modifying or changing intercooler
Old Aug 6, 2012 | 07:34 AM
m715's Avatar
Default modifying or changing intercooler
I am putting a 5.9 cummins from 1995 Dodge 3500 into a M715 (military truck). The motor is a tight fit but I should be able to get it to work. The real problem is fitting in the intercooler.
Can the intercoolers be "cut down" by a radiator shop or do I have to order a custom intercooler (and if I do, who would you recommend)?
Thanks for your help
Old Aug 6, 2012 | 07:39 AM
94CTD's Avatar
I don't believe you:d be able to cut it down, your best bet would be to make some measurements of the room you have and find an intercooler off of something else to fit.
Old Aug 6, 2012 | 09:05 AM
93_Fummins's Avatar
You could have a custom air-to-air made, or check out some of the tuner car sites for the oddly configured off the shelf intercoolers. You could also run an air-to-liquid intercooler which would give you flexibility as far as mounting the air-to-liquid unit and then either run jacket coolant through it or set up a small radiator and stand-alone system for it. Furthermore, you could look into sourcing a factory Cummins jacket coolant aftercooled manifold and crossover, found in some medium duty applications and generator sets. You'll have to have the injections lines to go with it though as it takes up the entire area of the intake plate. That would be a bolt on solution though, if you could source it.
Cougdiesel
Feb 2, 2016 10:17 AM
Rooster24v
Price Quote - Request A Price
Aug 26, 2015 06:24 PM
DAR_
Jun 6, 2015 03:26 PM
Nealwheels
Jan 10, 2015 01:33 PM
roanokerivermud
Dec 2, 2014 05:42 PM
