- Boost leak/oil spray
- Oil & Coolant Bypass under the hood
- remove ac compressor
- 6.0 rough start and rough Idle
- Coolant filter kit
- Popping sound
- tuner question
- egr cooler vs delete questions
- $6352.00 dollar repair on 6.0 Pwrstoke
- ECT and EOT "tee" Fittings help
- Safe horsepower
- number on my egr cooler?
- 07 6.0 P2291 No Hot Start
- I have a Bi Xenon Kit question?
- who is best for custom tuners
- 2006 f 250 6.0
- f250 6.0 oil in intake pipes
- intercooler issue help
- Intake housing clamp failure on turbo
- No start after HG's Oil cooler etc..
- Ive Converted over
- 2003 Low power
- TROUBLE STARTING WHEN WARM
- exhaust brakes
- Weird noise after letting off gas
- 6.0 bullet proof
- 2004 F350 cold miss
- 2005 F350 6.0L Powerstroke No start
- SCT iTSX? Pros and cons?
- WHAT TO MOD NEXT?!
- ecoRoute HD
- East and Free banjo bolt upgrade..
- manual sliding window to power window
- intercooler boot clamp dia. ???????????
- Doing EGR delete
- ficm tested good... now im stumped...
- 05 f250 leak
- Gpcm or PCM?
- new (to me) truck prevenative maintance
- 2004 f550 6.0 want take fuel and pours black smoke
- Is my turbo shot?
- uggg.... 6.0 build
- Next Upgrades
- Whats more likely to Go Out?
- 2006 Ford F350 6.0 Wont start at all.
- what synthetic motor oil is every one running
- How make 6l smoke
- TOOOOLLLLLLLLLL??????????
- regulated return
- Headlight bulbs
- A/C ON TRUCK HEATS UP?
- New truck have a few questions about initial upgrades
- HG?? Yes or No
- Rebuilt Transmission
- 06 6.0 after hg job
- New to ford
- P0341??
- Gauge Installation Help!!!
- EDGE CTS install problem
- Magnet in tranny pan
- Injector Cut Out Specs
- transmission service (oil)
- $9,000.00 dealer estimate
- Info please
- Speedo and odometer not working
- Regulated return or Air Dog?
- lifted f350 hard to steer?
- need some advise
- Suspension, ROUGH ride
- Oil leak
- Tubo boot blew off
- Another issue...
- 03 6.0 backfire type sound?? help
- odd 4x4 problem
- brakes blew out
- Cold studder
- Sick 6.0
- Question..
- exhaust
- Back Again With A new Problem I THINK
- What type of axle do I have?
- What Eot and ect are you guys seeing?
- transmission filter bypass kit
- need some professional help on tuners
- quick! 2005 6oh has cel and misfire. need info by tomorrow!
- puttin a 6.0 in a 1979 f250
- 6.0 egr Delete
- any one throw egr codes after straight pipe insall?
- need helh
- 03 f250 6.0 vs 02 f250 7.3
- F250
- 6.0 Photos of mods, gauges, chip, exhaust, intake, filtration, zoodad, lowered, B100
- Need help fast.
- where to find
- Intercooler
- 2006 to 2004 transmission swap?
- Set up alarm advise??
- Yeah, 6.0 hot no start
- Mpg's
- ready to do HG and studs, part#s
- Vibration and idle
- Reving isuues
- Neighbor probably hate me
- 6.0 died and won't start
- WON'T START WHEN WARM
- I'm back after the $4000 problem i had a couple weeks ago! Yay me....
- well boys my exhaust came in :)
- 6.0 problems
- Bad Turbo?
- On my way to 500HP!
- Low humming noise with slight vibration
- straight pipe
- 6l with issue
- MBRP Muffler Delete Question!
- High pressure oil leak?
- Turbo?
- Built 2003 Ford F350 Power Stroke
- Fuel Spring upgrade
- Rev X and Rotella T6
- Remote tranny filter
- Why you DON'T want after market filters
- limp mode
- source for FICM harness
- need help
- Can i run a race tune?
