View Full Version : Ford Powerstroke 03-07 6.0L
Pages : [1] 2 3 4 5 6 7 8
  1. i did it...like i said i would!
  2. She died!!
  3. Replaced STC fitting now hard to crank
  4. Long violent shifts
  5. arp headstuds
  6. diesel meet or car club in so cal?
  7. Water in Fuel light
  8. Review XDP coolant filter
  9. Powerstroke Blues
  10. Cummins swap
  11. Faint Smoke
  12. Sinister coolant filter
  13. Cummins Swap
  14. New oil cooler
  15. taxes came in getting windows tinted and hids
  16. Edge juice with attitude keeps turning off and on constantly
  17. SCT Livewire tunes
  18. programmers
  19. Tuner and guages for Ford 6.0?
  20. 2004 F250 turbocharger...
  21. wont start cold
  22. no lights high or low
  23. 6.0 glow plug harness leak fix. Removal and installation with photos.
  24. help ac oil
  25. 2005 ford f350 6.0 no start
  26. CEL after adding Coolant Filter
  27. SLOW TAKE OFFS?
  28. 13 mpg need to do better
  29. Injectors
  30. Brakes
  31. 6" lift?
  32. newb question
  33. '07/8 mirror hybrid?
  34. Yea I dropped the ball
  35. Decided to keep
  36. 6.4 help
  37. practice What You Preach
  38. Woops
  39. 2004 6.0 belt??
  40. straight pipes
  41. EGR check engine light??? sensor or cooler??
  42. how to remove door panels to fix widow motor
  43. Speedometer not working
  44. 05 f250 speakers
  45. Sale price?
  46. removing radiator?
  47. Oil cooler re-location
  48. 06 6.0L Completely shutting down around 40mph
  49. smoke smell
  50. egr valve?
  51. 05 hard start when warm
  52. Broken injector
  53. difference between powermax turbo and stock
  54. back up camera?
  55. BIG OIL LEAK
  56. Help
  57. info please
  58. lift kit
  59. Wicked Wheel on 07 6.0?
  60. Anybody like this EGR delete kit?
  61. 2 cracked heads
  62. Help please
  63. Prog. Question
  64. transmission troubles.
  65. SCT tuners
  66. egr delete
  67. Labor difference between bulletproof kits?
  68. Rear End or rear Axle going out!!!???? I'm 2000 miles from home!
  69. Bad injector???
  70. Friend just bought an 03 6.0
  71. High egts
  72. Help!! Is this a glow plug harness leak?? Photos included
  73. head swap
  74. NOW WHAT??
  75. 2005 F-250 6.0l 6-speed Hanging revs between shifts
  76. What needs to be done?
  77. Boost pressure loss after hg and studs
  78. 2004 6.0 fuel pump issue
  79. DIY water injection installation on the 2004' 6.0. Photos. Youtube.
  80. 6.0 snow performance
  81. Boost leak/oil spray
  82. Oil & Coolant Bypass under the hood
  83. remove ac compressor
  84. 6.0 rough start and rough Idle
  85. Coolant filter kit
  86. Popping sound
  87. tuner question
  88. egr cooler vs delete questions
  89. $6352.00 dollar repair on 6.0 Pwrstoke
  90. ECT and EOT "tee" Fittings help
  91. Safe horsepower
  92. number on my egr cooler?
  93. 07 6.0 P2291 No Hot Start
  94. I have a Bi Xenon Kit question?
  95. who is best for custom tuners
  96. 2006 f 250 6.0
  97. f250 6.0 oil in intake pipes
  98. intercooler issue help
  99. Intake housing clamp failure on turbo
  100. No start after HG's Oil cooler etc..
  101. Ive Converted over
  102. 2003 Low power
  103. TROUBLE STARTING WHEN WARM
  104. exhaust brakes
  105. Weird noise after letting off gas
  106. 6.0 bullet proof
  107. 2004 F350 cold miss
  108. 2005 F350 6.0L Powerstroke No start
  109. SCT iTSX? Pros and cons?
  110. WHAT TO MOD NEXT?!
  111. ecoRoute HD
  112. East and Free banjo bolt upgrade..
  113. manual sliding window to power window
  114. intercooler boot clamp dia. ???????????
  115. Doing EGR delete
  116. ficm tested good... now im stumped...
  117. 05 f250 leak
  118. Gpcm or PCM?
  119. new (to me) truck prevenative maintance
  120. 2004 f550 6.0 want take fuel and pours black smoke
  121. Is my turbo shot?
  122. uggg.... 6.0 build
  123. Next Upgrades
  124. Whats more likely to Go Out?
  125. 2006 Ford F350 6.0 Wont start at all.
