PDA
View Full Version : 5.9 Liter CR Dodge Cummins 03-07
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18
  1. Hard Shift When Taking Left Turns?
  2. Banks Six Gun
  3. 13 mpg
  4. 03 Intake air temp
  5. P0148 Code help
  6. rebuilding my 48re
  7. oil pressure sensor
  8. HOW DO YOU GET A 5.9 CUMMINS TURBO TO WHISTLE
  9. Needing a little help
  10. WHICH 5.9 CUMMINS YEAR SHOULD I BUY
  11. 07/Dodge 2500 Tires
  12. Duel mass fly wheel vs Solid fly wheel.
  13. what year to get
  14. Need help..Badly
  15. was told it couldn't be done.
  16. Grid Heater Issues - Any Ideas?
  17. 2004 dodge ram deisel
  18. Whine/Humming noise
  19. Comprehensive Guide To 5.9L Cummins ?
  20. Fuel milage
  21. strange phenomenom
  22. Newb questions about efi, trans ,cp3
  23. CP3
  24. lift pump
  25. steering hiss 911
  26. fuel system problem
  27. what is a good turbo for pulling
  28. second turbo for compounds?
  29. Intake horn and Exhaust manifold questions
  30. Pulling Transmission
  31. Trying to find a cp3 pump upgrade kit
  32. abs and parking brake light on
  33. jpt
  34. grills
  35. looking to buy 06 ram 5.9 Cummins
  36. front tires chirping
  37. Common Rail blow by
  38. Cheap Baldwin PF7977
  39. 2003 stock cummins 6 speed manual
  40. Interior things
  41. 2006 dodge 3500 will not crank
  42. Opinion on Mods for a 2006 3500 5.9L
  43. Grease zerks
  44. Help temp gauge fluctuating
  45. Sick 2006 5.9 cummins
  46. P0299 code...need some ideas....please..
  47. exhaust brake and aftermarket exhaust
  48. leveling kit for 2wd 2006 cummins
  49. Which fuel station to use
  50. Clean up the haze.
  51. Changed fuel filter found something
  52. 2003 5.9 cummins
  53. Which brand Atf4
  54. Pictures of my sprayin bedliner
  55. Squeek when turning off
  56. 04 ram 1500 hemi to cummins swap
  57. 1Lefty1
  58. 04.5 cummins rough idle/rpm shooting
  59. tranny problems
  60. Losing boost and needing help
  61. Help
  62. Xrt Pro Questions
  63. Truck is making a noise
  64. Where to put trans temp gauge sensor
  65. What kind of programmer should I get?
  66. Help me smoke!!!
  67. Driveshaft help
  68. Lift kit?
  69. Conversion to FSO6406A
  70. White smoke at idle
  71. Ranch Hand bumper pics on 2wd
  72. Tow mirrors wind noise
  73. Power steering gear box replaced truck won't turn.
  74. ram air hood?
  75. rain leaks....
  76. Banks tuner
  77. Injectors?
  78. G56 and Transfer case fluid change time
  79. Interior wiring problem
  80. 06 electrical issues!?
  81. Truck wont start / body codes
  82. rough idle
  83. 6 speed problems.
  84. MPG Readings on Overhead Display
  85. New to Diesel
  86. Another Way to Bag It
  87. New Guy Looking for help
  88. Looking for honest opinion on buy a truck
  89. 48re junk, now injector problem?Hey
  90. common rail CC chev swap - front ABS/ VSS issues
  91. Blower motor issues! Help!
  92. need help fast
  93. Need some info
  94. fuel delivery error
  95. Pinion seal leaking
  96. Question on tranny mods
  97. Bully dog gt diesel won't install
  98. Off road lights in fog light holes?
  99. Battery cable melted fuse 42 blown
  100. bird sounds under my truck
  101. idle
  102. BDS Lift Kits
  103. Throttle stiff when in reverse with 48RE
  104. electrical issue's
  105. new injectors
  106. i want 600 to 800 hp
  107. HELP!! PLEASE.
  108. Downshifting/ Irratic throttle- help!
  109. six gun
  110. 05' white smoke and rough idle!
  111. Decreasing power, increasing heat
  112. 2006 Dodge diesel 3500 - grid heater light stays on‏
  113. New to Dodge haveing tranny Probs
  114. DTT
  115. Leveling kit with suspension lift?
  116. 48re 2ng gear engagement arm broken
  117. 05 cummins 2500 4x4
  118. Common rail advice
  119. Odd Howling Noise
  120. downpipe
  121. egt questions
  122. Weekend Project
  123. arp head stud question
  124. code 2607
  125. intermitent ticking in 04.5 cummins help please.
