View Full Version : 24 Valve 2nd Gen Dodge Cummins 98.5-02
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16
  1. 1998 24v code p1389 help
  2. NV5600 question
  3. torque converter?
  4. slave cylinder
  5. Transmission questions...
  6. Sport Bumper Conversion?
  7. gonna put some electrics in the valve body of my 01 cummins
  8. 47re to nv4500
  9. 01 cummins auto tranny issue
  10. The 53 Block cracked . . .
  11. code dodge
  12. Blower Fan Issues
  13. Fuel in oil
  14. allison for a cummins ????
  15. No start, no start. Ok, it started.
  16. Looking at a 2002
  17. Diesel Fuel Compatible Thread Sealer
  18. adjusting valves
  19. 99 cummins
  20. NV4500 transmision issues jumping out of gear
  21. Hard Start
  22. truck missing at idle?
  23. should bands be adjusted?
  24. adjusting my wastegate
  25. 16mm turbo housing from 93 onto a 2001??
  26. trouble interpreting codes: P0216...
  27. trucks getting warm.
  28. Tranny and suspension question- help please...
  29. head bolt torque
  30. Another VP44 death?
  31. issue ?????
  32. auto tranny
  33. bad computer, still runs?
  34. Clutch!! help!!
  35. looking for 1st gen wheels
  36. VP-44 Ram Air
  37. drain problems?
  38. rearend
  39. v10 to cummins swap
  40. fuel gauge problem
  41. How do you like your Sport headlights?
  42. In tank fuel pump?
  43. Wastegate stuck closed.
  44. 53 question
  45. No tach/alt...won't start unless you
  46. 98.5 24 Valve. Help me out...
  47. Oil Pressure & Fuel Pressure
  48. Turbo
  49. injector pump PO216
  50. wait to start light 98.5
  51. Advice on fuel tank module repair
  52. is this a good deal or not on a 24v? advice please
  53. soundproofing
  54. 02 dually need advice
  55. starter contacts
  56. Electrical Problems Still
  57. KDP Question?
  58. Truck heater cycling when hot?
  59. Oil Pressure Switch FAIL... Holy Expensive! Help?
  60. What is a Fuel Plate
  61. VP-44?
  62. guess my fuel milage
  63. hot wire
  64. thinking about doing a side exhaust
  65. bad injector?
  66. lowered cummins
  67. not running well
  68. what to look for....
  69. about to switch to cummins
  70. a REAL 24v jake brake :)
  71. shocks
  72. how to measure vacumm
  73. duct system problem
  74. no fuel millage
  75. changing factory fuel filter
  76. fass fuel filters???
  77. dodge wiring >:(
  78. 1 of 8 lol
  79. how fast?
  80. surging idle please help
  81. wireing fuel pressure guage
  82. Tranny has No Passing Gear
  83. anyone for governor?
  84. 01 cummins injector cores?
  85. 98 Ram 2500 Blown Head Gasket?
  86. Final Follow up on new lift pump with my rebuilt vp44
  87. PCM reflash
  88. Smoke rolling from drivers rear tire
  89. removing the bed
  90. Tow Mirrors Help
  91. Tranny not slipping... more like down shifting
  92. help choosing
  93. TPS died again
  94. Fog Light Restore!!!
  95. Compitition Forum?
  96. 2 turbos in 2 weeks
  97. Headliner?
  98. running funny
  99. All The Symptoms Of A Head Gasket, But Its Not
  100. anyone in albuquerque?
  101. Restriction, Loading up ?
  102. CAD Axle
  103. Oil pressure
  104. help need help
  105. Having trans issues. Hoping you guys can help
  106. 99 Cummins Computer Problems PLEASE HELP
  107. If all else fails... check the EASY stuff!!
  108. door fasteners
  109. speaker problem
  110. gotta love owning a dodge
  111. Transmission Temperature & Overdrive
  112. rust
  113. Fuel Gauge Help
  114. Turbo oil leak
  115. Hx35 wheels Biggest/Smallest/Best
  116. Factory Oil Gauge
  117. wait to start light
  118. Missfires from time to time?
  119. Wait to Start Light
  120. 01 24v runs hot and cuts out
  121. turbo surge??
  122. 00 Cummins Crank Sensor
  123. WTB a tip
  124. wastegate actuator
  125. fuel and air mods??
