fuel pressure gauge install question.
Old Aug 1, 2012 | 05:50 PM
THEGOLDPRO's Avatar
Default fuel pressure gauge install question.
So i bought the gauge with the gauge kit and am getting ready to hook it up, Do i need to use the pressure gauge isolator shown in the pics? and if so what does it do? also i have a schrader valve coming off of my vp44 can i plumb the gauge in there?
Old Aug 1, 2012 | 06:53 PM
empty wallet's Avatar
Yes you need the isolator, it prevents fluctuations caused by the vp. And yes it can go where the schrader is, once it's been removed.
Old Aug 1, 2012 | 07:48 PM
c farmer's Avatar
A needle valve will prevent water hammer. The isolator will keep you from having to run fuel into the cab. The isolator will have fuel on one side and antifreeze on the cab side. I don't mine having fuel in the cab, but some people don't like it. Hook your fuel line to the shrader valve on the vp then to a needle valve then to the isolator or the gauge.
Sent from my DROID3 using Tapatalk 2
Old Aug 1, 2012 | 09:02 PM
THEGOLDPRO's Avatar
Did my kit come with a needle valve? or will i need to buy one?
Also i cant pm yet empty wallet, where are you located in CT? im in Southbury
Old Aug 1, 2012 | 09:05 PM
c farmer's Avatar
Mu guess is that it didn't come with one. Go to Napa, they have them.
Old Aug 1, 2012 | 09:09 PM
THEGOLDPRO's Avatar
do you have a link to said needle valve so i have some sort of idea what im going to ask the guy at napa for
Old Aug 1, 2012 | 09:15 PM
c farmer's Avatar
Let me look for one.
Old Aug 1, 2012 | 09:16 PM
THEGOLDPRO's Avatar
thanks man.
Old Aug 2, 2012 | 10:10 AM
c farmer's Avatar
NAPA (Weatherhead) #WH6820 is the part number.
Mopar1973Man's Dodge Ram Cummins Turbo Diesel Forum - Fuel pressure gauges and needle valves
Also check out this site. Lots of good info.
Old Aug 2, 2012 | 10:05 PM
THEGOLDPRO's Avatar
Thanks man
