- Coolant filter
- Lets see your gauge setups
- 2004 dodge 2500 5.9 wont start
- new truck?
- 5.9 cummins 24v hesitation when accelerating
- brake problem or not
- putting 07 dash in 03?
- Turbo Keeps Shutting Off - WHAT!
- >>>PLEASE READ BEFORE POSTING<<<
- Looking for my first diesel, test drive tomorrow.
- Trani questions??
- awesome no OD
- Extremely Weird Electrical Issue
- oil pans
- Abs 2003 dodge ram cummins
- Just bought an 06
- still smoken
- 3 injection event
- 06 steering pump bracket failure
- lots of questions
- Find out why they are called stealerships this morning.....
- Auto to manual swap.
- Fuel rail pressure sensor?
- Shocks?!?!?!?!
- 05 cr having all sorts of problems Help please
- 2003 cummins help!
- Indicated milage VS actual?
- 03 ctd 6 speed?
- APPS
- Holset Turbo Help
- motor nosie
- poker game
- ? To much boost
- 5.9
- 04 2500 code issue help please
- throttle position sensor
- No oil on the dipstick
- 2004 24 valve cummins hard starting
- whats ur rpms when running 70mph
- 05 needs help
- Some questions about an 04
- Dodge bounces at 60+
- 12v p-pump in 2005 HELP!!!
- front end u joints
- 06 5.9L Down cylinder?
- New Member, Got a Question
- 06 cummins ac problem....
- CB install
- blowing power stearing pump help!!!!!!
- HOAT coolant??
- How do I bypass heat Exchanger on trans
- '03 CR waterpump replacement questions
- good deal?
- 04.5 cummins
- cam bus problem.
- '03-'05 Engine Replacement Trend?
- STOP SMOKE
- i think my valves are ticking???
- whats the best year between 03 to 07
- Stick shift
- 2005 DODGE RAM SHOULD I BUY??
- Need Advice
- Weird A/C Issue
- Ohm Tested My Injectors
- New Truck High Miles
- 03 cummins wont start need help!!!!!
- Wiring Help
- cp3
- 03 dodge 3500 5.9 diesel
- 48RE transmission questions
- new wheels
- Found my transmission overheating issue.... 48RE running Hot?
- Tranny Swap
- My First Diesel Truck. Have a few questions?
- truck is acting funny.
- How much smoke
- Got a Few Questions
- Dang it!
- Life and Death
- Wait to Start indicator stays lit
- WTF
- 05 cummins need a lil help
- trouble code after installing APPS Noise Isolator
- 05 cummins white smoke, missing, poping
- Air Sensor
- mileage up and down
- 2005 ram 2500 cummins in need of help!!
- Inconsistant Idle
- Want to switch my new 06 5.9 to better oil
- remove the airbox
- 07 5.9 cummins
- confused about injectors
- maximum egt
- Lift pump replacement/upgrade
- John Deere (RDO Equipment) Billings, MT
- Fuel Additives
- Need help with staking
- Engine Light On but No Codes
- Trany upgrade
- Something is off with my '05
- Loosing performance and fuel milage.
- Good Highway Rib Tires?
- 03 Cummins
- Died, no start and no fuel to the rail?
- check out my truck video... what you think?
- 2003 Ram 2500 Should I buy???
- what causes death woble
- front clip swap????
- 05 questions
- Sensor found loose laying on the turbo?
- Another question
- Just a newbie
- Need Help! Lost.
- fire wall insulation almost caught fire WTF!!!!!!
- Broken Clip
- Poor Throttle Response
- Brake controller info
- Tan Vent Visors???
- smarty and Powermax
- Battery go boom!...
- need to do brakes is there any upgrades
- Airdog 150 problems
- What programmer should I get
- 03 cummins help
- looking to buy a 06 or 07, what to look out for
- Steering shot! Can I replace this?
- Smarty ssr or smarty s06 pod?
