So i got some new hardware
Old Aug 1, 2012 | 03:01 AM
2500HeavyDuty's Avatar
Default So i got some new hardware
care to guess what is next?
Attached Thumbnails So i got some new hardware-338587_10100699665581736_1461613363_o.jpg
Old Aug 1, 2012 | 09:33 AM
biged681985's Avatar
Twins?
Old Aug 1, 2012 | 12:02 PM
yeeeesssss
Old Aug 1, 2012 | 12:04 PM
i swapped out all those damn allen bolts for flange hex bolts on the valve covers.
saves a few headaches.
Attached Thumbnails So i got some new hardware-413176_10100699939198406_222462508_o.jpg   So i got some new hardware-garrett.jpg
Old Aug 1, 2012 | 02:05 PM
Deezel Stink3r's Avatar
Dang, I completely forgot the ARP bolts...
I did the same with my valve cover- factory was a mixture of torx, hex and allen heads.
I used stainless steel with a dab of ceramic anti-seize. Polished the hex heads and
voilà- shiny thin stainless steel hex heads.
Good work, Danny! Do I have recognized washers below the bolts?
Old Aug 1, 2012 | 04:13 PM
those arent washers, theyre flange head bolts.
the bottom half of the valve cover uses a washer kinda. but its just so easy to disassemble now. before with the allen head bolts when using an allen bit the bit and the ratchet wouldn't fit because there wasn't enough clearance at the firewall on the back bolts.
So you're stuck with using a ball end bit and sometimes they would strip out the bolts i have in there now i can use a swivel socket, wrench, small ratchet and have plenty of room.
Old Aug 1, 2012 | 09:05 PM
Ya I rounded one of the back bolts off one time on a top kick. What a pita that was. Took me 8 hours to get that **** out
Old Aug 1, 2012 | 11:11 PM
you could of pulled the cab off and back on in less than that time
Old Aug 2, 2012 | 12:05 AM
It was on a top kick and no way to pull the cab.
Old Aug 2, 2012 | 01:19 AM
i said PULL IT!!!
teehee, i just got done taking apart my engine wiring harness, its gonna be saweet and oh so much easier to work on after i get the harness finished up.
like u can fit your hands anywhere with the harness hooked up now, its so freaking awesome. ill post up some pictures when i finish modding it.
Last edited by 2500HeavyDuty; Aug 2, 2012 at 01:19 AM. Reason: Automerged Doublepost
