- qsb5.9-480
- Any brake experts?
- Outlook monitor freezing up???
- Edge cutting out????
- Blower Motor - bad sounds
- DiPricol Rail Pressure Gauge Issues! Anyone else?
- Installing Gauges on the Dimmer Switch
- Technical Questions Quadzilla Scout and Smarty
- PPE Xcelerator
- Granatelli or Quadzilla
- truck engine compartment smells like body odor/onions?!
- would this work??
- Fitting a BHAF on an '06
- need a hand finding nozzles, goin nuts here core charges.........
- detroit air lockers
- Juice w/ Att. vs. Bully Dog TD w/ Crazy Larry
- New truck mods...
- tow/haul mode
- 4x4 idiot light
- Whats your opinion?
- does anybody know about smoke switches
- HELP!!
- wonderin
- Navigation Unit install questions
- camo tanker engine install live!!!!
- Driveshaft Question
- ? on plugging in
- Aftermarket Gauge Questions
- do i have to worry about the airbag?
- oil pressure?
- 03 hard start only when it is cold
- Smarty Junior now with Power on Demand
- OBDII codes
- stock vs. aftermarket lift pump
- quadzilla xillirater II
- new guy needs help
- "Door's Open" horn warning
- 04 1/2 boost/ turbo question
- Blow-by
- New smarty Jr
- truck died
- Slip Yoke
- lowest mileage 04 in the country!
- High EGT Range
- twin trubo ?s
- 2006 fuel pressure and gauge
- Smarty jr
- dialbosport predator
- 2004.5 - 2007 cummins
- Question on fuel pressure
- Road walk
- DOH!
- 30000km with no second gear
- Quadzilla commander update....HELP!
- Power guesses?
- P0524,0148,2123,2121??
- Will these lights really go in the factory location?
- Stuck in second at full throttle
- Stacking Quadzilla Xzillarider 2 w/ Rokk
- code problem
- Cold Starts
- EDGE JUICE WITH ATT.
- Noisy 4 wheel drive
- 06 dodge front end help
- BullyDog PPE STACK
- EFIlive for cummins !
- Install Thermocoupler or not???
- axle wrap
- Key cycling question
- obd2 codes/problems
- 07' 5.9l stock injectors layin around?
- 03 5.9/ 100% stock drivetrain. what to do first?
- Manual shifting question
- Intake options?
- Bigger injectors
- Twin Turbos
- Diagnostic Codes
- 03/04 Intercooler vs 05/08 Intercooler
- Bullydog Torque Management
- Any head porting out there?
- ISB guy looking into a CR
- Injector Failure
- fuse question
- P-O483 CODE ANYONE ELSE HAVE THIS HAPPEN
- tranny
- Code P0573... Is it something to worry about?
- 2004.5 CTD No power and code P0148
- Power Puck, Boost Fooler??
- Pyrometer install
- CHECK YOUR COOLANT
- Intake Question
- fuse #35
- relay box
- NEW MOTOR OBTAINED! (PIX)
- a few questions
- HELP
- difference in CR injectors
- Texas laws exhaust
- 6.7 injection pump
- whats the best synthetic motor oil
- methanol injection install.
- T/C and valve body???
- bad mileage and slight smoke all the time
- Need Pics
- Personal Fuel Economy with EZ
- Help Plz!!!
- Any difference in the 06/07 motors or tranny on the 5.9L
- Which fuel filter to buy?
- Best place to read fuel pressure?
- wanted steel head ache rack
- Oil report for Amsoil 5w30 HDD
- Trans Decision Help
- Check Engine Light came on
- F-1 24v Sportsman Springs
- S&B?
- what is this.??
- good injectors for 06 megacab
- Oil pre filters?
- Need help with bumper
- Tranny fluid change question ?
- Double Deep Tranny pan
- Confused and Need an Expert - Exhaust Question
- Should I Be Worried?
- What Should I Look For In A Truck?
