PDA
View Full Version : 6.7 Liter Dodge Cummins 07.5-12
Pages : 1 [2] 3 4 5 6 7
  1. rear end help please!!!
  2. 6.7 dpf delete "see dealership code"
  3. Efi live question
  4. OOOO Blue smoke
  5. 08 cummins big hoss
  6. Dpf issues
  7. 5" Turbo-Back Exhaust Question
  8. 2010 Cummins smoke switch
  9. Bungs or no bungs that is the question
  10. Banks cold air intake
  11. This is one BIG reason to do deletes
  12. 08 Dodge 2500 new to me :)
  13. True or not?
  14. Exhaust help
  15. 2011 2500 delete help
  16. looking to buy 2012 Ram 6.7 Cummins
  17. cluthch for a 08 2500
  18. Getting a delete pipe...
  19. 2007 and a half 6.7 Cummins
  20. for sale 2007 cummins 6 speed 59kmiles
  21. EFI LIVE anyone know how to turn off dpf,....
  22. anyone in Illinois?
  23. Smoke switch install
  24. Lose power when under load/headwind
  25. 07.5 6.7 fell on its face ?
  26. royal purple gear oil
  27. 2009 6.7 cummins egr
  28. I dont know whats going on
  29. Need some info on 08 6.7
  30. to compound or not?
  31. will my truck pass smog in california?
  32. TS Performance Stryker modual
  33. pressure relief valve uncertanty
  34. Coolant temp
  35. EGR/DPF Delete in states that require it must read
  36. Help! Truck turns over but wont start
  37. ccv breather kit
  38. smoke switch
  39. g56 to nv5600 conversion
  40. Revs up when hits idle
  41. Lift kit = poor mileage
  42. Help Diagnosing check engine light
  43. What clutch set up to run?
  44. 07 dodge 3500 brakes locking up
  45. Suspension lift kits
  46. Low fuel rail pressure 2012 6.7 cummins
  47. Bad fuel Replaced everything NO Start
  48. Jerking from a miss
  49. Engine light
  50. 35's on a 2012 2500 4x4
  51. Radiator Removal
  52. Rearend Rebuild
  53. A little black smoke
  54. grid heater thingy
  55. clutch thoughts
  56. turbo down pipe to stack kit length ?
  57. Noob Question
  58. 2010 Dodge 6.7 shifting
  59. grid heater
  60. H&S MCC programing
  61. exhaust brake info
  62. 2009 ram 3500
  63. new ball joints axle u joints and hubs help!
  64. Uconnect
  65. Air in coolant and over heating
  66. 6.7 cummins boost drop
  67. fuel upgrade
  68. Rear tires. Funny wear pattern
  69. weak sauce..
  70. 6.7 engine error code
  71. torque spec rear pinion nut ?
  72. 07.5 vgt turbo and fleece standalone controller
  73. how can you check for block warp
  74. new truck 2012
  75. Need some noise
  76. Sputtering
  77. emulators or programmer?
  78. looking at a 2011
  79. g56 cracked by starter
  80. selling my smarty S69 and looking for smarty jrME
  81. Smarty/deletes Need some help please
  82. Head jewelery
  83. what tuner/chip is best for mpgs
  84. Tranny help
  85. 08 cummins
  86. thinking about upgrading
  87. p0473 help
  88. 2009 Ram 2500 Power locks INOP
  89. Best tuner for 6.7
  90. 08 850+ hp 1200+ ftlbs torque
  91. Ring and Pinion gears
  92. 6.7 injector nozzles
  93. New to this site and lookin for 6.7 knowledge
  94. EFI Tuning DFW Area
  95. EGR/DPF delete
  96. Anyone got a clear answer on how to fix the "death wobble"
  97. Hissing noise from brakes
  98. Not a very good mechanic but a great veterinarian
  99. 2014 Ram 3500 pinched wire 20 miles
  100. 2009 cummins
  101. 2009 cummins
  102. looking into buying a 2008 6.7
  103. 2011 2500 6.7L deleted cooling system issues
  104. 2014 cummins parts
  105. Dpf delete
  106. Need help with my 08 6.7 mega cab
  107. Cummins 6.7L FTP-75 drive cycle test results
  108. Decoded.
  109. Great buy on a 6.7 Cummins
  110. Smarty Jr Junior ME Tuner Dodge Cummins 2007.5-2012 6.7L DPF EGR CAT Delete
  111. Power-Play MP8
  112. Code?
  113. what too look for
  114. Want put in HID lights on my 2011 dodge 3500 Cummins.
  115. questions when buying a custom tuned truck
  116. 2014 RAM 2500 DIESEL FUEL ECONOMY
  117. Smarty Jr. DPF,EGR KIT
  118. Need some advice efi live
  119. How are the 6.7 trucks?
  120. Sensors on the air filter box
  121. DPF/ EGR delete
  122. 6.7 automatic will not manually shift
  123. Egr delete
  124. 2010 2500 6.7 with code P2609...HELP!!!
