and more brake problems...
Old Aug 3, 2012 | 01:01 AM
jdbigblue12v's Avatar
Default and more brake problems...
was driving to work today and noticed my brake pedal got stiff and the truck stopped much better than it did.. ever. the brakes were always sloppy due to the rear drums not being properly adjusted and just over worn. i know im not making a smart choice by driving with almost no rear brakes but my pockets are to shallow right now to do them over. but anyways it felt like something unclogged in the master and they were they way they should be. so i drove the rest of the day and then i came home for about an hour and then left with the truck and the pedal got worst and worst... driving til i had to put the pedal on the floor to stop and looked at each wheel... right rear wheel cylinder blew out and fluid everywhere. driver side front is also leaking from the caliper. what causes a wheel cylinder to blow-out besides age and wear and tear? is there something seriously wrong with my brakes that i dont know of? whats involved in doing an entire brake over haul and what do you think it would cost? sorry for long post just aggrivated and looking for best advice to make sure its dont right and wont have to do it again until its due again.
thanks in advance- James.
Old Aug 3, 2012 | 09:11 PM
firstgencummins's Avatar
interested to know price for a complete brake overhaul as well. Im in a similar situation
Old Aug 3, 2012 | 10:15 PM
RanchhandTCR's Avatar
I cant tell you put a caliper is about 40 bucks, rotors another 50 almost the same for the drums a master for my truck cost 180 bucks,. so its quite a bit, but souds like you caliper may have craked or the piston pushed out to far.
Old Aug 4, 2012 | 12:19 AM
NKY 1stGener's Avatar
I actually just did a complete front brake job on my 92. For loaded calipers(which comes compressed and with pads) plus rotors was about $237. It all depends on what front end you have in your truck though.
and im guessing for the rear, drums will be about $50 a piece, maybe less.
Last edited by NKY 1stGener; Aug 4, 2012 at 12:19 AM. Reason: Automerged Doublepost
Old Aug 4, 2012 | 04:49 PM
i have the dana 60 kingpin and i just did the rears last night took about 3 hours including using a screw driver and a hammer to take 2/9-16ths lock nut off of the axle to remove the drums but i had a ceased wheel cylinder on driver side and blown wheel cylinder on the passenger and all of the brake shoes were on metal with no pad left except on wich the material they use on the shoes was chipping off. i have a friend who works at a local firestone so i had him call in for the parts and the total amount at public price was $182.20 but at firestone cost i got everything for $64.67 with a quart of brake fluid! included all hardware new springs and everything i needed!
Old Aug 4, 2012 | 07:10 PM
Sweet deal man, ya having blown wheel cylinder isnt gonna help ya much..
Old Aug 6, 2012 | 01:05 PM
flyingcrodeo's Avatar
I priced all this stuff Rotors, Calipers, misc parts, pads, drums, shoes, etc. for around $500 to do it myself and thats the best parts I could buy at O'reileys, but thats not including the brake booster. And a new resevor is like $25 I think too. And not sure on brake lines though I dont think those would be much more probly $100 including fittings if you just bought brake lines and bent them yourself and rented the tools from O'reileys.
So if you did them one weekend yourself your lookin probly at around $750 - $800 for all new everything.
Oh didn't read the last 2 post, dang that's a good deal!
Last edited by flyingcrodeo; Aug 6, 2012 at 01:05 PM. Reason: Automerged Doublepost
Old Aug 17, 2012 | 03:17 AM
jwirth's Avatar
[QUOTE=jdbigblue12v;922169]i have the dana 60 kingpin
Dana 60 doesn't have a kingpin
Old Aug 17, 2012 | 03:27 AM
how doesnt dana 60 have a kingpin? i have done the king pins over and i have a friend who parted out same truck in a reg cab and it was a dana 60 kingpin check this out..
got my parts from here/
https://www.4wdfactory.com/store/pro...C-Kingpin-Axle
Old Aug 17, 2012 | 03:38 AM
jwirth's Avatar
I'm talking about a one piece king pin. Our trucks have the upper and lower bushings and bearing
