View Full Version : 5.9 Liter CR Dodge Cummins 03-07
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13
  1. Laramie steering wheel swap
  2. HELP!!!!!!!
  3. Boost Question
  4. fuel filter/ Injectors
  5. Can it be done? Pro's N Con's?
  6. crankshaft position sensor question
  7. looking for more....
  8. Front End Work
  9. NV5600 How much oil?
  10. Are the injectors the same on.......
  11. Bought A New Truck
  12. keeps on fueling
  13. 2006 5.9 trans trouble need help!!!
  14. NEED HELP PLEASE!!!!!!
  15. 03 cummins transmission
  16. 03 tranny probs
  17. 06 dodge a/c problem
  18. How to increase MPG on 03 Dodge RAM 2500
  19. Crazy Truck, Please help!
  20. injectors
  21. i need a price
  22. i am new to the diesels so this might be crazy ?
  23. egt's
  24. "HeadLight Help"
  25. What 48RE Tranny upgrades are reccommended??
  26. cam position sensor irratic signal
  27. Wheres my Lift Pump?
  28. '04.5 3500 needs new front end, is this what I need?
  29. fuel filter
  30. Lift Pump??
  31. Tranny rebuilt now this
  32. front bumper
  33. Valve Body
  34. 183000 Miles-Motor Oil
  35. steering stabilizer
  36. Front end garbage
  37. 48re clutch slipping?
  38. power steering leak
  39. what do u think
  40. Trans gague
  41. bad transmission or super chip issues?
  42. Got my 05!!
  43. nv5600 input shaft
  44. oil pressure 05
  45. Stiff Gas Pedal and delayed Shift to second
  46. 03 cummins tran need help!!!!!!!!!!!!
  47. New Cummins Owner
  48. 2004 high idle
  49. Opinions Appreciated
  50. overheating while towing
  51. Help White smoke and oil consumption
  52. 2003 cummins 6spd manual?
  53. turbo- code..is it serious?
  54. Switchin from powerstroke to cummins..
  55. Clutch
  56. fuel system problem
  57. new 04.5 dodge cummins.
  58. NEED HELP?
  59. lift pump code.
  60. Engine Knock
  61. Engine warranty
  62. led gauge bulb help
  63. Will not start without removing the fuel filter!!!
  64. 2004-05 FACTORY DODGE MANUAL
  65. wheel problem???
  66. Want a limited slip, need parts
  67. my 2005 dodge...
  68. 5.9 cummins starts and dies
  69. Warning signs of bad injectors
  70. power and smoke??
  71. tire size?
  72. Is my transmission toast?
  73. B What best filteration system for CR dodge cummins?
  74. Difference in 03 injectors and 04.5 cummins injectors?
  75. i feel pretty dumb asking this...
  76. new truck maybe
  77. 2004.5 Cummins will not start after engine swap
  78. LOUD NOISE FROM TURBO
  79. 06 cummins missing probs
  80. 04.5 dodge cummins?
  81. Synetheic gear Oil NV5600
  82. Smoking?
  83. stock turbo part number?
  84. coolant temp gauge
  85. Bad turbo?
  86. White smoke
  87. swap
  88. Best way to pick up Switched and un-switched power
  89. 04 cummins using oil?
  90. manufacture dates for half model years
  91. coolant problems
  92. 2003 Ram 3500 Front Wheel Joints
  93. Tail gate and subwoofers
  94. PDQ Volumizer manual
  95. 03 turbo
  96. Recommended towing mods and maitnenance
  97. 2004.5 5.9
  98. Best choice for Transmission Rebuild?
  99. Wanted: NV271 transfer case
  100. 5.9L Cummins 3rd Gen wanted for 07 Ford
  101. G56 southbend 3250 dd reviews?
  102. cherry bomb muff
  103. Start up after months of sitting
  104. nv 4500 fluid
  105. starting problem
  106. 04 dodge cummins.
  107. cold start problem
  108. Is this normal?
  109. Major issues.. Need help.. 2004 H.O
  110. when should injectors be changed?
  111. 2006 Dodge 3500 accelerates on its own.
  112. Oil Leak when under load
  113. trouble codes & descriptors
  114. Rims and Tires on a 2007 Ram 2500
  115. apps sensor question
  116. Air dog question
  117. Possible injector problem?
  118. Looking for an aftermarket oil pan for my 5.9
  119. Truck Won't Start
  120. Truck Won't Start
  121. 05 cummins .040 over
  122. 12v into an 03
  123. fuel plate question
  124. 06 3500 Problem
  125. what is it worth
  126. Injectors
  127. Winter grille cover
  128. transmission fluid in the fuel?