- Secondary Cooling
- Black fuel filter
- Power woes
- looking for core
- Which chip for 2004.5
- does anybody have a 6in air filter
- 05 Dodge Ram 2500 5.9 Electrical Problems
- Cheapest 5" exhaust???
- Won't build turbo boost
- Educate me: New to the 3rd gen
- A Jingle thats driving me crazy!
- Tranny Flush???
- buying!!! need info
- tranny trouble need help!!!!
- HE351 turbo in an '03
- Fuel Filter Bowl Tube
- 05 cummins not running good
- 2WD 2 inch lift
- 06 turbo on an 04?
- playing in the mud and.....
- can i get a 06 remote key for my 05.
- difference between 48re and 618
- Engine Temperature Issue
- Surge from 1st to 2nd
- To upgrade or not.
- Wheel question
- 07' cummins thinking about buying.
- Mid intake tube replacement?
- pcm code P0720 trans stuck in second gear?
- 06 dying for no reason
- 48RE Shift Kit Opinions?
- hi all pice of 3rd gen wheels painted or powdercoated
- Problem with ECM 2005
- Tires
- Turbo Play?
- rattle type motor noise
- silencer ring
- HELP MAYBE STRANDED 48RE MORE PROBLEMS
- Simple Dually to Single Conversion Questions?
- Too much turbo?
- 48RE 2-3 flare shift
- 06 Ram A/C Compressor
- Best bang for the buck
- TRUCK PULLS IN SOUTH WEST IN
- Another One Bites the dust
- Transmission trouble shifting into 2nd gear
- Clicking in Reverse
- Whats your best MPG?
- Heavy 39' 5'er on '05 2500~Any advise?
- Crazy larry for my 03
- dually fenders
- Towing engine temps.?
- 04 dash noise
- new guy, new to me diesel, here to learn
- Front U joint Needs replacing
- COOLANT?
- Really Need Help!!!!!
- Fan clutch wiring PLEASE HELP
- Intake Manifold-Paint?
- New Truck?
- A/C Problems
- 2005 dodge 2500 cummins stalls at idle
- head gasket question!
- 2003 cummins head gasket????
- poll on death wobble
- G56 Trans Fluid
- how do you check fuel pump and lift pump
- cummins died and wont start please help
- 04 turn sig circuit help
- bad fuel/ fuel pump or something else
- De-fueling problem
- Dead Cylinder!!!
- h&s for 5.9
- Trans mounting tricks
- Fuel line leak from pump to rail
- new truck
- front axle leak
- Need some help
- bad FCA??
- Valve adjustment?
- Resetting TIPM for blown headlight?
- Current Dmax owner might switch to Cummins
- Towing & High HP w/ Electric Fans?
- P0868
- Are my injectors going bad?
- 2003, 5.9 Overheats at 70mph
- Rebuilding Totaled Truck ~ Lots of Pics!!!
- Dodge with a blown Cummins
- Cummins rock!
- Loping and worse milage
- battery going bad?
- Diesel Prices.
- Twins?
- Fixin to get an 03
- 04 cummins loses rail psi when normal temps are reached
- Bypassing heater core and a/c problems
- Got a 03 2500 yesterday...
- buyin a diff truck
- Softopper??
- 2004 CR 235HP
- What are symptoms of a bad fca?
- Lopy idle?
- No start
- Crack?
- 2007 2500
- 8 lug 2500
- 48re problem need help!!
- Mileage doesnt seem right??
- Beep
- 2006 5.9 cummins fuel preasure problems
- PARTS MANUAL OR CD 2004 5.9
- Want to get a CR
- good tranny shop in tn
- EGT's
- P0088
- Power Problem....
- exhaust brake problem
- Engine RPM help?
- 2006 5.9 cummins
- Cummins Lope
- 48re rebuild
- New purchase 2004 Cummins - dead pedal
- weight pulling
