- changing injectors
- Head Gasket or Turbo?
- 4x4 problems/question
- Alternator Issues I Believe
- Truck won't start
- exhaust
- 3.31 Gears in a 1 Ton???
- Need pics
- P0236 - error code
- Hay from Tulsa,OK
- need a new apps i believe.
- Cold weather no power
- Bad Injectors? Bad Turbo?
- plugging wastegate
- hx 40
- No Throttle Response & Died
- DASH crack
- Mods
- DDRP with big lines
- 5" Exhaust tailpipe location
- turbo swap
- 4 wheel drive noise
- ebay truck. What do you think?
- Turbo
- Code Help
- Filter minder testing...
- Missing Sway Bar?!?
- Blowing Smoke
- South Bend Clutch? New Input Shaft?
- Lift Pump Question
- what kind of #'s do you think?
- Fuel Mileage went in the crapper
- wont start
- high egt #s at 1500rpm
- turbo seems to spool late
- no heat
- What is a stock cam worth?
- Threw a couple codes
- best way to bomb a 2nd gen cummins
- Edge Juice with Attitude or Quadzilla Adrenaline with Pulse?
- Anyone have an opinion on this fuel pump??
- Cab light install
- Trouble Codes
- Odd Problem
- I have a few questions?
- 150k mile valve lash adjustment necessary??
- Heated Mirrors
- TIMBO APPS
- airdog install question
- thinking of converting to a 5 speed, is it worth it?
- blower motor resistor
- All of a sudden Death WOBBLE
- First Post: VP44 Problem?
- I winter preped my truck
- im looking to trade
- Turbo Silencer Rings
- Tranny troubles?
- Clutch
- Clutch slipping
- Grease for the Caliper Pins
- Need advice on rear brakes not working??
- Dana 60 spline count
- programmers
- Frozen window
- Boost tube from Turbo to Intercooler.
- Nuetral Safety Switch Bypass
- heat
- &@*& door panels!!!
- Dual exhaust
- 01 transmission
- stacking programers
- Overhead console
- The light is blinking more
- what clutch
- Ignition Problems
- ABS i think
- rv275 injectors?
- Unsolved issue!
- Big Thanks to "The Chop Shop"!!!!
- 2 WD LEVELING KIT HELP!!!!!
- Swapping ECMs
- 2002 Dodge Cummins Wheel Bearings Installation - Videos and Photos
- Source for good starter!!!!
- Dying VP?
- boost fooler???
- need quik fix for trans cooler line!
- Engine barely runs and im along way from HOME!
- cummins part #'s
- Holley Blue hard start when warm
- trouble in paradise
- 47re Shift kits
- Speedometer trouble.
- A few q's
- Need help with trans problem!!!
- Fuel leak help
- leaky vacuum pump
- quadzilla adrenaline or edge juice with attitude?
- Burning up headlight switches
- question for the more knowledgeable
- Heat issues and temperature fluctuation
- 4k kit
- New VP44 and RV275s and still doggish...
- Tired of searching, need a door. Little help.
- TCM
- Truck is in the shop!
- oil pan gasket leak fix?
- Easiest/Cheapest/Most recomended mods...
- hard starting issue PLEASE HELP!
- shows no charge but stays charged
- Holley blue electric lift pump
- conversion ?
- Best Chip For 02 24V
- Truck Surges Really Bad
- codes
- limp mode
- My 2000 Suffers From Lack Of Power
- Overboost Code??? How?
- CHECK THIS OUT...Use A 727 Torqueflight Tranny Pan For 47RE...REALLY???
- Wanting To Build A Set Of Twins!!
- engine code assistance
- Need advice on head!!
- Strong Rotten Egg/Sulphur Smell
- Carfax
- Speedometer And Odometer Don't Work Right, ABS BRAKE Lights On Too???...
