PDA
View Full Version : Chevy/GMC Duramax 04.5-05 LLY
Pages : 1 [2]
  1. need help! transmission relearn
  2. MPG
  3. adding coolant
  4. EGR cooler
  5. colder weather
  6. Programmers????
  7. any know how on this duramax turbo?
  8. head bolt choices
  9. EGR, PCV reroute, CAT delete
  10. LLY blown gaskets,
  11. coolant leak
  12. '05 duramax loosing fuel pressure
  13. chip?
  14. duramax not starting
  15. Transmission Problem
  16. duramax
  17. ok dumb question
  18. 4" vs. 5" Exhaust
  19. fuel problem
  20. another lly overheating question
  21. need help with a motor swap
  22. P0670
  23. Losing coolant, 05 duramax
  24. white smoke at idle
  25. K & N Intake
  26. codes. please help
  27. Found an oil leak! need some help.
  28. MPG Increase
  29. I have no power!!!
  30. limp mode code 1093
  31. Advice for a newbie??
  32. PPE HOT+2
  33. Thinking about buying a 04 duramax what to know
  34. help me out
  35. fuel mileage
  36. duramax turbo clamp
  37. cranks, no start
  38. p1094 code
  39. LLY problems?
  40. Switch on????
  41. Coolant leak
  42. squeaky steering
  43. COOLANT LEAK, NEED HELP!
  44. exhaust for my lly
  45. Diagnostic-Turbo Vain Position Sensor
  46. oil blow by
  47. Duramax Won't Start
  48. no oil pressure
  49. how to tell the difference between lbz lly truck?
  50. NO COMMUNICATION
  51. cant find source of leaking coolant
  52. JUST CURIOUS
  53. Turbo Squealing
  54. Limp Mode?
  55. tow hauld mod / over drive switch
  56. COMPONENT QUESTION?
  57. EGR problems
  58. COOLANT QUESTION?????
  59. Lly recals?
  60. 4 Wheel Drive QUESTION!?!?!?
  61. allison trans 5 to 6 speed question?
  62. intercooler Pipes
  63. 05 duramax headgasket repair
  64. trans question
  65. Possible limp mode?!?!?
  66. Grinding Starter
  67. LLY MP MOD? !!HELP, I GUESS!!
  68. LLY or ?
  69. FUEL FILTER PROB! HELP ASAP!
  70. rear diff locking up
  71. One more thing
  72. Thermostat replacement
  73. Heater issues?
  74. Hissing exhaust
  75. looking for info
  76. 2004 duramax lly will crank but wont start
  77. LBZ radiator
  78. 2005 Duramax
  79. dmax questions?????
  80. 2004 exhaust extremely loud
  81. confused about situation
  82. lly to lbz change over
  83. How many here have had a head gasket failure?
  84. im stumped.
  85. 2005 chevy fuel injection problems
  86. NEED HELP P0089
  87. 05 Duramax 2000 rpm shut off
  88. Rear Diff?
  89. p0642
  90. Rear door locks
  91. Coolant issues, need help
  92. mississippi
  93. Broken Turbo ????
  94. AC fan
  95. Engine code help
  96. A Cummins Man Needs Some Assistance From Some Chevy Folks
  97. 05 D-max high miles?
  98. limped again!
  99. allison question
  100. how do i reset the fuel filter light?
  101. tranny limped?
  102. shifting problem
  103. 05 duramax gmc, good rig?
  104. smog
  105. Duramax Injectors. No surprise
  106. Pedal Stop working
  107. Low power
  108. does a stock LLY truck smoke?
  109. Ball joints
  110. hard miss what run no power
  111. leaking down pipe
  112. High mileage 05 ??
  113. annoying rattle/clatter
  114. Front Differential Oil Drain Plug
  115. Leaking Injector
  116. i need a transfer case
  117. front differential
  118. Straight pipe
  119. U Joints
  120. Turbo Vanes stuck
  121. How should I ask for my pickup?
  122. coolant out overflow
  123. blue smoke
  124. Brake Bleed on LLY
  125. LBZ Mouthpiece
  126. 05 Duramax smokes and won't move
  127. EGR and injector #2 output circuit
  128. good price on this truck?
  129. where is the wastegate
  130. Transmision Rebiuld
  131. Oil Pressure Gauge
  132. Hidden short circuit
  133. New CP3 still 1093
  134. Help with code
  135. Injector Replacement
  136. trouble codes
  137. LLY Codes. Need possible causes.
  138. New LLY Duramax Power Tee Shirt
  139. low rpm miss
  140. LLY Smoking on WOT
  141. Power Problem
  142. Rear differential service?
  143. Grandma with a duramx
  144. 1st pull
  145. flywheel
  146. need help..
  147. up pipe bolts?
  148. My friends truck broke down.....
  149. A/C Unit wont turn off.
  150. LIMP MODE!!!
  151. Autoheadlights come on and stay on during day
  152. Oil in turbo.
  153. service 4wd
  154. high egt's lately
  155. P0087
  156. Need some help.
  157. trouble codes
  158. speedometer problems
  159. Yes...More questions...
  160. *** DTC... U1000? ***
  161. Considering This Truck....
  162. LLY Over Heating While Towing
  163. Oil Pressure?
  164. Normal Boost Numbers
  165. Allison Maintenance
  166. Truck Won't Start
  167. EGR Leaking Oil
  168. 2nd Turbo On Stealer's Dime
  169. New Truck AGAIN :(
  170. Someone Talk Me Into This...
  171. Dealer Has No Clue, And We Need This Thing Fixed NOW!!!
  172. '05 LLY 6spd...
  173. Did My Good Deed for the Day!
  174. sweeeeeet
  175. 5w30 Engine Oil In T-Case
  176. Shocks
  177. Amsoil Tranny Fluid
  178. Trailer Brake Plug In??
  179. Axle Lubricants??
  180. Steering Clunk??