  126. Curious about Dodge
  127. electrical issues bad
  128. vp44 pump
  129. TC lockup with cruise control
  130. Electic Problems
  131. fuel gauge 98 dodge ram 2500
  132. Ye olde oil vent bottle
  133. need some help with a truck not starting
  134. exhaust band clamp
  135. ECM problem?
  136. 99 dodge sometimes wont start
  137. Hard Starting When Warm
  138. KDP Help
  139. Low boost code
  140. Little miss?
  141. code 1690?
  142. helpp tranny is messed up
  143. fuel tank
  144. 98.5 dodge ram 2500 wiring diagram
  145. Little Miss at idle?
  146. 24v Things to look for and fix?
  147. cant avoid workin on the pickup
  148. Wait to start light problems?
  149. 99 Dead Clutch Pedal and fluid is all leaked out, Far from home. What to do?
  150. Steering.....
  151. Just changed the a/c evaporator and what a job that was!!!
  152. nv5600 no 6th
  153. Front axle specs and possible ball joint solution
  154. strange noise
  155. BOOST
  156. Steering problems
  157. looking for 2wd hubs and projector lights
  158. well vp44 is done
  159. cracked block
  160. jchavis
  161. VP getting air in it?
  162. The ol Velcro - THROW STUFF TIL IT STICKS! HELP!
  163. weird whine
  164. Loose control arm bushings?
  165. bad oil leak
  166. Muffler
  167. A/c Fan control...
  168. starting question
  169. Short box flat bed?!
  170. 1/4 tank issue
  171. transmisson swap
  172. Fuel Gauge
  173. strange noise... need help
  174. replacing a dash
  175. Dodge 2001 cummins
  176. transmission question
  177. VP 44 pump life
  178. vp44
  179. Turbo questions
  180. Vacuum Pump Woes
  181. 2001 6 speed
  182. Which clutch?
  183. do i need a new vp???
  184. Tanny Temp
  185. Shrader valve on the fuel in fitting
  186. Finally Fixed
  187. truck wont start after fuel filter change?
  188. 2001 cummins dead pedal
  189. Replaced VP got codes
  190. Banjo bolt for the VP
  191. no wait to start light?
  192. Lift Pump Electrical Circuit Issues
  193. VP44 install videos?
  194. VP replacement, I DID IT!!!
  195. couple questions about and 02
  196. Cruise control question
  197. More ???'s on VP install
  198. Cruise control as easy as...
  199. VP install today
  200. Sputtering/Stalling above idle
  201. Inside the VP44 - Cummins VP44 Injection Pump Internals
  202. Dodge Cummins Starter Contacts Replacement Video
  203. p0216
  204. Things I need for VP install
  205. Cruise Control not Working? A/C Wont switch off of defrost vents? heres the fix
  206. What year tranny
  207. Transmission Coolers
  208. auto or std
  209. timing trouble?
  210. Cam sensor
  211. About Tow Mirrows
  212. cruise quit
  213. Heated seats
  214. Torque Converter??
  215. tire balance causing death wobble?
  216. Front Differential Capacity
  217. Losing Oil
  218. where to get a good electrical noise filter from?
  219. MAP sensor!!!
  220. no start or crank?
  221. New transmission down again!!! 3rd time!
  222. Can't win for losing....
  223. Raptor mounting on frame
  224. auto trans first gear and surge at 40 mph
  225. Check Gauges?
  226. Engine Codes
  227. Blue Chip Diesel
  228. cummins 53 block
  229. 98 dodge cummins ?
  230. 1998.5 dodge cab leak?
  231. Pillar pod
  232. clutch switch
  233. Dodge V-10 not shifting out of first
  234. Injection pump
  235. Nv4500 input shaft install walkthrough
  236. nv5600 shift rail pics
  237. No power sometimes
  238. diesel in oil
  239. failure codes for a vp 44 injection pump
  240. need help quickly
  241. oil in turbo ?
  242. a/c, heater fan
  243. sputtering
  244. Transmission is slipping. What to do now?
  245. somethins still wrong
  246. rear parking brakes on 2002 dodge dually
  247. power steering pump
  248. 53 BLOCK- Cracked block.
  249. catalytic converter removal
  250. Breather Bottle Delete
