Code P1102 - WTF ?
Old Aug 9, 2012 | 09:23 AM
angelic0-'s Avatar
Default Code P1102 - WTF ?
Truck was fine, i put in the Spartan Tunes... now truck triggered P1102 and CEL came on...
I tried to locate the MAF sensor but where the MAF was supposed to be truck now has a blocker plate, or so i beleive...
This is what the intake looks on the truck:
Any suggestions on how to fix this...
Old Aug 9, 2012 | 09:31 AM
Mdub707's Avatar
Sounds about right for the tunes and the intake. Going back to a stock intake would alleviate this. Or stock tuning. I hate K&N.
Never seen anyone just delete the MAF, that's really odd.
Old Aug 9, 2012 | 09:32 AM
Mdub707's Avatar
Did someone already do a coolant flush on this truck? Is that red coolant in there?
Old Aug 9, 2012 | 09:34 AM
angelic0-'s Avatar
Is red coolant bad for a 6.0 PS ?
It probably has had some coolant system work before because the filler box for the coolant is the wrong one i'm told... hence the black marker...
Old Aug 9, 2012 | 12:30 PM
TheRobenator's Avatar
I like to use Ford Motorcraft Coolant (yellow), can't go wrong..
And yes, K&N seems to be the most hated air intake around these parts.
Old Aug 9, 2012 | 12:52 PM
Mdub707's Avatar
Well no it's not bad, but what is bad is if it gets mixed with the gold Ford stuff. A lot of guys do a full coolant system flush, then just go with an ELC (extended life coolant) from CAT or Rotella etc, and the red stuff is quite popular, looks like someone might have already done that for you. If it mixes with the gold (if anything mixes with the gold for that matter) it will gum the crap out of the oil cooler and cause issues.
That bottle is fine. The min line is actually the max line, make sense? Only fill to the min line at the most. For a while Ford had a sticker they slapped on there to notify this. My truck got the black marker job from the local Ford dealer too, not that big of a deal as long as you know. I'm told they have new bottles with the new lines on them, but I wouldn't go out of my way to buy it just for that... personally.
Try running the truck stock and clear the code, see if it comes back. I know a lot of the earlier trucks with MAF and the butterfly valve always threw a code and a CEL with an aftermarket intake on.
Old Aug 9, 2012 | 05:33 PM
bobfbigman's Avatar
ford was messing around with the use of the MAF, 03-early 04 have the MAF/ from late 04 to sometime in 05 it just has a temp sensor and late they went with temp sensor and a MAF sensor. The only reason these are on the trucks is to monitor EGR flow.
Old Aug 9, 2012 | 08:58 PM
angelic0-'s Avatar
Ok, so i shouldn't be too worried with it throwing a MAF code ?
Old Aug 9, 2012 | 10:27 PM
bobfbigman's Avatar
what year is the truck? the Spartan tune might have been written for one with MAF
Old Aug 10, 2012 | 08:12 AM
Mdub707's Avatar
What he said.
dwmeehan
Sep 6, 2015 04:20 PM
Saams69
Jul 20, 2015 11:21 PM
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
Backhoeman
Jan 3, 2015 12:53 PM
