- Lift pump running while cranking, mine wasnt
- Driveshaft carrier bearing,, suspected of 70+ mph vibe
- looks or power?
- Fuel tank
- Hood Spring
- Towing My Truck
- FLOW CHARTS?
- pressure boost sensor
- transmission control solenoid
- Boost elbow delete.
- Stock turbo
- Code P1687
- fuel lope?
- Driver's Side Seat... Replacement?
- Speedo not working
- Sad Story
- new VP
- high pitch squeal
- mecanical fuel pressure gauge isolater question
- turbo
- in need of a hx35
- what turbos will work of stock trucks
- vp 44 question
- 4wd issue
- cool stuff about our truck
- ITS ALIVE!!!!!!!!
- problem with fog lights
- dieing VP-44
- Is it worth is???
- big troubles
- Cluster and overhead console problem
- HELP! Want to get the best for my buck....
- i think its a wiring prob..
- please help vp44 !!???
- cb radio mounts
- What tranny will work in my 98.5 ?????
- TRAGIC accident
- fuel pressure gauge???
- tried everything Vp is gone RIP!!!
- No reverse lights..well sometimes
- thanks
- What Power adder for an '02. Prices also ASAP
- U-joint
- pitman arm stuck??
- Power Steering Going?
- cab lights
- vp44
- lowering a 1999 4x4
- PO253 & TRUCK WONT START
- Rear end problem and tranny issues!!
- well e big green is down again.
- runnin lights
- running a powerstroke?
- 99 To 02 BLock Change
- Transmission identification??
- 24v questions
- p pump swap
- big programer starting problems??
- Truck has trouble starting
- Turbo pressure
- 47re swap
- Need Fuel canister Cap ASAP!!
- super chip?
- 5 speed wont go into reverse or 5th
- Fuel Pressure issues
- no smoke
- How much problems?
- BIGED Broke my truck
- help truck won't start
- new 44
- Overhead Map Light
- smoke switch
- Tranny Swap !!!!!
- Power Steering Pump?
- AAPS or VP44
- squeek
- Fuel pressure jumps!!
- He351 Turbo in 02
- vp problems
- Helpful hint when buying parts
- Torque converter vibration fix?
- detroit diesel turbo
- oil leaking from transmission
- fuel pressure
- truck stalls?
- Dodge DTC code P3232
- Cummins Surging??
- hx or hy
- Edge box
- Input Shaft
- ball joints. any tips..
- what do you guys think?
- Smoke switch?
- Fuel pressure with adrenline???
- Injector connector tubes
- Newbe here i have a few questions??
- super chips
- Vacuum Line Size?
- hr vp44
- Nitrous v.s Propane
- where to go what to do
- Dana 80 Rear ??
- tranny ???????
- Rotors???
- Boost Elbow
- 2 stroke oil?
- .093 Lines/Tubes
- has anyone ever tried this???
- CTD won't start
- IAT Sensor
- Wheel Spacers/Adapters
- Tach Issues
- Day time running light
- Edge A2 Monitor
- timing vp 44
- Quad-adrenalin VP44?
- changing injectors
- Head Gasket or Turbo?
- 4x4 problems/question
- Alternator Issues I Believe
- Truck won't start
- exhaust
- 3.31 Gears in a 1 Ton???
- Need pics
- P0236 - error code
- Hay from Tulsa,OK
- need a new apps i believe.
- Cold weather no power
- Bad Injectors? Bad Turbo?
- plugging wastegate
- hx 40
- No Throttle Response & Died
- DASH crack
- Mods
- DDRP with big lines
- 5" Exhaust tailpipe location
- turbo swap
- 4 wheel drive noise
- ebay truck. What do you think?
- Turbo
- Code Help
- Filter minder testing...
- Missing Sway Bar?!?
- Blowing Smoke
- South Bend Clutch? New Input Shaft?
- Lift Pump Question
- what kind of #'s do you think?
- Fuel Mileage went in the crapper
- wont start
- high egt #s at 1500rpm
- turbo seems to spool late
- no heat
- What is a stock cam worth?
- Threw a couple codes
- best way to bomb a 2nd gen cummins
- Edge Juice with Attitude or Quadzilla Adrenaline with Pulse?
- Anyone have an opinion on this fuel pump??
- Cab light install
- Trouble Codes
- Odd Problem
- I have a few questions?
- 150k mile valve lash adjustment necessary??
- Heated Mirrors
- TIMBO APPS
- airdog install question
- thinking of converting to a 5 speed, is it worth it?
- blower motor resistor
- All of a sudden Death WOBBLE
- First Post: VP44 Problem?
- I winter preped my truck
- im looking to trade
- Turbo Silencer Rings
- Tranny troubles?
- Clutch
- Clutch slipping
- Grease for the Caliper Pins
- Need advice on rear brakes not working??
- Dana 60 spline count
- programmers
- Frozen window
- Boost tube from Turbo to Intercooler.
- Nuetral Safety Switch Bypass
- heat
- &@*& door panels!!!
- Dual exhaust
- 01 transmission
- stacking programers
- Overhead console
- The light is blinking more
- what clutch
- Ignition Problems
- ABS i think
- rv275 injectors?
- Unsolved issue!
- Big Thanks to "The Chop Shop"!!!!
- 2 WD LEVELING KIT HELP!!!!!
- Swapping ECMs
- 2002 Dodge Cummins Wheel Bearings Installation - Videos and Photos
- Source for good starter!!!!
- Dying VP?
- boost fooler???
- need quik fix for trans cooler line!
- Engine barely runs and im along way from HOME!
- cummins part #'s
- Holley Blue hard start when warm
- trouble in paradise
- 47re Shift kits
- Speedometer trouble.
- A few q's
- Need help with trans problem!!!
- Fuel leak help
- leaky vacuum pump
- quadzilla adrenaline or edge juice with attitude?
- Burning up headlight switches
- question for the more knowledgeable
- Heat issues and temperature fluctuation
- 4k kit
- New VP44 and RV275s and still doggish...
- Tired of searching, need a door. Little help.
- TCM
- Truck is in the shop!
- oil pan gasket leak fix?
- Easiest/Cheapest/Most recomended mods...
- hard starting issue PLEASE HELP!
- shows no charge but stays charged
- Holley blue electric lift pump
- conversion ?
- Best Chip For 02 24V
- Truck Surges Really Bad
- codes
- limp mode
- My 2000 Suffers From Lack Of Power
- Overboost Code??? How?
- CHECK THIS OUT...Use A 727 Torqueflight Tranny Pan For 47RE...REALLY???
- Wanting To Build A Set Of Twins!!
- engine code assistance
- Need advice on head!!
- Strong Rotten Egg/Sulphur Smell
- Carfax
- Speedometer And Odometer Don't Work Right, ABS BRAKE Lights On Too???...
- MileMarker Hydraulic 12000# winch
- MAP Sensor
- No Smoke
- Opinions On Manual Tranny's
- Just Replaced VP44 And Still Won't Run
- 1-2 Shift Problem
- Best Reman. VP44 For Cheap
- Which Calc Is More Accurate?
- Gonna Cry
- Speedometer Quit
