View Full Version : 24 Valve 2nd Gen Dodge Cummins 98.5-02
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21
  1. Funny noise!!!
  2. Need help with nv4500 parts
  3. abs light on
  4. 02 Auto Trans
  5. blew something
  6. EJWA Install
  7. HELP! TDC question
  8. dt control arm bushing size
  9. Need an answer FAST
  10. Swaping OD units.
  11. Bad injection pump?
  12. Turbo going bad?
  13. 24valve plug and play
  14. ABS Booster
  15. Tore the roof(and doors) off
  16. Auto Swap 47 for a 68 conversion??
  17. always grinds into 3rd gear
  18. new lift pump or intank pump
  19. quadzilla xzillaraider help!!!!
  20. Vulcan DS V Install
  21. carrier barring?
  22. strange pull??
  23. Stock looking for more but no chip?
  24. Driveline noise?? Doesnt sound good.
  25. Muffler Delete Yes or No
  26. 02 24v issue
  27. 33x12.50's
  28. 01 cummins smoke at idle
  29. 5" down pipe
  30. new lift pump?
  31. Spray in Bedliners other uses
  32. Several Questions (lift pump issue, 4x4 engagement)
  33. t case... rebuild or upgrade?
  34. Injector Upgrade
  35. Fuel Problem
  36. Fuel gauge not working !
  37. Any suggestions ??
  38. 01 Dodge 3500 diagnostic port problem
  39. My latest 2nd Gen electrical system gremlin
  40. Fuel Pump
  41. another fuel pressure gauge question
  42. Computer Question
  43. VP44 swap
  44. dead pedal question
  45. 1999 dodge ram no start
  46. Upgrade intake?
  47. Oil filter relocation
  48. Smarty Troubles HELP!!!!!!
  49. Gauges or a EJWA or QUAD?? Need opinion
  50. neutral safety switch - what tool to use?
  51. I Got A Little Problem
  52. Speedo quit after installing BD speed eliminator
  53. AirDog Question
  54. new guages, now what
  55. 1998.5 NOT cranking
  56. What size injectors?
  57. I GOT A PROBLEM!!!!!!!!!!!!!!!
  58. 4WD DO-DAD
  59. 24 Valve 5.9 Liter Dodge Cummins
  60. Yes! Got it!
  61. lost 3rd and 4th gear
  62. thought I had a spare turbo...
  63. auto to manual swap
  64. blow-by
  65. 2001 ram steering/brake issues
  66. what did I MISS?
  67. guidance
  68. getting a 02 cummins with an auto and 130xxx
  69. oil leak?
  70. starter problems
  71. In tank lift pump ?????
  72. no lift pump power
  73. need help
  74. 2000 5.9 MPG!!
  75. power steering pump leaking
  76. E-brake
  77. How long can i run my truck without an air dog or fass?
  78. New to Diesel world with Cummins Wastegate questions
  79. 53 block perdiciment
  80. First post and a question
  81. Maintenace
  82. tranny rebuild qustions? please help
  83. 47re help needed
  84. No power
  85. What would cause my fuel tank to be pressurized?
  86. Advice on tuners
  87. 2 Run or not 2 run 2 stroke
  88. blue smoke
  89. crappy night.. now what?
  90. Is Exhaust Brakes Worth The Money
  91. 01 cummins not starting
  92. power steering/brake issue
  93. Should I dump it?
  94. good reads on a website about used motor oil and disel fuel
  95. Transmission is starting off in 2nd.
  96. 1999 Dodge 2500 no altenator charge
  97. BANKS EX. BRAKE
  98. Cheap turbo???
  99. lost 10lbs of boost when i swiched to a hot rod vp
  100. P0500 and P1693 codes
  101. Need Help Apps
  102. crazy exhaust sound
  103. Should i buy this truck?
  104. block heater temps
  105. 24 volt conversion
  106. truck running weak please help!
  107. 2000 Cummins, start issue
  108. is amsoil worth the bling
  109. Miss at idle? Help
  110. Best 47re VB
  111. intank pump or not?
  112. CB Mount
  113. loping?
  114. 53 block
  115. starter problems
  116. axle ? for yall
  117. 19.5\22.5 rims on 1998.5 dually?