- Smarty Vs. Stock Clutch
- Banks 6 Gun DEAD
- Where Did You Mount Your Brake Controller
- Factory Brake Controller Hook Up
- Looking For An Axle
- Check Engine Light Keeps Coming On
- Looking To Buy An 04 CR
- Make More Smoke?
- Thinking I Need To Send My Cylinder Head In
- Automatic To Manual?
- 12 To 24 Valve
- Idle Stalling
- Bumper Or Bully Dog Programmer?
- Quick Question
- Rough Idle
- Rail Pressure Relief
- Boost Leaks ?
- What Exactly Does This Do??????
- Missing Problems
- The Never Ending Code
- CODE QUESTION
- Exhaust Manifold Port Temps
- Waitin' On Gustav
- Quadzilla Max Mileage
- Boost Codes
- 3rd Gen 1/2 Ton Frame Vs 3/4 Difference? Helper Air Bag Question
- Popping Through Exhaust Running 1400-1800 RPM
- Fuel Filter Question
- Battery Question
- P2609 Issue, Any Ideas Why? 2006
- Any Suggestions
- Driveshaft Question.....
- Common Rail Help.....
- Cleaning Head
- Free Wrecked Dodge/Cummins
- Losing Coolant
- 2006 Dodge Ram 3500 - 766HP Sleeper
- Lift Pump??
- Stacks
- Banks Six Gun
- Tranny Conversion
- Tuner
- Fuel Pressure
- DTC P2121 And P2127
- New Trans. Rebuilt
- Halo Headlights ?
- Stock HORSEPOWER Specification For The 2004.5 / 5.9L HO Cummins
- APPS Adjustment 3rd Gen
- What Would Be A Good Exhaust For My Truck?
- White Smoke From The Exhaust?
- Holley Black Or Carter
- Oil analysis Q's
- Level10 Transmissions
- #1 Injector Line Felt Something Like A Tapping????
- Death Of R Front Steer Tire By Bottle In Road!!
- 3rd Gen Wheels
- Cluster Error Codes
- Lap Top Programs?
- Map
- Overhead Console
- IAT, MAT Or Whatever the Sensor Is Called
- can't seem to find it
- Aftermarket Knowledge
- DIY
- Fass 150/150 kit question?
- What Is This???
- Fuel
- School Me On 3rd Gens
- 2 Cycle Oil In Fuel?
- P0069 & P0073?
- Resealed CP3
- Cupholder?
- P0111
- 05 2500 Problem
- Freak'n Truck!!!
- A/C Question
- Shocks
- Idle Problem
- exhaust brake
- stock lift pump
- Brakes
- Blackstone report
- Valve Bridges
- Key Counts
- Lowrider
- The More I Tow.....
- Clutch Popping noise
- What yall think about biodiesel?
- I'm Breaking Things Again.... G56 Bites The Dust.
- CP3 And The FCA........
- Code Won't Go Away
- Mileage Flash From The Dealer
- Going To Track, Would Like Advice...
- HELP!!!
- High Beams/ Washer Fluid
- Anyone Know?
- Normal Cold Start??
- 5" Straight Pipe 3rd Gen
- Seeking MPG W/ Gear Vendor Overdrive...
- Brake Question?
- New Engine Go BANG BANG RATTLE RATTLE
- Code ?
- Changing Trans Fluid?
- P2509
- Xzillaraider 2 XZT (60hp) And Rokk Timing Sensor
- PacBrake Issues
- 48RE Bands ?
- Pop Testing Injectors
- Confused-Performance Question
- Worth It Or Not?
- G56 Spring Center
- Dodge Transmission
- Optimum Rail Pressure
- Stock 4wd Parts 03 2500
- In Need Of A Motor Bad
- 5 Speed?
- How Big Should I Go
- Rear & Front Axle Capacity
- 2nd Oil Analysis Results....
- Begging For Answers!
- Impossibly Hard To Shift NV5600, Other Times Shifts Fine
- Cool Email
- CP3 Is Leaking
- Rear Axle Seal
- Wierd Problem-Maybe
- Yet Another And Hopefully My Last Clutch Question
