PDA
View Full Version : 24 Valve 2nd Gen Dodge Cummins 98.5-02
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27
  1. Shorted Computer!!! Help
  2. violently shaking after clutch install
  3. Dually question
  4. Fuel Pressure
  5. power steering went out help please!
  6. Fuel pressure problem???
  7. Bigger Tires - Now I have an EGT Concern
  8. Heater help.
  9. Chrysler 47RE Transmission
  10. Still getting that funny throttle...
  11. Electrical Problem?
  12. rotary pump in a 24V
  13. Gas Milage
  14. Help
  15. Problems
  16. Headlight issue
  17. Vin # 6 or 7
  18. Question about Cruise control and manual transmissions
  19. 2001 cummins turbo
  20. Afe wastegate
  21. need a clutch
  22. P0500 code need help!
  23. WTB: HX35 or HY35 for a 2001 cummins
  24. vaccum pump
  25. nv4500 shaft play?
  26. honeing
  27. 24v Rebuild Need Advice
  28. Fixing up my old truck.
  29. Hx35/40 limits
  30. Towing
  31. **Need HELP 2001-interm loss of power
  32. Symptoms of NV4500 starting to go out????
  33. Compound opinions
  34. time for new tires - should I go with 315/75/16 ?
  35. Tranny problems
  36. Fuel Gauge Issue
  37. 2001 Cummins - dead pedal? TPS?
  38. Just Making sure.
  39. 99 24v 4x4?
  40. Turbo advice
  41. Water in fuel light
  42. I need some help!! Bad!!
  43. gear help!!!
  44. Question for you 24V guys.
  45. Choosing clutches. Red alto or Borg or raybestos?
  46. 2000 Dodge throttle probelm?
  47. Funny throttle.
  48. plow trans
  49. help confirming lift on my truck **with pics
  50. Air intake
  51. 98 v10 transfer case
  52. Shook me sh*tless
  53. removing engine
  54. Opposite of 'Dead Pedal'?
  55. cummins sputtering
  56. Peterbilt glider kit
  57. fuel problems
  58. fass system question
  59. starts, lopes, and then dies
  60. Cummins running rough
  61. Valve cover gasket?
  62. Help
  63. 3 pillar guages hooked up, couple questions
  64. Exhaust system recommendations needed
  65. turbo low circuit cel?
  66. 00 Cummins 24v oil in turbo
  67. NV4500 difficult shifting
  68. What is this? edge map adapter???
  69. Fuel Pressure issue?
  70. Stock Injectors Value
  71. Having more problems with my 02 dodge cummins.. wont start
  72. Headlight switch issue
  73. Time For Turbo
  74. Fuel pressure gauge on its way
  75. over reving
  76. Dually adapters
  77. Ball-Bearing Water cooled turbo
  78. turbo whistle
  79. air dog delima
  80. Considering stepping up to a diesel
  81. Time for a turbo rebuild....or new turbo?
  82. No Blinkers or Hazzards
  83. Quality injectors?
  84. swap a 01 to 99
  85. Band Adjustment
  86. P0230 Code Help??
  87. Raptor lift pump pressure drop question.
  88. throttle problem
  89. head gaskets where to find one
  90. 47re Problems.
  91. still no lock up
  92. What lug nuts do I need? Rockstars
  93. Need help ASAP!
  94. Battery opinions
  95. truck problems
  96. Side cover leak...
  97. 2002 3500 24V knock
  98. NV4500 Broken Cluster Gear
  99. lope, then dies
  100. 1999 v10 to 2nd gen cummins
  101. Apps or vp44?
  102. major oil loss on driver side
  103. vacuum problem
  104. 5.9 dead pedal then over rev
  105. head gasket?
  106. oil leak cant figure out?
  107. Diablosport trinity programmer?
  108. 4x4 Acuator Question
  109. very odd problem
  110. Stumped..
  111. Extremely low fuel pressure... im stumped..
  112. Top Gun Customz
  113. need advice asap
  114. lift pump location
  115. Code?
  116. bolt size
  117. BD or industrial
  118. Weird Shudder/Vibration
  119. Rebuild Kits
  120. 99 24v w/ fass fuel system issue with dying out in motion
  121. What kind of injectors shoud i use?
  122. 2.5in spacers
  123. HID's messing with quadzilla
  124. Transmission help
  125. Running odd after injector swap
  126. Transmission help
  127. radiators and upper hose cold
  128. yes fass
  129. Help with my 99 Dodge 5.9
  130. need help on 01 cummins
  131. 02 cummins 2500 cold start
  132. truck died dont know whats wrong?
