Exhaust sputters!!!!!
Old Aug 8, 2012 | 08:42 PM
cumminalong92's Avatar
Default Exhaust sputters!!!!!
I have a 1992 Cummins with a hood stack. I have only turned up the pump. But my exhaust will sputter at part throttle at low speeds, and sometimes when make sharp slow turns. Any ideas? It still has stock injectors, not sure if that has anything to do with it.
Old Aug 8, 2012 | 10:01 PM
RanchhandTCR's Avatar
bad timing or bad injector my 24 valve just started that the other day and it turned out to be a stuck injector. are you smokin like a fright train..
Old Aug 12, 2012 | 07:04 PM
I turned up the pump to get it to smoke, but it only smokes alot when I stomp on the pedal at low boost pressures. Stock injectors too.
Old Aug 12, 2012 | 07:11 PM
Well how many miles it got? it can be Valve lash, Timing, or Injectors I had exhaust sputter just last week and it turned out to be a stuck injector. without being there kinda hard to diagnos, if you want turn back your smoke screw and see if that helps?
avatardvr
18
Aug 8, 2019 12:38 AM
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jake12valve
May 10, 2015 11:57 PM
carid
Diesel Bombers Sponsors
Dec 12, 2014 02:26 AM
