PDA
View Full Version : 5.9 Liter CR Dodge Cummins 03-07
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18
  1. 800 to 850 hp??
  2. Operating temp
  3. Smoking cylinder 6
  4. bully dog power pup?
  5. Edge problem
  6. Smarty or Diablo
  7. Wait to start light won't go off
  8. new trans ideas
  9. can you put different nozzles on stock injectors?
  10. fuel delivery issue?
  11. g56 wont go into gear sometimes
  12. Occasional Hard Start
  13. Which aftermarket CP3?
  14. whats the best 2.6 turbo
  15. New to Cummins
  16. 2006 5.9 Litre
  17. TRANS Not responding
  18. School bus Cummins
  19. 2005 ram 3500 277000 miles whats the best programmer for fuel milage
  20. Just got my Smarty
  21. dual wheel tire rub
  22. 06 smoker
  23. bought junk
  24. 2003 cummins random white smoke
  25. Will 04 ranchhand fit 06
  26. Need help with diagnosing steering problem
  27. question about airdog kits
  28. 5.9 to 6.7 Intake swap
  29. newbie question
  30. Batteries dead on demand
  31. 03 To buy or not?
  32. Death wobble on my cummins
  33. STARTING ISSUE 2003 cummins
  34. Cummins hates rain
  35. will not start below 40 unless plugged in
  36. overdrive and tc lockup noise
  37. Fummins
  38. Couple question's
  39. 04.5 cummin HO 6spd horrible mileage?
  40. dash codes
  41. help
  42. 06 Cummins Problems
  43. 271 assembly torque
  44. mirror heat
  45. smoking
  46. NV271D transfercase help
  47. Problems With AutoMeter Phantom Boost Gauge
  48. Steering brace - info
  49. Best turbo?
  50. P0243 Fault Help
  51. Engine cutting out, similar to a rev limiter, but low RPM's & high-rapid EGT Spikes.
  52. Attn Snow Plowers:
  53. rough country
  54. rp/po483 fan code. truck feels slugish
  55. need help on getting a 03 cummins
  56. star wheel
  57. leaking antifreeze
  58. need some help plz
  59. NV5600 input shaft
  60. pitman arm
  61. Cp3 upgrade
  62. 2003 Cummins Smarty S-06 with.....
  63. "Wait to Start" light
  64. sold my truck
  65. Going down the road my truck just dies out
  66. looking for new truck
  67. WON'T START PLEASE READ !!
  68. quadzilla boost fooler and bullydog gt
  69. cleaning injectors
  70. transmission upgrade???
  71. 04.5 Ram 2500 6sp
  72. bad morning starts
  73. lift kit
  74. No heat coming out
  75. tranny fluid leak
  76. fuel filter
  77. Ideal hwy rpm
  78. DIFF RATIO
  79. 1st issue in 250,000 miles!
  80. Smoke is getting worse
  81. FILTER
  82. newbie question
  83. 2004.5 Does ECM Re-Flash reset the TPS???
  84. Heater blowing hot, cold, hot
  85. help 2004.5 no power
  86. Those with Maxx Link sway bar ends...
  87. auto to a 6spd
  88. support bearing replaced and still having problems
  89. Injection rejection
  90. New cummins
  91. Going to look at an 06 mega cab
  92. cummins on the highway
  93. exhaust
  94. seat belt reminder ????
  95. Whit smoke
  96. 2004 Cummins Dually
  97. tranny problems
  98. AIR BAG LIGHT HELP
  99. What would you guys think this truck is worth?
  100. Truck do random CHUG , HELP!!!
  101. Batteries bad / both tops blew off on 1 battery
  102. stock 24 valve cummins
  103. Best years to look for?
  104. high pressure
  105. Problems please help
  106. Cummins runs rough at 1800 rpm
  107. Truck not running right
  108. 2003 Not Starting Cold
  109. exhaust???
  110. 06 radio nav unit ?