  129. 2006 Dodge 3500 - Smoking/Knocking
  130. rear main leak
  131. 2003 question
  132. weird noise
  133. PROBLEMS W/ 230 hp cummins in a F750 2006
  134. No.4 fuel line
  135. Pickup surging
  136. CR injector Reliability?
  137. CR sound?
  138. horse power
  139. Fuel Mileage
  140. 48RE 2nd gear slipping?
  141. 2005 cummins motor in 2004 Truck?
  142. Help with 04 cummins
  143. injector swap question???????????
  144. cp3
  145. manuel trans cracked
  146. Gauges
  147. 48RE - G56 swap
  148. What kind of tires
  149. Module Interest
  150. HP curious?
  151. Please help with wiring...
  152. No power after warm up
  153. 2006 Dodge 5.9l Cummins loud engine knock
  154. mileage
  155. 4in turbo back and stock boost
  156. more injector questions
  157. common rail injectors?
  158. What is 2005 dodge cummins problems?
  159. Commonrail injector problem?
  160. Idle RPM
  161. RECALL
  162. 2004.5 Cummins 5.9
  163. Oil Smell
  164. Battery or alternator problem???
  165. Coolant bundle /Water tube Issue ?
  166. newer truck?
  167. straight pipe question
  168. some help from the BIG builders
  169. crappy AAM axle u-joints
  170. transfer case question
  171. Blow by
  172. fault code p0628
  173. how does the warranty work?
  174. Engine Needed... Looking for Help In or Close to Tulsa OK
  175. Power belt replacement on a 04 cummins
  176. weird acting truck
  177. found a 07 Cummins with 134k good Deal?
  178. Idle/cough?
  179. Fan clutch wiring??
  180. Lost all pedal response...
  181. Water Pump went out
  182. Still will not start
  183. misfire or rough idle at cold start up?
  184. towing mirrors
  185. 3.5 Years On Gel Cells??
  186. Offer made on my truck.
  187. Clunk or banging on downshift
  188. Alternator Question
  189. Alignment/Camber
  190. Fuel Knock and sputtering
  191. CR sounds?
  192. 48 re problims need help
  193. switching from vp44 truck to common rail.
  194. Damaged injection pump?
  195. weak or no power steering?
  196. Interior Lights WONT STAY ON!!!!
  197. 4" downpipe question???
  198. 06 ram no reverse 5.9 48re tram
  199. Injector Question
  200. winter storage prep help
  201. bag of parts??? NOT
  202. 03 lost power steering/brakes won't release
  203. Misses under hard acceleration. WHY? Ideas?
  204. pickup running rough.
  205. 2004 cummins diesel won't start suggestions
  206. Recommened intakes for a 07 5.9?
  207. Lots of Wind noise in Cab
  208. P0628 code
  209. truck wont start.....
  210. Straight pipe or ????
  211. D-tech parts
  212. 2004 cummins won't start
  213. Injector Hold down bolts
  214. got a problem
  215. No or Hard starting
  216. Injector Problems
  217. changed batteries
  218. code 2509
  219. obd2 port wiring diagram?
  220. What's the difference/better?
  221. Not Starting
  222. New truck prob with mpg's need input
  223. Holiday Wishes
  224. 97 catalytic work on an 03?
  225. front axle
  226. Cylinder head pressure?
  227. T/Rex Steering Box Brace
  228. 05 2500 exhast
  229. 2003 dodge wont start.
  230. 2004.5 dodge cummins?
  231. can you put a 2005 tranny in a 2003
  232. hydro assist steering help??
  233. 2007 5.9 Cummins Diesel voltage
  234. Which tranny should i go with?
  235. Stumped on Exhuast what to do.
  236. Leaking injector line?
  237. 18000mi. since aug
  238. 04 dodge cummins 3500 truck runs for like 10 sec and shuts off i think bad cam sensor
  239. 04 dodge cummins 3500 runs for like 10 sec and shuts off plz help
  240. Catalytic Converter Question
  241. Crankcase Vent Filter Screws
  242. replacement taillights
  243. manual trans
  244. wiring probs
  245. 05 cummins throttle issue,mind of its own!!
  246. Common rail questions
  247. Front End Rebuild Questions
  248. stock intercooler
  249. Problems with 03 Dodge Dually 3500 Cummins
  250. 2003 Dodge 3500 4 Wheel Drive 48 RE Transmission Issues
