transmission,
Old Aug 7, 2012 | 07:45 PM
jenny heise's Avatar
Default transmission,
hello everyone, i was driving down the highway when my tow haul started flashing and i coundnt accelerate, so i pulled over and checked fluid and it was fine so i thought i would try again got a min away then check engine and tow haul came on flashing, so last ditch effort i unpluged batteries in hope that just maybe , it only got me four mins or so down the highway. and while sitting there there was a ticking sound coming from the bottom of tranny. and ideas? my friend said sounds like oil pump in tranny. let me know what everyone thinks thanks alot
Old Aug 8, 2012 | 07:29 AM
Mdub707's Avatar
When the tow/haul starts to flash, it's usually not good at all. Mine would do this when I tried using tow/haul. It would shift a gear or two then just stop shifting and lock it into whatever gear it was in and the light would flash. Trans needed a complete rebuild.
Are you running any mods on it? Do you tow really heavy with it? These transmissions are VERY stout, usually the only thing that kills them is a generic programmer (ie, banks, bullydog, edge, etc)
Old Aug 8, 2012 | 03:39 PM
bobfbigman's Avatar
I know there was an issue with one of the shift solenoids in these trans, it would stick and cause these problems, might be an easy fix for a dealer,can't believe I said dealer but it might be your best choice for this as they should be familiar with it.
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
SixSpeed
Jan 11, 2015 01:41 AM
W350-4x4
Nov 12, 2014 09:35 AM
TheDirtyDozen
Oct 1, 2014 10:09 AM