  133. truck just died?
  134. remote door locks not working
  135. Turbo on a manual truck
  136. nerf / step bars with bed access
  137. piston cooler
  138. want to gain more rpm ???
  139. wiper arm removal
  140. Traveling and having big issues HELP PLEASE!!
  141. longer rear axle U bolts
  142. Torque Converter problems? Help
  143. NEED HELP ASAP!!!!!
  144. stock lift pump on framerail??
  145. Turbo`s
  146. carrier bearing?
  147. 2001 ram 2500 cummins
  148. oil leaking out of head gasket help!?
  149. Edge settings for fuel economy when towing light
  150. Grand junction/ montrose colorado
  151. Drw to srw?
  152. Nv4500 not working
  153. opinions wanted; wheels
  154. Oil leak front of engine
  155. metal in oil
  156. need some help: possible fuel gelling at -5 F
  157. Injector help!
  158. bypassing stock fuel filter
  159. I think my VP44 died....
  160. Fue Injection Timing code
  161. 280k miles....what should I expect to replace soon?
  162. Need more heat
  163. anyone selling any turbos
  164. 911 Denver Colorado
  165. Tranny problems 98.5 cummins nv4500
  166. transfercase fluid
  167. more power
  168. Lowdown on trailer charge wire/general electrical?
  169. any ideas what this is
  170. 53 block???
  171. headlight upgrade options
  172. boost elbow?
  173. alternator/ regulator problems?
  174. 500-600 hp
  175. 02 cummins inj pump
  176. Truck WILL NOT turn over..
  177. stock filter housing question
  178. Suggestions Wanted.
  179. Timing Rattle noise?????
  180. Another ECM question
  181. HX40
  182. rebuild kit
  183. Roaring noise while driving, not from front end
  184. Body Control Module ?
  185. #53 hard block ?'s
  186. wat year ecm's will work
  187. 22.5
  188. nv4500 rebuild kit
  189. Just b4 disaster
  190. 2002 ram 3500 cab and chassis rearend
  191. electronic issues help!
  192. Looking for a place to get a switch box or panel
  193. LOOKING FOR MOD IDEAS...
  194. Looking at buying 02 cummins and NEED HELP !
  195. recommendation on antifreeze
  196. exhaust wont seal
  197. 98.5 cummins upgrade????
  198. tc lockup?
  199. Second Cummins 24V 1999
  200. want to get my first dodge with cummins!
  201. big problem!
  202. Newbie What's up 2nd Gen
  203. APPs Or No??
  204. clutch install
  205. Driving habits while towing?
  206. RPM's all over the place
  207. Torque Converter Random Unlocking,47RE
  208. 275k
  209. what kind of chip
  210. Hard starting issue
  211. Reman VP44's
  212. EGT are not normal
  213. 1999 24 valve Transmission oil leak
  214. Intermintent starting problems
  215. What boost PSI should I be seeing.
  216. power issue
  217. fuel cannister '00-02
  218. apps sensor mess
  219. Heater
  220. Quadzilla Adrenaline erratic throttle response
  221. 1999 Dodge 2500 24valve
  222. overdrive slipping
  223. park and dash lights?
  224. white smoke
  225. no power on hills
  226. Ouch that's gonna cost me
  227. Heater
  228. Superchips flashpaq
  229. Best lift pump and programmer
  230. 99 dodge leans to the right
  231. Good deal or not?
  232. Truck repaired by dodge, now more issues, help!!!
  233. Convince me to do cab lights
  234. PCM and ECM upgrades?
  235. fuel filter housing
  236. Cleaning dirty motor?
  237. map sensor?
  238. Curiosity's got the better of me on VP44's?
  239. Front end problems!!!
  240. multiple trucks 1 smarty programer
  241. need a nv4500
  242. Oil drain plug
  243. Restoring my 98.5 suspension question
  244. Troubles starting in the morning.
  245. strange issue?
  246. truck wont shut off when i turn the key off
  247. 99 dodge motor swap
  248. Fuel Tank Heater
  249. bad apps?
  250. 2000 dodge cummins 4x4 tranny rebuild cost?