  111. Code 78 and Brake Light On ((!)), No ABS Light, Just Brake Light On
  112. 03 cummins 5.9l
  113. Dash mat
  114. Vibrating Front End
  115. New injectors
  116. INJECTOR QUESTION
  117. 2006 white smoke at idle
  118. NV 5600
  119. Surging
  120. 05 noise
  121. radio acting wierd
  122. leak from Transmission (NV5600)
  123. Tranny tube broke. Need a new one...anyone have one?
  124. 04 Dodge Starting Hard
  125. 04 turbo
  126. Rear Door Harness problem....
  127. 2004 Cummins stalling and skips when cold
  128. 48re acts like neutral in drive
  129. tranny rebuild problems need help quick
  130. Rear Axle= MPG?
  131. Injector removal
  132. need help truck wont start
  133. Ticking noise? 04.5
  134. traction bars
  135. NEW BALL JOINT PROBLEMS
  136. HELP ME WITH NEW TIRES!!!!
  137. Airbox
  138. 2006 3500 Auto Trans Upshift slipping...
  139. Edge from 05 compatable with my 03?
  140. Buying 2004 Dodge Ram 3500 Could use some advice?
  141. dash crack
  142. Storage Questions
  143. Horrible fuel mileage
  144. 04' 2500 crew cab short bed
  145. Need Head!
  146. 2003 Dodge Cummins MPG
  147. Routine Maintenance NV5600
  148. fuel injector pressure
  149. clutch noise?
  150. HELP!!!!!!!!!
  151. 02' Front & rear Diffs in a 05' ?
  152. Bad MPGs Question
  153. No power
  154. electrical gremlins
  155. Any one elses truck do this?
  156. Please help me
  157. Please help mw
  158. 04.5 cummins
  159. Weird Problems at 2000 RPM
  160. Overboost code
  161. need reviews
  162. What Is This????
  163. Overdrive problems.
  164. Need opinions
  165. White smoke rough idle?
  166. 03 fueling issues
  167. codes and questions
  168. 2003 ISB 250/47re replacement Qs
  169. injector Questions!!!
  170. P0069
  171. 2001 5.9L or 2004 5.9L?
  172. 2004 5.9 cummins, 204k miles?
  173. another turbo question
  174. 06 door open interior lights ?
  175. Has any experienced excess fuel intake?
  176. possible new truck
  177. No power/ no boost
  178. RECALL
  179. 04 abs issue
  180. 05 Auto to manual swap cost.
  181. shuting down?
  182. Hard starting when facing uphill
  183. Need help
  184. P 2509 need help
  185. 2007 Dodge Cummins with junky auto
  186. Just bought my first diesel (pickup that is)
  187. Will all 5.9 24valve blocks interchange?
  188. 04 is storing a bunch of codes
  189. Oh boy.. where do i start?
  190. Please help newbie
  191. 03 Hard start, rough idle
  192. Why did this happen? 03 cummins
  193. Oil Drain (Turbo)
  194. Looking for some insight
  195. guy complaining about is 03
  196. Fuel Filter
  197. Some one tried to steal my truck!
  198. p0837 code fix
  199. 03 Commonrail auto trans.
  200. dually torque specs for the roter to hub
  201. Need help!
  202. 2004 24V Engine Blown
  203. Rear Pinion Seal Leak
  204. Throttle Position Sensor Location
  205. engine temp running hot.
  206. 2nd cummins
  207. 03 Dodge looses power when warm
  208. losing brake pressure
  209. Can i run it?
  210. Cummins not starting?
  211. Bad Engine? 6.7 ltr Cummins
  212. what are yall guys running and why
  213. front bumper air dam
  214. charging issue maybe????
  215. loss of power? ????????
  216. cheap mods?
  217. 2005 Dodge Rear axle leak
  218. help 911
  219. any way to eliminate the engine management computer
  220. 05 cr in my f250 what ya think, help
  221. Fuel issue ?
  222. NEED HELP with ac compressor
  223. Thinking about buying my first Cummins
  224. Severe Wobble
  225. Need some info on the stock turbo, engine and trans?
  226. Grid Heater randomly coming on.
  227. UGH! My truck is doing it again!
  228. marine son home from deployment wants a cummins
  229. better milage
  230. Finally running strong
  231. Electrical Issues
  232. fueling?
  233. 05' engine noise
  234. What to do next?
  235. Looking for a new Cummins Engine for my truck
  236. need tranny help
  237. Possible new member of cummins world. Advice please
  238. 04 engine rust
  239. Blew up the 06
  240. stock wastegate
  241. G56 noise!
  242. turbo question
  243. First mechanical breakdown
  244. Transfer case replacement or rebuild
  245. Turbo Problem..I think
  246. Need some help with T Case or Possibly Front Differential
  247. p2146 code
  248. Need Advice
  249. clutch?
  250. whats the best tires
