- Oil and oil filters
- posi or unlimited slip ??
- "no Bus" code
- HELP PLEASE!
- Show off your 2nd gens!
- trans slippin really bad
- trans burp!
- Buzzing sound under hood 99 dodge
- Help truck died and wont start
- new vp still ?s
- wont start,,2002 cummins
- 1688 vp44
- gettin a new vp
- 99 dodge Water temp ?
- '99 wont start
- gear oil?
- oh where to start
- how to wire in lift pump
- oil problem HELP!!!!
- p1689
- Fuel press loss
- check engine light
- Dealer said no high idle.
- DRAGGING/ LOCKED UP FRONT BRAKES
- VP44 help!
- New batteries for 98 cummins?
- Have dash lights coming on and off...
- help bad turbo?
- 4 wheel drive
- Single or dual steering stabilizer
- FUEL PROBLEM...
- blow by...:/
- Coolant Leak During High Idle
- VP44 safe fuel pump pressures?
- Heat senor leak on Fuel filter.
- Injection Pump?
- P 7100 question
- 2001 dodge won't start
- valve adjust and missing problems
- turbo causing leaks?
- T-Case Help
- FIRST CUMMINS AND HATE IT
- Smarty problems
- clutch
- gear question
- Oil leaks ???
- new truck need advise
- hd t-case
- should i trade for a 99 cummins
- Leaky injector, or lines?
- 4 wheel drive disconnect
- 5x18 injectors
- power
- ADVICE PLEASE:Replacing U-joints on front driveline...
- Head gasket or oil cooler?
- fuel pump is shot!!:(
- 47re lock up fix
- 1999 24v question.
- dead pedal
- ECM thoughts
- cruise control
- Transmission hoses
- Transfer Case
- Clutch not disengaging?
- Loss of power
- The Ol Headliner
- axle ratio question
- O-Rings, Pictures, Myths, Facts and Info!
- Still won't start
- Losing prime. What else is there to check?
- Truck stumbling Need Help!!!
- Turbo Trouble
- throttle postion sensor
- Compression Specs for 24 valve
- what gas mileage am i getting?
- Throttle goes dead.
- clutch questions
- HY35W to HX35 Question
- New Bed Needed for '02 Ram 2500 4x4
- lift pump
- Lope after wide open
- Messed up fuel return line
- muffler poll
- No brakes!
- good hot wire
- Transfer pump stays on/guage issues
- fuel leak
- 2wd loose steering.
- Need Help !!!
- cummins oil pressure?
- All good things.
- i need some enlightenment
- 99 cummins clutch install gone wrong
- Alternator or computer?
- fuel heater leak
- transfer Case, 4x4 Not Working
- Poor fuel mileage?
- is my vp44 on its way out?
- trailer running lights
- VP44 or APPS
- speedos off
- rebuild the old or in with a new.
- CRUISE CANT GET IT FIXED
- hard starting issues
- It runs slow from cold starts ??
- bad fuse??
- Worth it?
- Fuel level sender
- transmission
- Truck
- Heater Short
- hesitating 2002
- Dropping the tank
- injector pump
- mirror questions...
- Single to Dual??
- converting to power windows and locks
- cruise control help 2001 2500 p-pumped
- just for poops and giggles.
- scary smoke?
- Brake pedal slow coming up
- weird problem truck will idle all daylong
- Friend has a 24valve... what can i mod for him ?
- left turn signal and cruise control short??
- valve lash
- Gasoline to Diesel filler neck
- Need your Input
- mystery
- code216
- Cold start blues
- weird start?
- what clutch should i use?
- Truck Rear Too High
- PMSING dodge!!!
- VP, lift pump help!!!
- white grey smoke under boost
- Knock Knock Knock......
- old ram is gone
- hard start
- white grey smoke??
- intermittent miss
- low voltage
- bad vp pump
- FPCM question
- loss of boost
- Wastegate plugging
- boost press senser reading low.
- 01 24v auto-want to build up tranny
- heater core replacment
- APPS stutter but not
- Turbo oil drain tube gasket?
- 48RE Cooler prob...
- Auto- 5speed ??
- hard start and cutting out while wot
- 2000 sarting problem and other issues
- buddy with a 2000 electrical problem
- fuel problems
- Pump issues
- Torque Converter not locking up.
- Trouble codes help
- Rocker Arm Inspection
- need help with torque specs pleaseeeee
- Head Bolts
- tap broke in manifold!
- tranny swap
- who makes this tc
- Truck Problems
- Dim Headlights????
- '99dodge ram 5.9 cummins diesel-truck won't start
- VP44 / BD lift pump. issues
- Steering and fuel canister question 2001 QC 4x4
- 12v turbo on 24v
- BREATHER
- 47re cooler check valves
- A/C compressor clutch squealing
- crazy situation fuel related ?
- HELP!!!!!!!!!!!!! 01 cummins "no bus"
- 47RE Transmission price??
- brakes / steering issues
- what size bolt is needed for turbo flange
- Engine Knock Help ASAP!
- VP RIP
- Great 24V info
- air conditioner just died
- help on injection pump
- question about 47re and 47rh??? help
- squealing when shifting
- Turning up the line pressure in the 47re trans?
- removing 47re from an 01 cummins
- crankcase breather
- Lockup in OD, cant make up its mind.
- Fuel Guage Issues
- stainless steel tranny cooler lines
- auto to manual tranny swap?
- starter
- Truck wont start
- Wastegate on 02 3500 auto tranny
- Headlight issues
- new clutch
- 5spd... slave cylinder junk?
- Do not know what is wrong with truck..Any ideas?
- leme know what u think plz
- Lights intermittently dim and display CCd.. ???
- before i take her to the shop?
- Advice on my hopefully soon to be first diesel
- Machining Head After Blown Gasket??
- Rear axle bearings?
- 02 Cummins acts like it is not geting fuel when pedal is pressed
- just installed my cab lights!!
- hard to start.
- 98 auto trans problem in overdrive
- PPE lift pump
- Fuel pump( fass) relay voltage from ECM
- Leveling Kits
- On board air
- Brakes locking up
- Just a lil more smoke?
- Brake lights and blinkers
- 01 2500 Tranny issue?
- hx-55
- turn signal wire color
- Power Steering & Vacuum Pump Seals
- muffler time...
- ho swap vp
- finally !!!
- OBD II
- Which Sport Headlights Did You Use?
- i got a miss at low rpms
- feels like brakes are on
- Home Maid Stack Opinion
- 12valve or 24valve, what do you prefer?
- Auto Trans Slippage Question?
- Need help with codes and "no bus" code
- quad updates
- truck missing at idel when warmed up
- intake manifold
- lift pump and filter
- Going to buy 2001 cummins 4x4. ALL STOCK
- Turbo question
- Need some smoke
- 99 cummins, rpm spikes to 3200, then won't rev past 1200rpms
- Remote Keyless Entry (RKE) Programming Help
- Think TPS Finally Died
- HID headlights
- will a 04 nv5600 work
- Cab lights
- trans problems
- starter clicks
- tranny change?
- Erratic Boost / Tranny Shutter
