Wiring for fuel pump
Old Aug 8, 2012 | 04:12 PM
EmersonT's Avatar
Default Wiring for fuel pump
No Power to Wiring at fuel pump. Traced it all the way back to the fire wall and nothing. What relay or fuse does it get power from .... 94' K5...
Old Aug 8, 2012 | 05:29 PM
Mayhem's Avatar
you can check the LP under the dash by running a jumper wire to the G terminal on the ALDL port under the dash open the T valve under the hood then apply power to the G terminal if the LP works its probally the OPS
Old Aug 8, 2012 | 06:58 PM
ebarresi5894's Avatar
Splice a wire from a key on fuse wire (cruise control, gauges, or the ign on radio)
to the grey wire on OPS and you will have your lift pump running whenever truck is on.
Old Aug 8, 2012 | 08:27 PM
EmersonT's Avatar
We know the fuel pump works. Trying to find a Wiring Diagram so that we can chase wires...
Old Aug 9, 2012 | 05:11 AM
Mayhem's Avatar
Relay is on the firewall
Old Aug 9, 2012 | 05:40 AM
Mayhem's Avatar
here you gp
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
moneypitk5
Feb 12, 2015 11:01 AM
B.k. Smith
10
Jan 7, 2015 02:29 PM