- MileMarker Hydraulic 12000# winch
- MAP Sensor
- No Smoke
- Opinions On Manual Tranny's
- Just Replaced VP44 And Still Won't Run
- 1-2 Shift Problem
- Best Reman. VP44 For Cheap
- Which Calc Is More Accurate?
- Gonna Cry
- Speedometer Quit
- Injector Replacement Advice???
- Mad At The Truck
- Transmission
- Refresh My Memory
- Seat Covers????
- Lift Pump In Now What?
- Next Bombs?
- Chinese Heads?????
- NV4500
- Stealth Plate
- Truck Seat
- Bucking
- Troubling DTC
- Looking For A Part Number - Gaskets
- VP44 Bad Or Dead Pedal??
- Pulling Gear Case Cover
- Block Question
- Hiccups
- Tranny Question
- 01.5 Juice W/Attitude Tubro Cool Down Problems
- Carlise Truck Show
- Super B Turbo Question/Concern
- Replacing The Front Seal
- Front Locker?
- Got Deuces
- Something (VP44?) Is Badly Wrong
- Source For Carter 4090046 LP
- Lift Pump PSI
- Need Help With Brakes
- Time For A Truck
- Excessive White Smoke During Hard Start
- 2001 5.9L 24V Coolant Leak @ Head Gasket!
- VP44 Help
- VP44 Help
- Can I Beat A New Mustang???
- Intake
- Questions On EGTs And Fuel Pressure
- Transmission Problems 47RE
- Surge Issues
- '02 Overdrive...Crunch Boom Clatter Bang
- Starter Kickback
- Towing Injector With Light Performance Mods Question
- Electrical Issue
- Walbro pressure adjustment?
- Transfer Case Problems
- EGT
- Boost Pressure
- rust
- Brake Master cylinder
- Cruise Control
- Performance Temp Question
- What Transmission?
- Using Oil
- How Do You Get The Dash Out Of The Way..
- Why Did I Overheat??
- Is This A Good Deal On An Engine
- Left Coast Diesel Sets VP44 Record!
- brake light on, no brakes
- Block Code
- Aussie Stacks Pics
- Pinched Off Wastegate Hose, How Much Boost Should I See?
- Custom Air Intake
- Codes 336 And 237
- What's Stock Boost
- '99 4x4 - Stress cracks in front rotors??
- 98 24V, Only 17PSI, Sometimes Hard Starts?
- Safe Towing RPM Range And With OD Or No??
- Adjusting the Slop Out Of A 2nd Gen Steering Box
- More Codes - Unknown Cause
- Tie rod ends
- 3 Pumps...Still Leaking
- difference between 2500 and 3500???
- Transmission Doesn't Want To Shift
- I have 2 Q's I hope you guys can help me with..
- PO122
- Transmission Trouble
- Electrical Question About The Batteries
- Dana 80 Rear Wheel Bearings
- Cummins Shocks
- Air Filters
- VP on 235hp '01
- Transmission Question
- Stange noise underhood from exhaust brake
- '03 Front clip on '01
- 01 Cummins Problems
- Down Pipe
- Buying A Cummins?
- How Many Is Too Many?
- Hard start AFTER running a while
- 24 Valve misfire? Help!
- Eccentric Bolts
- VP Toast?
- ATS Tranny Milage
- Tranny Upgrade
- Fuel Additive
- Is This An Acceptable Way To Lift 3"
- VP44 Question
- Manual To Auto?
- Electric Mirror Switch And Down Pipe
- Tranny
- Fuel Mileage And Smoke
- What Does Valve Lash Sound Like?
- Track Bar
- Fluctuating Engine Temp
- Timing Cover, What Else?
- Adrenaline IN!!
- Transmission Throttle Valve Cable
- AirDog 150 Is Installed!
- Ball Joints
- Vibration Dampener Bolts
- Hub/Bearing Part Search. Recommendations?
- HX35 Spin Test?
- Silverline T409 Turbo Back Exhaust Installed (PICS)
- Now I Got Some Codes?
- Return Fuel Line Leak ?
- 53 Block
