- Possible front differential trouble...help
- running the rack on 6.7s
- Tranny help
- t case oil
- Injector Nozzles or Smarty Tuner
- Intake manifold
- anyone stacking?
- 08 BHAF??
- Best price on ARP 625 head studs?
- Best Price??
- Front End???
- 6.7 Turbo Suggestions
- egt probe?
- tradin
- Smoke?
- Turbo troubles
- electric 4 wheel drive
- Intakes
- Smoke ????
- auto trans
- Need Some Advise!!!!!
- SMARTY JR ?
- Delete Question
- egt delete
- My 08 6.7
- 6.7L with a Smarty Jr. throwing egt codes.
- Console swapping
- Gauges
- Delete or not?
- Fuel Rail Pressure "How much is too much"
- clutch opions
- Torque converter cooked?
- 6.7 no boost or exhaust brake Please Help
- air bags
- "To shim or plug, that is the question"
- Emissions Problems?
- I have a 2007 6.7 need help with
- EGR Code
- Smarty TNT question
- "Perform Service"
- Slow acceleration for my 2011????????
- 6.7 Mpgs
- engine temp above normal????
- 2010 with the check engine light on already, WTF?
- Mileage Change
- G-56
- just got a 08 6.7 need help
- 2011 ram breakin info needed
- Looking at an 07 6.7 Questions
- Front End
- 2011 2500
- Valves starting to rattle
- Just got my 6.7
- Make driveable in Central America
- please help on 6.7 new!
- Waving the white flag on 2008 6.7L
- boost question
- 2008 Dodge Ram 3500 Mega Cab 6.7
- Odd Turbo Noise
- lets see all these 6.7s
- Wheel hop.
- turbo spooling up or clutch?
- Considering New 2011 Dodge 3500
- Shackle Question
- 09 trailer brake control
- regen
- P2509
- Front end work.
- Regen
- Just installed rebuilt engine and Here are all my codes. It will run on shot of WD40
- Turbo Cool Down
- What is 6.7 Code U010C
- I took a 4 hour trip yesterday.. heard a odd noise...
- Diesel Smell
- Does my grid heater look better?
- Pics of a 5.9 and a 6.7 injector side by side
- A few pics of a 6.7 and a 5.9 head gasket side by side
- 2010 cummins help please
- Revisiting an older post
- Hate my truck
- Pics of Rebuilding My 08 6.7 engine
- Possible brake issue??
- hmm something is wrong
- manual or auto
- 6.7 cummins regular cab shortbed
- MPG
- 2008 3500 calling for dealer cleaning
- 2011 ram 3500
- White Smoke
- are dpf the answer
- Brake Light
- 2008 Cummins 6.7 info on swap to 5.9
- Question for a FRIEND
- Gear Ratio??
- Opinion on salvage titled 6.7.
- front axle u-joints
- throttle valve butterfly screws
- Wheres the best place to buy 08 6.7 rebuild kit?
- Here is a pic of how to kill your 6.7 dead!!!
- I found out why my 08 6.7 is dead
- bodyshop
- 08 ram 3500 can you swap a bad 6.7 with 06 5.9
- EGR Circuit
- 2008 ram 3500 6.7 bad engine. Who has a wrecked truck?
- can i run smarty tnt software?!?!?
- 08 Cummins 6.7 wont turn over. Starter? Engine?
- help-diagnose vibration
- water in fuel light coming on.
- A good Reason to Own A Dodge
- Rerouting exhaust outside frame
- What next?
- Jake Brake
- bents valves
- Which Trac Bar
- TC lock up question
- 6.7 wont start
- Adding 2 stroke to a 6.7 good or bad?
- cel cylinder missfire
- What size?
- Warranty Question
- 2010-2011 dodge 6.7 cummins?
- Overhead Computer Problems
- brakes hissing going down the road
- Need a clue
- Stock Tranny
- looking at 6.7s
- best engine oil out there for 6.7
- abs/brake light coming on under a lug
- Death wobble
- Strange Vibration
- Four wheel drive not working
- same problem as 07 flatbed
- Problem, appreciate some info
- 2010 crew cab how much room?
- 6.7 problem
- A/C Question
- Hard Down shift
- HELP Engine running strange
- Raced my truck today
- 5.9/6.7 swap
- New Gear
- VGT
- Dyno numbers
- shop manual
- DTC#1--P1507
- What kind of numbers?
- If someone can answer this I will really be impressed
- P0488
- gauge cluster light change
- 68RFE vs AS68RC Transmission
- 2011 3500 c/c
- TRANS TEMP???
- Defueling??????/
- What's it worth??
- How to take off speed limiter
- MPG QUESTION
- 6.7 trannsmision
- do i need the air temp sensor?
- heated seats don't work
- P0601
- Engine light.
- exhaust question
- Fuel problem
- 2008 6.7 no high idle
- high idle
- coolant system
- 3500 ?
- Thermostat
- High idle with E-brake
- 2010 6.7L computer ECM upgrade????
- u-joints
- Blown Tranny!! What to do??
- Help Needed!!!!!!!!!!!
- 2wd Tire Question
- Light Load Button
- p2509
- cylinder #4 misfire
- 6.7 over boosting
- exhaust emissions?!?!?!?!
- Egr/ Cooler delete
- cel 2609
- 2008 6.7 Alternator ?
- Tranny Help, Please!
- Disable seat belt chime?
- coolant problems....
- Motor Knocking
- Boost Fooler
- Problems with 2008 6.7
- Wheel Hop
- 2010 3500 srw
- 6.7l wastegate
- VGT turbo
- egr bypass parts.....broke
- New to 6.7 question
- 2011 DODGE QUESTIONS
- Cant find cause of shutter
- 07 6.7 shuttering at 1200 rpm
- Best RPM for Mileage
- .99 cent DPF Delete
- did deletes on 07 today
- Gauges
- MP8 Good or Bad
- Tuner?
- Building a 2010 6.7L Injector???
- regeneration
- 09 Cummins 6.7L ***ENGINE LIGHT****
- thinkin bout a new truck
- Help! Mass Comm loss from EGR, TURBO, O2, and Throttle
- lots of box's THX's Diesel Dawgs
- bad diesel
- Next mod
- Excide battery question, center post location
- 07 6.7 cummins with a P2563 code
- PERFORM SERVICE
- Recall problems....
- yellow engine light
- is this normal smoke
- Low Tire Pressure Light
- mega cab exhaust
- Needing Info for the DPF and EGR delete with Smarty tuner
- 2nd Gen exhaust manifold on a 6.7?
- need help!!
- DPF/EGR delete 6.7
- Weird Smarty POD reaction today..
- Duramax Owner needing Cummins Lube Info.
- What helps make power up top?
- HOW TO GET BETTER BOTTOM END ON 6.7
- Tire Questions
- Leveling Kit??
- Exhaust brake problems
- 08 6.7 exhaust question
- What's What On the Exhaust??
- new 68 RFE noises with new torque
- Upgrading to 19.5 tires
- Exhaust Questions
- 6.7L Cummins Larger Capacity Radiator
- lookin at getting a 6.7
- engin code ? 6.7 cummins
- "Brake" light flashing???
- just startin out need some help
- lovefab
- bad cylinder head casting for early 6.7s
- In CA. what mods can be done?
- Need Some Advice Please
- exhaust brake
- 2010 Mega Cab Rear A/C Vent?
- Mega cab year choice
- b&w hitch mega cab
- Advice wanted.
- Lifted truck with a gooseneck
