- silencer ring
- smoking at cold start
- help
- Programmers And Stacking
- Truck is at the dealer...
- 05 cummins exhaust what to get
- Very Slow Coolant Leak
- 03 auto
- Headlight Bulbs
- In need of Smarty 4.2 program
- crazy larry
- What to expect from injector nozzles?
- Service Manual...
- Tranny bands
- bully dog help
- In need of advice!!
- Choppy/rough rev down
- yet another mystery vibration!
- Truck Cutting Off And Code P0513
- 03 3500 rear diff issues!
- 03 CR - How to check turbo?...
- Diablosport?
- Bug deflector stolen!
- Removing overhead console thingy
- center support bearing
- 2003 5.9
- Oil Preferences
- Engine
- Anyone Want To Trade Injectors for an '06 Dodge?
- Clunk
- Power steering gearbox help
- Rail pressure
- knock knock
- 2 cycle oil
- ABS light
- oil pan gasket
- Wheel size?
- Cummins Surging and dying
- Fuel milage in the dumps!
- Erratic Tach Operation
- 2003 Ram 3500
- OBDII code
- OBDII code
- How hard to convert
- HVAC troubleshooting
- 48re losing 2nd gear
- Mystery vibration..
- Putting a 12 valve in a 2005??????
- Headlights Dropping or Cutting Out!
- wont start with out ether
- could i be loosing low end cause....
- Tune up, valve lash
- boost pressure
- optimal fuel pressure??
- Flywheel
- Help on Cummins
- hard starting a little
- Installed a new Belt... Squeaks like crazy now~!
- Anybody had this happen to them?
- baro sensor reading
- Valvoline/Cummins Synpower additive
- Installing Water Pump
- Proper Antifreeze?
- Battery Cables?
- click,click,click
- Low Oil Pressure?
- Another Tranny Question
- Noise in my 6sp
- Lift pump or cp3 failure?
- troublecode! helpout a new diesel guy
- 2nd gen camper shell on a 3rd gen
- Tranny
- 2005 Dodge Ram CTD Front Differential Hose
- dtt shift enhancer, blinking
- Dodge Thunder Road
- Cummins strange idle
- How did i do
- TC lockup
- Most definitely could use some help here...
- Hard Starting
- Cummins Motor strength?
- HVAC system Mode Door.
- What kinda axels/gear are in my truck?
- light haze from tail pipe
- My Cummins problem. Need Help!!!
- HELP!!!
- Stupid question about how much smoke these things make stock
- May be Buying 5.9 Cummins
- Question about a code#(10)
- OBD CODES P2127 AND P0483 0N 2004 3500
- block heater for an 03?...
- looking for advice on checking 05 ram 3500 transmission throttle valve actuator
- a breakthrough kinda
- Where Do EGTs Turn Into $$$
- turbo issues
- tranny going out ????
- 2003 Surging
- 3rd gen short box conversion
- Oil Recommendations
- 07 with fuel pressure probs
- Front End Rumble
- Fuel Mileage Wasn't Bad
- Noisey Input Shaft Bearing on 6spd Manual
- Rough Idle +
- Normal fuel pressure
- heavy mesh grill
- Tranny grinding in 5th gear
- Headlight help!
- Bad Vibration possibly Pinion
- How much inlet psi?
- belt issues...
- Going to try to remove injectors myself
- spun a bearing on the turbo?????
- 06 gas to diesel swap
- Cruise cntrl works a min then quits
- Lights for airdam
- 07 quad cab door panel rattle
- Service 4x4 Light
- codes
- thinkin i got trans problems
- Programming Tire Size?
- Need help diagnosing this please!!!!
- early or late model 04?
- Tips for a warm cabin this winter?
- "popping" out of stacks
- Block Heater's Cool(!)
- Studder /Hesitation At Idle
- rusty oil sustance
- Wait to start is staying on forever it seems like
- 48re used wrong trans fluid
- Going to pick up my new truck tomorrow!!
- Dodge Dealer giving me the runaround?? Odd revving..
- Catalytic Converter Removal 04.5
- Head light issues
- dually conversion
- P0192
- Advice Needed
- Need help diagnosing vibration
- edge chip?
- Weird intake noise
- Checked Codes, what next?
- Trouble Code P2059
- abs brake light
- 2003 valve adjustment
- Check your radiator level!!
- Getting Close To the 100,000 Mile Service
- Fuel pressure
- injector question
- Truck smells like vinegar
- Question About SMARTY
- Catalytic Converter with programmer?
- Gauge Issue
- banks big hoss bundle
- Edge w hot studders under medium throttle
- Air Dog stops running?.goto 10micron?...
- Tranny needs to be replaced???
- Engine Questions
- Idle-up is not working
- Transfer Case Blues
- buy or not?
- Need a list....
- Lucas Oil Questions
- New Trans needed
- Motor rebuild :(
- Why are injectors HP #'s different?
- 48RE fluid change
- 48RE TRASHED?????
- Got a quick questions for everyone need some opinions
- Injector clatter/Tranny probs
- Transmission Problems/// A618-48RE 2006
- G56 pain in the butt
- Sun roof seal?
- NV5600 for towing only?
- 03 white smoke
- Power Steering Issues
- Quality balanced by value - Replacement batteries
- Tranny Qestion
- Short throw?
- 10 ply tire problems
- New Pics of the Heater/Collant Filter Bypass
- yet another 48re question thread
- wanting a high idle
- Considering twins
- Input output shaft thinking
- Front axle schematic
- I can't believe it worked!
- Turbo Time!
- cummin diy
- 2wd vs. 4wd
- #4 Injector Line
- smoke switch
- few questions about the 3rd gens, maybe looking at buying one soon...
- code po206
- Transmission Questions
- Clunking and squeeking noise in front end
- Tranny Fluid and engine oil change
- 05 dodge starting problem
- Road tested Air dog
- Literally stuck right now!!!
- Piston Rings Going Out?!
- Short Shifter Kit
- Stacks???
- Stock Radio Interference Problems
- Why is my fuel milage so bad?
- 48RE Transmission problems
- I messed up on my choice, BAD!
- Air dog install 05's and newer Part 1
- Body work to be done....
- power steering hissing
- POWER LIMIT
- Rough Idle, Blue Smoke, Runs Better over 1/4 Tank???
- P0500 code
- drag race times
- winters coming!
- Next upgrades
- dual feed
- got codes
- Need some advice.
- Falling on its face at WOT
- Removing Fan
- new truck and some decent mods
- Low Fuel Pressure???
- What do you guys think?
- Got my Dog
- problem with my 04 dodge 2500 cummins
- towing twins or a good single towing turbo
- how to take off a dashboard for a 2003 dodge 3500
- lowering my 03 2wd dually
- Fiberglass bumper?
- lift pump failed ???
- Do it myself CP3
- Axle seal leaking?
- 03-05 OEM radio?
- ?edge juice w/ attitude?
- Ball Joints
- 2006 dash trim removal - stereo
- 05 dash center trim removal
- AC help on 2006 mega cab
- Help
- injector connector tubes
- 2006 3500 5.9 Cummin's
- Someone please help
- My MPG Compared To Yours
- injection pump
- 2005 dodge 2500 smoke
- Dad bought 2004 Cummins
- Less expensive modification options?
- Need a trans for 06 Dodge
- Edge CTS
- Need to find a 2006 Engine
