1/2 inch cp3 fuel fitting
Old Aug 8, 2012 | 06:34 AM
2500HeavyDuty's Avatar
Default 1/2 inch cp3 fuel fitting
So while i had my engine out i decided to do some improvements on the cp3 on my engine.
One of the things i did was make a 1/2 fuel fitting for the supply for the cp3.
Most of the 1/2 fuel fittings you see out there are still too restrictive because it bottlenecks down to a smaller fitting when it reaches the part that threads into the pump.
The stock 3/8 fitting Has an inner diameter of .232" with equates to about .0422 square inches.
The modified fitting i made was pieced together with a half inch ac line fitting and a M12x1.5 to jic. i cut the jic part off and welded the ac fitting on to it and that took care of the 1/2 inch hose part.
The M12x1.5 fitting on the other side still had to be taken care of so i bored out the fitting from .232" to .295". i could of probably squeezed out more of it, but i was pushing it already.
The area had increased to .683 inches squared resulting in about a 62% increase of flow capability.
Here are some pictures of the fitting.
Side by side difference:
Size difference between both fittings on the side that goes into the cp3:
the 1/2 inch fuel line attached:
Clearance with a modded wire harness:
Attached Thumbnails 1/2 inch cp3 fuel fitting-20120802_185238.jpg   1/2 inch cp3 fuel fitting-20120802_185116.jpg   1/2 inch cp3 fuel fitting-20120802_232803.jpg   1/2 inch cp3 fuel fitting-20120802_205730.jpg
Old Aug 8, 2012 | 07:34 AM
RAW's Avatar
RAW
Nice write up! Where there any noticeable differences after the modification?
Old Aug 8, 2012 | 08:41 AM
dont know
truck is still in pieces right meow.
Old Sep 16, 2014 | 06:02 PM
Meyer907's Avatar
I know this is a old thread but I just did a search on this and want to know if it is worth doing?
Old Sep 24, 2014 | 07:31 PM
well not worth paying 50 dollars for a ppe one i tell you whut
Old Sep 25, 2014 | 01:08 PM
Meyer907's Avatar
Thanks that answers my question.
Old Sep 26, 2014 | 04:36 PM
i dont like paying for things that can be easily made. like thier high flow fuel fittings that sell for 40+ all that is needed is 1/8 drill bit to modify you existing one, the only thing is that u have to make 100% sure that there are no burrs left when u re install it.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