  125. Aisin 6 speed automatic opinions ?
  126. Custom Diesel reviews?
  127. New truck! Need help!
  128. Help on choosing a transmission
  129. Need advice about 1 ton diesel - dodge
  130. Since I'm new....
  131. Why I bought my new 2014 2500 Cummins
  132. 2G Man. Swap vs Compound setup
  133. Smoker switch on 2012 cummins is it possible
  134. Crazy emmission issues
  135. spade tuner
  136. Need to reset oil change message.
  137. Cooler Delete Hose
  138. Smarty jr me files
  139. Grid heater cord?
  140. For those of you who may not have recieved the recall
  141. New help ASAP
  142. Intake manifold ?
  143. Side Exhaust
  144. odometer readings!
  145. 2012 Ram 2500 6.7 best options.
  146. 2008 6.7L Won't start
  147. Best tuner for stock 2010 2500 CUMMINS
  148. WTT smarty sr67me for something less agressive
  149. From H&S MCC to EFILive
  150. Custom tuning???
  151. 09 cummins
  152. 6.7 dead.. NEED HELP NOW please..6
  153. New '13 2500 6.7 Questions
  154. Help Programmer or No Prorammer
  155. Transfer case stuck in neutral...?
  156. Bone stock 08 6.7 with 68000 miles limp mode question
  157. can not see
  158. Exhaust Make
  159. Delete
  160. DEF on 2012 3500?
  161. Bullydog GT Mileage Improvement???
  162. Deleted EFILIVE additional tuning/trans
  163. Transmission ASAP !!!!
  164. Voltage Gauge Problems
  165. ABS Sensor
  166. mileage and power
  167. 6.7 cummins deletes
  168. 68rfe pan gasket
  169. Engine light and codes
  170. How can I quiet down my exhaust whistle?
  171. Tailgate Wiring Connector
  172. aftermarket turbo question
  173. Atf blowing out dipstick, gear hunting, pushing thru breaks at stop
  174. 6.7 dodge 3/4 ton Drive train upgrade question
  175. Help
  176. 6.7 dodge cummins
  177. .99cent DPF Delete?
  178. dpf delete tuner ?
  179. Exhaust brake missing
  180. New guy what tuner is for me?
  181. Head light issue
  182. How to install 2012 6.7 cummins smoke switch
  183. What next?
  184. P003A DTC and No Exhaust Break
  185. broken rocker arm
  186. 0w40 oil year round?
  187. vin 8th digit question
  188. Used Upgrades
  189. Boost Fooler
  190. smarty tuner question
  191. regen/dpf ?
  192. Need Some Buying Advice for a Newbie
  193. 68 rfe 6.7 ram
  194. tranny
  195. FORD 6.7 / Cummins 6.7 /Duramax 6.6
  196. Lope tune?
  197. 6.7L Kills after 20 min of running
  198. Dash Lights and Dome Lights dont work
  199. Need Help
  200. 07.5 cummins 6.7 ltr generator voltage sense high?
  201. Tranny limp mode!
  202. Valair or South Bend
  203. g56
  204. Need Help
  205. 08 6.7 over head displey reset???
  206. 2011 ram 3500 low trans fluid issue plz help!!'
  207. White smoke
  208. 6.7 Cummins he351ve vgt warped and leaking oil
  209. 5.9 vs 6.7
  210. 2012 tratction control disable??
  211. Another headgasket
  212. Pusher intake = less boost than stock!
  213. EFI Live Tuning Help
  214. Just buy a 6.7 or buy hemi to do 5.9 swap?
  215. Any ideas on dpf delete
  216. Etc light while towing
  217. high idle
  218. po420 cat efficiency Bank 1 code
  219. 07.5 EGR Delete vs EGR Disable
  220. MBRP down pipe ....very happy
  221. 03-06 OR 07+?
  222. Help dnt know what's wrong
  223. 2008 ac help
  224. Is it posssible that I don't have a block heater?
  225. help!!asap valve lash adjustment not working for me!!
  226. injector question
  227. Random black smoke stock truck
  228. Shift kit...
  229. suggestion for EFI reseller?
  230. 2010 truck w/g56 manuel
  231. Big MPG Gain
  232. downpipe
  233. 08 ram 6.7 w/ dpf delete and us smarty s-67.. stuck in limp mode
  234. NC Inspection
  235. NC Inspection
  236. Transmission build
  237. dtcs p063c p031c and check gauges???
  238. aftermarket fuel pump
  239. turbo change
  240. 4th turbo on 2007.5 2500 and still in limp mode
  241. smarty mads or h&s mini maxxx 2012 6.7 cummins
  242. Transmission problem
  243. Cam shaft?
  244. AC Bypass??
  245. 4" or 5" Exhaust
  246. head gasket blown need reputable mechanic it Austin tx
  247. Extended Warranty?
  248. 2011 6.7L DPF delete HELP
  249. Efi live
  250. stack question
