5 Hours Later ... 24V Rebomb
Old Mar 1, 2008 | 01:51 AM
DB Admin's Avatar
Banned
Default 5 Hours Later ... 24V Rebomb
Ok i have some photos ill post in a bit
I moved my Boost Gauge from my Steering Wheel Pod Via A Kit from Kens Performance Solutions , and put it in a new Piller Pod 2 gauge with speaker From Nate Via Bomb Bay , Removed the Mech FP gauge from the piller , and installed an Elec FP gauge (Kens Performance Solutions) on to The Steering Pod , So now i have Elect FP reading on my Steering pod and my boost and Pyro on a pillar Pod , My After market speaker wouldnt fit the hole in the Pod , Has anyone Put in replacement tweaters that fit the same size holes? right now i just have 2 wires hanging out of the hole ,
I then Removed the EZ and Installed the Quadzilla Adrenaline (Diesel Dawgs) , I already have Pyro , Boost and FP gauges but ill hook up for Trany Temp , Ill be posting some photos i snapped during install
I only have 3 complaints on the Quad install ,
-The Short red wire was suppose to have a Mini Fuse tap on it insted it had a terminal connector on it
-The wires Come into the Control Pod on the wrong side
- T Taps Are your Serious !! , I Used a posi tap , DO NOT USE THE TEE TAP they are Junk and will cut the wires
Old Mar 1, 2008 | 02:28 AM
2500HeavyDuty's Avatar
Old Mar 1, 2008 | 02:46 AM
2141pete's Avatar
Old Mar 1, 2008 | 02:57 AM
DB Admin's Avatar
Banned
Im getting them !!!!!
Old Mar 1, 2008 | 02:59 AM
DB Admin's Avatar
Banned
2 More Negatives for the Quad box ,,
I cant find a Users Manual for this Quad box anywhere online like whats the Factory Program ? How to use it and ect...
Also it Monitors Oil Temp OR Trany Temp you cant have both at the same time , The Boost and EGT and FP are Individual
Old Mar 1, 2008 | 03:10 AM
DB Admin's Avatar
Banned
One more negative The Velco they Give you to mount the control Pod is some good Stuff , Too Bad the other side is not sticky at all , I dont have no photos of it in the truck because its laying by the windshield .. Yes i used the alcohol on the dash didnt help .
And that Sums up the Negatives , Im Iced in so i cant make it to a high way until maybe tomarrow So i have not done more than pipe shots with it to see more smoke at setting 10 then setting 1 , The Engine seems way more responsive then with the smarty/sz stack
Old Mar 1, 2008 | 03:20 AM
DB Admin's Avatar
Banned
ReBomb photos
Ive been collecting things fro the Bomb bay here and there and picking up some good deals on things , I had quite the hall way of bombs , Time to get em on , My truck fits in my garage but i cant walk around it so i grabed some tools and went to dads heated garage ,
Heres my Passenger Seat , Air Dog 150 and an edge ez thats sold , I will ship Monday
Driver Seat .... hehe
My Dremal NEVER LEAVE HOME WITH OUT IT !!
And Heat Shrink with A Red Neck Torch
And the Quad install Manual which is Very Professional High Quality ,, Its as nice as a little book can be ...
Back Seat:
Slip Lock for Diffs as i have a slight chatter - Heath
Electronic FP gauge and Snubber - Kens PS
Quadzilla Adrenaline - Diesel Dawg
Boost Gauge Relocate Kit - Kens PS
Pillers on the floor - ndurbin
Quadzilla Adrenaline Box Open
My Flash Light
Old Mar 1, 2008 | 04:08 AM
DB Admin's Avatar
Banned
Pump Tap , On my Second VP44 Aie Aie Aie
Here Quadzilla Grouped 2 wires together one is the Pump Tap (Tee Tap Connector) and the other wire is to read Fuel Pressure You will have to take there tape off and run the yellow wire back 1/2 way down the splitloom so you can connect it to your Fuel Pressure Sender Which they DO NOT SHIP WITH YOUR PRODUCT you have to contact them to get it There directions to how to get yours in the box
Heres a PosiTap.. I cut there Tee Tap Fitting off .. I Refuse to use them
This is how i got my Control Pod up to my dash
Old Mar 1, 2008 | 04:11 AM
DB Admin's Avatar
Banned
And heres the wire thats suppose to connect via fuse tap to a fuse in your engine compartment fuse box
Thats it i got tired of taking photos
Old Mar 1, 2008 | 05:38 AM
Jazz's Avatar
I did the same thing on my install with posi-taps. As far as the short red wire with the ring terminal I connected directly to the battery and threw in a inline fuse. Directions are pretty vague as far as settings and use of the box. When you are done being iced in and want to feel some real power, that is quite insane, here is the download for the competition version. Now remember this is just the first one and still being worked on, but it's nutz. The aggressive tunes run good. I've tried 3 different ones so far.
Quadzilla
