defrost only
Old Aug 4, 2012 | 05:37 PM
staylorw250's Avatar
Default defrost only
i went throught the drive through and went to turn the ac on and noticed that i only have defrost no feet or face this just happened out of nowhere any suggestions
Old Aug 5, 2012 | 05:04 PM
cummin_un_glued's Avatar
FormerVendor
vac lines under the hood
Old Aug 5, 2012 | 05:14 PM
dolla_hite's Avatar
yep vac line came loose/broke in engine bay. same thing happened to me
Old Aug 5, 2012 | 05:41 PM
where do these vaccum lines run and are there any commons spots where they break
Old Aug 5, 2012 | 08:02 PM
dolla_hite's Avatar
along the fire wall cowl area. mine came undone at a t fitting behind the brake booster area i believe
Old Aug 5, 2012 | 08:25 PM
alright thanks that would make since because i just got through pulling the noise insulation stuff of when i went to put the valve cover back on thank you guys
Old Aug 5, 2012 | 09:05 PM
NeverEnough's Avatar
when ur climate control loses its vacuum it defaults to defrost by spring i do believe. safety thing
Old Aug 5, 2012 | 09:42 PM
RanchhandTCR's Avatar
When I did my lift pump I pulled one of the plugs off the vaccum line, up on the rubber seal near you windshild behind the break booster
Old Aug 6, 2012 | 10:46 PM
found the problem the clip that hold the line in place broke and the line laid on my downpipe it melted it shut thanks for the help guys i didnt realize vaccum ran the the blower controls saved me from buying a switch
Old Aug 7, 2012 | 06:03 AM
FormerVendor
Glad you found it.
Sent with a Droid RAZR in one hand and 14,000 volts in the other.
