Radiator may be no good.
Old Aug 5, 2012 | 11:13 PM
deadman inc's Avatar
Default Radiator may be no good.
Well today i had to change out the lower radiator hose cause it had a pen hole in it so i figured i would get it out of the way. So in the process of taking the lower hose of the 180 degree fitting on the radiator i guess i broke it off or something. I put the new hose on and it was leaking so i tried to take it back off and the whole fitting broke off the radiator and came out with the hose. Now the question is, is it broken or can i get it fixed? It is metal so didnt know if i can get away with JB welding it or taking it to a radiator shop and get it fixed. I sure hope so cause im trying to get the dang truck on the road and then this happens???
Old Aug 7, 2012 | 01:03 AM
1stgenblowingsmoke's Avatar
You can try n get it soldered back on at a stock but I wouldn't get your hopes to high.
Old Aug 7, 2012 | 06:33 AM
Not looking forward to have to buy a radiator if I have to.
"On the road using Tapatalk"
Old Aug 7, 2012 | 10:56 AM
mkriebs's Avatar
Mine was "bad" too, according to the radiator shop. Funny thing is, we soldered the leaks up and put it back in the truck. It seems to cool the truck just fine and doesn't leak any more. I know I am on borrowed time though, but will eventually upgrade to an aluminum one. The OEM radiator is brass, so it brazes pretty good!
Good luck!!!
Old Aug 12, 2012 | 11:45 AM
Well wound up getting the radiator derusted and fixed. Sucker works great for $75 bucks.
Old Aug 17, 2012 | 02:48 AM
jwirth's Avatar
Had the same thing happen to me 2 years ago Radiator shop fixed it for $45. I have that rad put up in the garage now I said the hell with it and got a griffen thermal one for it needed more cooler for towing
Ian Roberts
Mar 23, 2015 12:36 AM
Mar 17, 2015 01:40 PM
willgoss
Ford Powerstroke 08-10 6.4L
Feb 12, 2015 09:52 PM
Jackson Gregory Scott
Nov 1, 2014 04:06 PM
Hardcorefx4
Oct 6, 2014 07:47 PM