  126. what synthetic motor oil is every one running
  127. How make 6l smoke
  128. TOOOOLLLLLLLLLL??????????
  129. regulated return
  130. Fuel Solenoid Ground
  131. Headlight bulbs
  132. A/C ON TRUCK HEATS UP?
  133. New truck have a few questions about initial upgrades
  134. HG?? Yes or No
  135. Rebuilt Transmission
  136. 06 6.0 after hg job
  137. New to ford
  138. P0341??
  139. Gauge Installation Help!!!
  140. EDGE CTS install problem
  141. Magnet in tranny pan
  142. Injector Cut Out Specs
  143. transmission service (oil)
  144. $9,000.00 dealer estimate
  145. Info please
  146. Speedo and odometer not working
  147. Regulated return or Air Dog?
  148. lifted f350 hard to steer?
  149. need some advise
  150. Suspension, ROUGH ride
  151. Oil leak
  152. Tubo boot blew off
  153. Another issue...
  154. 03 6.0 backfire type sound?? help
  155. odd 4x4 problem
  156. brakes blew out
  157. Cold studder
  158. Sick 6.0
  159. Question..
  160. exhaust
  161. Back Again With A new Problem I THINK
  162. What type of axle do I have?
  163. What Eot and ect are you guys seeing?
  164. transmission filter bypass kit
  165. need some professional help on tuners
  166. quick! 2005 6oh has cel and misfire. need info by tomorrow!
  167. puttin a 6.0 in a 1979 f250
  168. 6.0 egr Delete
  169. any one throw egr codes after straight pipe insall?
  170. need helh
  171. 03 f250 6.0 vs 02 f250 7.3
  172. F250
  173. 6.0 Photos of mods, gauges, chip, exhaust, intake, filtration, zoodad, lowered, B100
  174. Need help fast.
  175. where to find
  176. Intercooler
  177. 2006 to 2004 transmission swap?
  178. Set up alarm advise??
  179. Yeah, 6.0 hot no start
  180. Mpg's
  181. ready to do HG and studs, part#s
  182. Vibration and idle
  183. Reving isuues
  184. Neighbor probably hate me
  185. 6.0 died and won't start
  186. WON'T START WHEN WARM
  187. I'm back after the $4000 problem i had a couple weeks ago! Yay me....
  188. well boys my exhaust came in :)
  189. 6.0 problems
  190. Bad Turbo?
  191. On my way to 500HP!
  192. Low humming noise with slight vibration
  193. straight pipe
  194. 6l with issue
  195. MBRP Muffler Delete Question!
  196. High pressure oil leak?
  197. Turbo?
  198. Built 2003 Ford F350 Power Stroke
  199. Fuel Spring upgrade
  200. Rev X and Rotella T6
  201. Remote tranny filter
  202. Why you DON'T want after market filters
  203. limp mode
  204. source for FICM harness
  205. need help
  206. Can i run a race tune?
  207. Oil Pressure
  208. Programmer problems
  209. To test or not to test FICM
  210. what mt and at is everbody running
  211. 2003 6.0 looses power all of a sudden and idle fluctuates
  212. 6.0 Rough cold idle slight bucking under load
  213. 2003 6.0 looses power all of a sudden
  214. Turbo not building pressure
  215. air dog does everbodys suck
  216. Im back!
  217. just ordered my exhaust yeee haawww!!!
  218. Diff fluid
  219. Huge gains from FICM ONLY tune!
  220. Truck pictures!!!
  221. Unrelated
  222. EGR
  223. Programer
  224. Occasional groaning noise from steering.
  225. HELP!!! 6.0 white smoke antifreeze smell!
  226. Intercooler hoses
  227. just about to order mbrp but i have a question
  228. Alternative to GO-GO direct solenoid???
  229. 05 turbo removal questions
  230. EBP
  231. 2005 6.0 no smoke no start
  232. Does this seem like just injectors or FICM
  233. 6.0l No Oil Pressure
  234. 6.0 Powerstroke heads
  235. Confused about gauges!!
  236. Injector cleaning
  237. Egr cooler upgrade versus delete
  238. Cruise Control
  239. leaking coolant
  240. 6.0 runs rough
  241. 2006 6.0 Head studs/intake manifold help
  242. EGR delete question
  243. Tranny problems
  244. Millenium Extended Warranty HELP
  245. Cool/cold start issue
  246. codes
  247. OIL IN MY EXHAUST!!!!
  248. Stick-shift no clutch to start
  249. DIY badges
  250. 2008 GRILL AND BUMPERS ON 2005