  118. tps/curse corntroll problems
  119. DAngitT!! NV4500 5th gear clutch ring...
  120. What could this noise be?
  121. Torque specs and bolt size for RH motor mount???
  122. HX 35/40 turbo?
  123. Freshly minted diesel owner...key fob ??
  124. 3 codes please help!!!
  125. throttle position sensor???
  126. Any suggestions on where to start?
  127. (beating a dead horse) trans question
  128. crank sensor or what?
  129. Trying to find leak in return line.
  130. 1999 cummins making driving me nuts
  131. vp44 normal pressure
  132. 53 block
  133. How much is it worth?
  134. fan control switch
  135. Hard Start, Error Codes, New Transmission
  136. fuel press low warning light???
  137. Sending Unit?
  138. parking brake???
  139. ABS Problem
  140. Clicking in Front End
  141. winter cover
  142. Fuel Filter housing
  143. not starting
  144. take over jumpin
  145. vp44 hot problem
  146. ok next question dana 80 spline count
  147. G56 swap?
  148. Found Out What My Stutter Was Caused By! &%$#!!
  149. i have 3 codes on my ecu
  150. 4x4 isnt really4x4
  151. 2001 cummins programmer for fuel mileage?
  152. 99 dodge overdrive problems
  153. Tuner Question.
  154. 4 wheel drive issue
  155. stupid turbo clamp!
  156. Weird vibrations
  157. lift pump questions
  158. New whistle
  159. Need some help
  160. Lift pump delay
  161. engine washing
  162. hy35w turbo
  163. 2001 Sputter and stall ...no codes
  164. Gearing
  165. replacement seat bottom cover
  166. what is a smoke kill kit?
  167. veggie oil
  168. Grease used front sus.
  169. Trans rebuild
  170. what causes the truck to go into limp mode?
  171. nv4500 grinding in third & fourth gear
  172. Torque Management
  173. Trans shutter.... need help
  174. 1690 DTC
  175. Is it my VP??
  176. run away pump
  177. 53 Block
  178. looking at buying a 01 24 valve cummins
  179. vibration sound from somewhere
  180. 02 swap to 03
  181. I hate 24V's
  182. 47RE VALVE HUNG OPEN
  183. Dodge exhaust brake
  184. rocker arm ratio
  185. How long for shop to replace VP44
  186. ABS Control Module questions
  187. Brake Issues?
  188. Fueling Problem?
  189. Dash dead
  190. 0216 Fuel Injection pump Timing Malfunction
  191. Hard starting after sitting overnight
  192. ppump
  193. Chugging/surging on freeway with hard throttle after head gasket install...?
  194. 01 cummins gauge cluster
  195. loss of power
  196. Where to buy rebuilt calipers?
  197. Lock N Stitch
  198. new problem to me?
  199. hy35
  200. 47RE problem, hanging in first
  201. Cold fuel plugging fuel filter...
  202. Axle swap
  203. Clutch problems
  204. code crazy!
  205. Injector help
  206. Fuel Filter Leaking
  207. scanner code 1689
  208. vp44 return line
  209. Motor Oil
  210. Fuel Leak
  211. The Official, Unofficial, My "53" Block Cracked (Or Not) Thread.
  212. fuel economy
  213. 02 or 05 wrecked truck.
  214. which thermostat?
  215. 53 block?
  216. Opinions on a 2002 dodge cummins for sale.
  217. another 53 block question
  218. No Fuel Pressure
  219. Color Matched stacks?
  220. Coil Spring Question please help
  221. 99 Valve Seal Busting
  222. exaust temp
  223. Turn signals
  224. Gauge Install
  225. new battery cables or relocate?
  226. Swap: 6spd in 5spd out?
  227. got a ? about 98 dodge
  228. blowby or valve stem seals?
  229. power steering/brakes
  230. exhaust brake
  231. 98.5 Ram 3500 no-start
  232. Sputter/buck
  233. chattering clutch
  234. air dog connect?
  235. heater noise
  236. thoughts??
  237. exhaust system question
  238. How much would you pay?
  239. Help Please
  240. seat belt wont unlock
  241. input needed
  242. transmission line pressure
  243. blue haze
  244. Turns Over But No Start
  245. apps???
  246. STARTS RIGHT UP, DIES, THEN STARTS HARD
  247. Bouncing at 50 MPH...
  248. steering box leak
  249. 5th gear issue
  250. Rocker Arms and Pivots Scored/Scratched Help??
