- Head Gaskets
- Clutch Question
- Main Studs
- OBS single tank
- New mods
- Problems with starting my 1995 Powerstroke
- My heat is not hot
- evans npg+
- CFM rating
- Where is the best place to hook up gauges
- Glow plugs
- gas to diesel conversion
- question on my 97 f-250 7.3
- 94 powerstroke missing,running terrible
- I'm smelling exhaust.
- When did turbo become standard on Powerstroke
- 1996 F350 wont start
- superduty leafsprings on obs?
- need help quick neg batt cable
- how to get pre-filter off
- Intercooler V. water injection?
- 351 to 7.3 swap
- Question about OD
- gear ratio
- HPOP Empty
- 97 stroke leaking diesel??
- truck will not shift into gear
- what would it take?
- 98 7.3 wont start turns over clean fuel
- WHat next???
- F-SuperDuty
- ZF5 overdrive noises
- Back in the Powerstroke scene!! First obs and first auto diesel though
- Whats the best chip for mpg
- excuse the ignorance
- F450 running gear?
- wiring harness
- Rear winch?
- Comments???
- two questions, clutch and downpipe
- ford death wobble ?????????
- the dam beast is fightin me
- turbo question for you strokers
- in need of some picture help
- injectors reman vs. new-online vs. local
- 96 7.3 crate engine
- Injector Ideas?
- back pressure sensor
- water meth??
- '96 Power lock actuators
- White/Blue smoke???
- 4" or 5" exhaust
- Why So Responsive
- Clutch firewall Repair kit?
- how about a 4" downpipe?
- truck stalling at stops
- Drained Trans fluid, now clutch wont engage
- question about 4" exhaust
- 94 PowerStroke wont start
- Newbie to powerstroke
- runs rough and white smoke
- P1211
- What torque converter to use?
- GOING CRAZY
- Wheel base question
- severe loss of power!
- got rid of the dead fish lookin down. pipe
- drivers side door bushings
- Opinions?
- How Hard???
- TS 6 pos chip
- is this a good deal?
- wheel bearing
- 96 powerstroke
- singal stack
- cheap and easy up pipes?
- lots of noise
- EGT's
- Intercooler problem
- 1994 Powerstroke motor issue
- my 97 7.3 question
- six speed transmission
- Next issue-----Fuel gauge.
- FPR shim?
- missing loping only between 45mph and 55 mph
- Hard shifts
- powerstroke help
- grey smoke
- 7.3L superduty intercooler???
- BTS Tranny
- Sensor on airbox
- Is this IPR o-rings?
- 96 f250 7.3 no crank no turnover
- down pipe, intake, stacks
- horrible fuel mileage
- 96 f350 info!!! plz!!
- which turbo?
- injector related problem.
- Fuel pump issues
- What trans temp
- fuel leak
- headlight issue
- stroker no start, help me please
- I need a trans cooler
- Cruise control (after market)
- Compression test results?
- Lets see how good you guys are: wont start
- would it work...?
- Thinking about buying a 95 f350 cclb
- rebuildable turbo off 2000 f350
- f150 made into a f350???
- 1997 F250 powerstroke
- Tach needed
- Just Bought a 1997 Powerstroke I have ? on it
- What trans cooler?
- 97 psd dies when warm
- New to everything...
- why wont it start?
- Help!!! Fuel leak
- Buying used injectors advice
- 7.3 engine 1994
- sterling 10.25 problem
- P1211 woes
- Building an Intercooler
- edge Evo
- loose shifter simple fix
- BIG problem!!!!
- 96 PSD Trans ?
- 97 powerstroke water in oil
- Noob with questions
- Smoke
- WANTED: single stack.......
- More Power?
- What is this?
- P2281 Cylinder 7 contribution or balance fault
- 1996 f 350 4x4 od light flashing,,help please
- sponge brakes 1997 f 250
- Fuel pressure at Shrader valve
- question about a ts 6 postion.
- fuel pump
- strokin it
- White Smoke
- Brake Probs When Cold
- NEW G PLUGS AND REBUILT INJECTORS
- will not start when cold out
- EBPV as an exhaust brake???
- 97 7.3 motor problem
- PISSED!!
- 1997 f350 4x4 steering
- Steering stops on 90's f350 dana 60
- Noisy intake
- 1997 1 ton boost???
- Rust
- bed liner on brush guard and bumper
- something like a waste gate????
- two questions
- What gears?
- i have a question about a tuner
- 94 turbo 7.3 no start or starts and dies no restart need help
- 97 3/4 ton turbo
- adjust idle
- hard brake pedal no brakes
- Speedo bouncing
- looking at getting a powerstroke
- dumb question but have to know
- truck kinda sputters at 2000 rpm then picks up HELP!!!!!
- grinding 7.3
- need some help have some ?S
- hydraulic pump mount
- photoshoot of my truck
- not getting up to temp
- Considering buying a 96' 7.3L
- 7.3 ghost start
- Air ride seats
- dana 60 front needed
- trans help
- Mounting a Winch?
- Why doesn't my 97 have a wastegate on the turbo?
- 4 speed on 7.3
- crank, no start
- What to look for in 1997 f250
- headlight mounting
- lets see all the trucks
- HELP!!!! Fuel Leak
- winter troubles
- wiring help
- Rotors on a 96 f250 help
- LED Tailights Group Buy
- 7.3 rebuild
- Diesel smoke signals
- coolant
- Speed/odometer fix?
- go big or go home... but how big?
- oil pressure problem
- FALLING APART!
- TS chip?
- Ford Automatic Transmission Questions?
- Where to find Interior plastics?
- 1995 f 250 7.3 PSD won't start in 40 degree weather. Low Oil pressure
- 97 f-250 has no drive gear only 1st and reverse
- need help on turbo question
- help please
- Sealing Head Bolts/Studs.
- another tranny problem
- 97 powerstroke issue
- 96 7.3 PSD WIRE QUESTION
- need some advice
- Tranny probs
- Just installed rebuilt E4OD and reverse is weak along with fwd...
- 95 powerstroke wants to die
- Need input on 1996 stroker
- 93 7.3 idi
- Just found a farm truck
- cutting out while driving
- Auto to 5spd swap into 95 PSD,Any advise and parts list?
- 603 error code
- Tranny problem,95 7.3 f-350 4x4
- 1996 7.3 f-350 running in driveway then stalled out now no restart
- 97 7.3L F250 waste gate
- front end problems
- truck wont move in drive
- Stock Turbo Upgrade ?s for '95 F-250 7.3l
- 7.3 F250
- straight axle conversion please!
- turbo psi
- Truck died and will not start
- 97 psd intermittent skip
- loud squeek when driving
- Converting to super-duty electric fuel pump
- 7.3L Engine Life For a Buyer??
- Mysterious Vibration...
- NO FUEL PRESSURE
- High Mount Brake Lieght, Dome Light Problems
- rpm jumping .
- ZF 5 trans fluid
- TD Sudden Stall While Driving
- Downpipe leaks
- edge programmer setting?
- Injector queston.
- need some help!
- need some help
- need help asap
- Choking 1996 PSD F-350
- fuel tank vent problem?
- 7.3L excessive black smoke cold start-up
- bad shimmy when i hit a bump
- exhaust: money Vs. performance gain
- lpop knock insight
- Stacks or Straight Pipe?
