Big Single
Old Feb 29, 2008 | 05:56 PM
Blacksmokeracing's Avatar
Default Big Single
Any yall runnin a big single on the street. im talkin 66mm or bigger and if so how is the drive ability?
thanks
Adam
Old Mar 1, 2008 | 03:52 PM
Crawler's Avatar
It all depends on what you want to do with the truck.
A 66 is not a problem, if the truck is setup properly.
On a 12V the 64 is a lot more friendly.
All that being said. I run a 72mm currently. So, what is your precise question? Driveability is a subjective thing.
Old Mar 1, 2008 | 05:55 PM
well im lookin at runnun an Aurora 5000 so thats a 71mm. From dealing with ATS as much as i have and them knowing how i drive they say itd be some what streetable biut i was lookin for yalls opinion. once that turbo is one this truck will no longer be a daily driver. but i want to be able to drive it on the street still. the truck is gonna do both drags and pulls.
and yes ill have the fuel to spool the 5000
Thanks
Adam
Old Mar 1, 2008 | 06:06 PM
Crawler's Avatar
I wouldn't want to run a K31 (Aurora 5000) as a daily. But, as you pointed out your truck will no longer be a daily. In that case have at it.
The 71s make a pretty good charger. But, I wouldn't be willing to run a non-wastegated K31. To keep from overspooling the charger you will have to sixe the exhaust housing a bit large, which gives up some spool up. This is fine on a sled truck. But for drag racing I'd want a tighter WG housing.
Just something to consider.
Old Mar 1, 2008 | 06:22 PM
alright thanks for the info. im gonna plan on runnin an externel WG till i go to a big twins setup. im thinkin a5k on top of somethin really big 90+mm.
Adam
Old Mar 2, 2008 | 05:32 AM
Crawler's Avatar
THAT would be the way to go.
As far as in twins, I ran a K31 over a 96mm S510 a while back. Nuts would be an understatement.
~Wes~
Old Mar 2, 2008 | 12:55 PM
wow i can only magine what those twins were like once they spooled.
Adam
Old Mar 2, 2008 | 03:06 PM
rbratby's Avatar
I have a 71mm charger that I daily drive. It's not to bad. I have to keep the engine rpm up. If I lug the engine around it will smoke like crazy.
Jun 4, 2015 08:40 AM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Feb 2, 2015 03:10 AM
Dec 10, 2014 03:19 AM
Oct 26, 2014 06:20 PM