  126. 48re Failure
  127. looking to do some upgrades
  128. swap to g56 from 48
  129. Cant remove shock!
  130. Code P0299
  131. Transmission Help 1st Gear?!
  132. starting problem
  133. Smoke at an Idle...
  134. Tips for removal of old exhaust system?
  135. Exhaust size??
  136. Plasti-Coat
  137. Considering Banks or Afe
  138. Steering wanders a little
  139. Headlight Issues
  140. Better mileage and a little more power
  141. Leveling My Ram
  142. Stanadyne Fuel Treatment
  143. stiff gas pedal dont know why?
  144. high egts
  145. Weird leak?
  146. Mag hytech double deep Trans pan
  147. Many Miles Overhaul 5.9?
  148. 06 5.9 missing at idle, clears up when revved
  149. best mud tire???
  150. high idle gone
  151. fuel gauges?
  152. what programmer are you running???
  153. edge juice w/ attitude
  154. Sounds like a big fan turning on!
  155. Idle Problem
  156. 2003 stock cummins noisy injectors??
  157. 06 2500 mega cab hvac with dual climate?
  158. 2004 cummins ticking at idle
  159. Best year for common rail??
  160. Front lower coil mount....
  161. transmission problems 48RE slippimg and not shifting
  162. 48re tranny please help
  163. abs and brake light on
  164. 2006 5.9 lifespan
  165. injector problems
  166. built cummins HP and Torque guess
  167. ran p2146
  168. turbo questions
  169. weird knocking sound
  170. cummins ISBE 220-30 5.9L
  171. EGT diy
  172. changing ball joints
  173. maybe some of you have ran into this...
  174. to buy or not to buy?
  175. Looking to buy
  176. new engine-no low end power, lousy mpg.
  177. fleece holstett cheetah vs ed 63/68/14
  178. 2005 cummins engine build
  179. Troubleshooting P0628 fuel pump low voltage
  180. ticking noise on 04 cummins normal?
  181. 2005 injectors
  182. biodiesel or WVO? what are you running?
  183. funky throttle
  184. electrical issues
  185. Finally ready to to get my tranny now which one???
  186. 06 horn goes off!!!
  187. 48re letting go?
  188. built 48re help
  189. swap from 48re to 5 or 6 speed help!
  190. Need help
  191. 04 5.9 no fuel peddle after turning off cruise
  192. Strange Noise
  193. Long crank/ no start
  194. fixing to buy a 2005 dodge 5.9 dually help
  195. Lift Pump, Engine Codes: P0628 and P2509
  196. Gear Cover Bolt
  197. Bulldog chip?
  198. Grid heater question.
  199. engine core price??
  200. Sputter question?
  201. turbo question?
  202. 351vgt turbo off a 6.7 cummins
  203. 2004.5 Cummins For Sale Needs To GO!
  204. 03 SWAP electrical issues IPM?
  205. Air Intake System
  206. Still Have Front End Hop
  207. Power Service Diesel Kleen
  208. Shocks
  209. dodge cummins shutting off while driving
  210. 2005 5.9 cummins getting hot at an idle?
  211. over heating at an idle
  212. transmission not shifting
  213. 2004 on 3rd ecm in 6 months
  214. Loses fuel pressure
  215. Trans temp?
  216. Excessive crankcase pressure, rough idle, and some blue smoke. Help!
  217. Need Help
  218. Need to find a good shop in the Omaha/CB area
  219. injector problem?
  220. quadzilla xzillaraider 2
  221. 2003 dodge cummins
  222. Best turbo and fuel system upgrades?
  223. High egt's and coolant temps
  224. P0628 code and other issues.
  225. Auto Trans
  226. Fan Clutch question
  227. Anybody else have slight wobble?
  228. 6 speed to auto swap question
  229. Crank shaft position sensor P0336 HUGE PROBLEM
  230. Bad Vibrations
  231. 2005 2500 Random Power Loss
  232. front end issues (steering, DW)
  233. Temp help
  234. Tuner for cummins
  235. 2003 injector problems follow up report
  236. freeze plug injection pump
  237. Leaking Part Identification
  238. 2004 5.9l help
  239. Soft Clutch after serviced - help!
  240. Fresh 48RE no go
  241. Need rail pressure help
  242. Flash Programmer
  243. Looking @ a 2003 got a few ?'s
  244. 2003 cummins, what mpg should I be seeing?
  245. General 48re question
  246. Battery Connection Issue PLEASE HELP!
  247. is this true hp or just numbers
  248. Leak around injection pump
  249. 06 5.9 starts then dies?
  250. HELP please.Cummins, Powetstroke, or....duramax?
