- Problems with 03 Dodge Dually 3500 Cummins
- 2003 Dodge 3500 4 Wheel Drive 48 RE Transmission Issues
- service manual
- cant get the smell of anti-freeze out of my truck
- Tail light covers
- Backup lights
- 06 cummins injector
- Tranny cable vs electric kickdown ??
- Borg Warner??
- Installing cab lights on a 2500?
- 05' cummins shut off while idleing
- mirrors
- Is '03 preferred
- 48re to 6 speed
- sick 06
- Banjo Bolt on a 2007 Cummins fuel canister intake line.
- Confused.
- New Batteries Now No Start
- occosaional surge driving me crazy help
- sellinjg old truck getting new.
- Fog light's
- Fcm??? issues
- Silencer ring
- 2wd to 4wd
- low speed binding from stop to 5mph
- P2149
- loss power
- Just a reminder
- replacing my heater core every two weeks?
- Rear wheel hub caps
- What size tire
- Wire up anzo lights????
- truck stuck in liimp mode...
- Hydrogen in diesels
- turbo problem
- i have two questions
- 2006 3500 4x4 Rear End?
- Cold weather starting
- smells?
- Maintenance..
- vibrations !!!
- over heating- air pressure in coolant...
- Replacement Clutch, 2005 G56 Trans?
- electrical issue maybe?
- Batteries?
- Interior
- 2004 Dodge CTD Possible no start
- 05 5.9L Surging under throttle--no power increase?
- tranny question
- 4 codes
- Good diesel shop?
- 07 cummins in an 04.5
- Annoying issues - help me fix!
- Why does a/c comp run on defrost?
- Need a Torx Bit
- Jake Brake Malfunction
- Went and did it!
- Turbo
- Should I upgrade my tranny?
- 5.9 Factory Exhaust Upgrade..Aftermarket?
- Servicing an 06 auto tranny & rearend ????'s
- 05 ENGINE INTO AN 06
- Big-A
- Spec questions on an 07
- Timing knock and won't start
- NO SMOKE?
- CR or not...? NOOB ALERT!
- 03 Cummins Fuel Mileage Drop
- Changing Low Gearing
- brain tease
- oil change input
- Name that noise! Unit bearings???
- 04.5 Dually
- Those with dynatrac...
- Frustrated with a vibration..
- What to look for?
- Gear Case Leaking... should I do a cam too?
- no start
- Do the 3rd gens suffer cracked manifolds?
- Seats for these trucks
- Done with 6.7 back to 5.9 YeeHaw
- 48re to NV5600 swap
- Help! 07 Cummins 5.9 Gear slapping noise
- Please Help
- clutch problems
- Noise...
- High Egts..
- another 48re question! bands?
- 48RE issues
- NOTHIN BUT PROBLEMS SINCE I GOT IT!!
- Dodge 5.9L What to Look for
- Dodge Balljoints Can...
- smarty
- newb with questions
- Looong Cranking 04 Dodge Cummins
- automatic problems
- need an opinion
- Hard start sometimes when cold
- dodge limited slip
- what tranny fluid?
- Sound and vibration like its coming from rearend
- new truck
- fuel filter
- exhaust and turbos
- Just a suggestion:
- Third member
- 5th gear's rattling?
- 06 mega cab lift needed
- Shifter adjustment
- CR Pressure Relief Valve
- Transmission problem
- 48re to 68re swap?
- freeze plug
- rough idle
- steering linkage
- 04 won't start
- New 'LARGER' Air Filter Installed!
- NO BALLS
- Installed NOx Filter, Now Won't Make Boost
- Noise? What - Oh THAT Noise....
- Need help please
- is it my injector pump?
- Front Pinion seal
- Taillights For 2005 Dodge
- oil leak
- 2004 dodge ecm problems?
- Power Steering Quirk...
- Tranny fluid ?
- power board steps
- Codes PO646 & PO882 ?
- p1757
- Intercooler Issues on an 05'
- Under Center Seat Console
- Broken steering linkage.
- Tranny Nightmare, Help!
- empty weight of 05' qc 4x4 cummins
- Motor noise
- Help
- lift pump route 04.5
- need exhaust parts
- Need towing mirrors
- Is this a fair price?
- Truck Mysteriously shut down and wont restart
- Drivers side brakelight not working on Truck camper
- 03 RAM HO CUMMINS
- Tire vibration or near death wobble
- banjo bolt sealed washer
- Exhaust ???
- exhaust ?
- Roar at slow speed/slight pedal input
- 04 injectors for a 07
- help with trans problem please
- Fuel Bowl Bypass
- p2146
- tire psi question?
- rear universal joint part numbers
- 04 raattle
- Throttle position sensor
- broke and broke down
- Interior Questions
- Clutch Chatter
- surge and seams like rough idel
- clearance question
- tailgate bushing?
- Headlight adjustment
- starting problem
- back fire
- Where can I buy a new 5.9 CR longblock?
- headliner removal?
- SeaFoam in a diesel
- Turbo Overboost Code
- warrenty question
- 2003 No power
- How long will the stock clutch slip before it wears out completely?
- Fuel Gauge?
- Code: P0148
- new truck
- maintenance and add on questions
- Baldwin BD 7317 dual flow oil filters
- Turbo Squealing under load
- angel eyes :)
- clutch
- Torque converter wont lock up...
- Engine Bay "hoarding"?
- Trans Temps ?
- Need some quick steering help!!!
- Strange change on startups
- miles?
- Symptoms of a dying CP3?
- HP?
- About to buy
- stock lift pump went out
- How much boost before throw codes?
- More 48re questions, hoping for tranny guy response
- converting a auto 2003 to a g56 six speed
- Sudden loss in fuel mileage
- LOOOww dyno numbers!!!!
- dead at the pizza shop
- A/C problems
- Quick Tranny question
- The difference between an 04 and 04.5
- Power Steering/ Steering Gear Box
- what tranny does the 04 high output have
- stock boost pressures
- can someone get me a picture of this?
- codes P1751 and P1753
- possible purchase
- Major Truck Problem! R.I.P TRANSFOMER
- HELP !! 5.9CR converision
- cummins fan
- CRACKED INJECTOR WHAT TO DO??
- A few service questions
- Tstat and Water pump brands
- 06 quad cab
- Question...
- Converting the truck to a 4x4?
- Which model?
- 06 Dodge cummins AC not working all the time
- Tire Question
- Need Some Tranny Options
- 07 mega cab
- Tranny Questions..
- sputter and white smoke???
- Fan Speed Code
- lowering an 04???
- 2006 A/C problem?
- 6 spd swap questions
- Cruise problems
- help??
- Mega cab year choice
- blow by
- Smarty or PPE for 04 Dodge?
- 2004 problems
- truck not starting
- Amazing what one sensor will do
- 06 4x4 making "final drive/wheel speed" noise
- how to deactivate "horn honks when in gear and door open"
- help me fix my truck
- 2007 dodge i deleted the dinger noise
- MBRP Cat Delete Pipe
- rebuilt 48re NO GO!
- Help
- U-Joints
- Crazy wipers!!!
- Trans cooler
- Boost elbow on 2004 Cummins
- Is there any drone with a straight pipe exhaust?
- A/C Driver side only
- Need some help, might be crazy but.....