- Oil Pressure
- Programmer problems
- To test or not to test FICM
- what mt and at is everbody running
- 2003 6.0 looses power all of a sudden and idle fluctuates
- 6.0 Rough cold idle slight bucking under load
- Turbo not building pressure
- air dog does everbodys suck
- Im back!
- just ordered my exhaust yeee haawww!!!
- Diff fluid
- Huge gains from FICM ONLY tune!
- Truck pictures!!!
- Unrelated
- EGR
- Programer
- Occasional groaning noise from steering.
- HELP!!! 6.0 white smoke antifreeze smell!
- Intercooler hoses
- just about to order mbrp but i have a question
- Alternative to GO-GO direct solenoid???
- 05 turbo removal questions
- EBP
- 2005 6.0 no smoke no start
- Does this seem like just injectors or FICM
- 6.0l No Oil Pressure
- 6.0 Powerstroke heads
- Confused about gauges!!
- Injector cleaning
- Egr cooler upgrade versus delete
- Cruise Control
- leaking coolant
- 6.0 runs rough
- 2006 6.0 Head studs/intake manifold help
- EGR delete question
- Tranny problems
- Millenium Extended Warranty HELP
- Cool/cold start issue
- codes
- OIL IN MY EXHAUST!!!!
- Stick-shift no clutch to start
- DIY badges
- 2008 GRILL AND BUMPERS ON 2005
- SCT livewire Mounting???
- What are the draw backs of EGR delete?
- 06 6.0L White Smoke with Blueish Tint at idle and take off??
- Engine Vibrations and cold starts. Codes on 7 cylinders
- FICM issues Help!!!!!
- New guy needs help!
- Isspro ev2 gauges install
- Early '04 Cranking but Not Starting
- 6.0 turbo surge at idle and shakes going down road
- ok i need some misfire assistance please.
- Little DIY High Idle for you guys
- Auto enginuity
- Serpentine belt??
- Intake help...
- Recommended FORD 6.0L Technicians in the Bay Area (CA)
- 04 6.0 with problems
- Intermittent Problem
- Coolant filter
- tuner
- Egr update
- VGT question
- coolant leak at reservior cap
- 2005 6.0 stock.. no-start
- QUESTION OF THE DAY!!??!!
- Feel little spit and sputter
- 6.0l
- cab weight
- I have no clue!!
- whitish blue smoke?
- powerstroke trubo?
- NOOOOOOOOOO!!!!!
- 05 Ford Runs better Cold
- Idler noise?
- Pesky Codes
- Miss on cold start
- 04 6.0L Crank no start
- New first time 6.0L PSD owner with some old questions!
- 2005 f250
- not good vibrations
- 2006 f350
- No get up and go
- QUOTE
- 2006 super duty
- lie-o-meter and transmission
- FICM Tuning
- 2003 6.0 egr delete whats the best one.?
- Turbo hose blows off
- pulse width question/no start 03 6.0
- 2005 E-450 bus part time no Low pressure oil?
- Popping sound an black smoke
- 6.0 no start and out of ideas
- 6.0 trials and tribulations
- limp home mode
- 05 6.0L Loss of Power and MPG
- Coolant?
- oasis
- rmps jumping
- Question for Scan Gauge II users
- reset PCM?
- 04 oil cooler
- Finally found a code. Anyone ever have same one??
- auto 4x4 hubs not working/vacuum leaks
- Vegistroke
- used sct question
- Hypermax wire ring head gaskets
- Bully dog watch dog?
- Update
- EGR Delete
- Fuel Gauge Install and Pressure reading
- New to me 2006 6.0L. Help wanted.
- Do I really need a new turbo?
- 6.0L write up
- 2003 6.0 runs rought
- wheels and tires for my 2006 f250
- Diesel smell
- Code P0299
- Have you missed me yet?
- Need help. Trucks Tampon fell out. She's p!ssy
- New to 6.0 world: What do i need to do?
- Help: Died on freeway, No start, No throttle
- 6.4 PSD
