- Engine Cuts Out At Higher RPM
- chevy dura max 03
- white flag about the white smoke
- First Hand, Gauges?
- Low Coolant light coming on
- Repairing a bed-side?
- truck won't start when its cold outside
- Poor cab heat
- lb7????
- 01 injector pump
- Replaceing FAN on an LB7
- LB7 DIY, Maintenence, Codes, and TSB's.
- Gotta tear down my baby
- new turbo
- Problem with 2004 Duramax
- 2004 Duramax Engine Light On
- egr problems
- injector problem
- New guy checking in.....
- Knock
- egr help
- INjector haze
- help truck keeps turning lit on p0089
- Rough running 02 Help!!!!!
- need advice on a 01 lb7 worth it?
- balance rates
- 2001 LB7.. This thing has issues.
- how hard could it be??
- oil filter leak?
- Head Gaskets
- Low Coolant Problem
- 2003 duramax has a intermittent no start
- Boken heater core hose
- 2001 DURAMAX LB7
- Engine Oil Life
- Looking at buying an '02 LB7 Pro/cons
- Exhaust and Noise?
- Spare key and alarm system
- Need DURAMAX repair in Detroit area???????
- 2001 Duramax smokes
- 03 blows white?
- FUEL PSI GAUGE VS RAIL PSI
- $1000.00 (That is correct, one thousand dollars) 03 Duramax
- transmision msg?
- 04 Duramax power loss
- injector problems
- Buying an 01.
- Power reduced while brake is applied?
- boost gauge
- how do you test the glowplug relay
- manifolds cooldown cracking noise after shutting down
- Bilstein 5100 Shocks
- replacing ball joints
- Tire and Wheel size
- annoying vibration
- DURAMAX IDLE PROBLEM
- oil pressure
- water in cab
- Changing a Fuel Filter
- 2003 Duramax Diesel WaterPump R&R
- engine limping
- Duramax Repair Manuel
- dmax valve lash
- Fuel Flow/ Leaky Rail
- loss of power?
- Pulled Injector cups / Injector sleeves
- nitrous
- injectors
- duramax vs cadillac ctsv
- Diagnostic Code P0236
- Racing a 6cyl. mustang
- Help Speedo jumping, ABS & Brake light on
- bad injector vs particulate filter
- Changes?
- New LB7 Duramax Power Tee Shirt
- o2 duramax nocking sounds
- "Service Engine Soon" light & fault code
- Limped tranny ???
- DIY rebuilt injectors?
- oil pressure.
- Balancer bolt
- Leaky Injectors.
- 03 duramax
- Injection pump replacement instructions
- WasteGate Blockoff
- EGR causes hazing?
- Time for a change.
- 04 Duramax with ZF6 speed manual.
- Trouble code P0380
- Topkick smoking!!!
- top speed
- false oil pressure signals
- '03 duramax studdering
- vibration
- Trans. Temperature
- Is this a truck i should look at or steer clear?
- Sell me a Chevy
- What Boost valve
- Duramax
- Sudden Boost Drop.
- Cycling noise...???
- 2002 LB7 HP upper???
- Boost Pressure at 65mph
- puff while cranking
- Weird Rail PSI
- proper pyrometer install?
- I'm Back
- Black Smoke, No Power
- Removing the Harmonic Balancer
- 2003 LB7 duramax Low fuel pressure
- trailer wiring no, blinker or brake
- replacing the t stats
- unusual rattle in engine
- SCIV
- WTB: LB7 injectors
- Aftermarket or GM or Reman injectors
- Hitachi Starter any good?
- adjusting torsion bars
- Rear Rotors
- Changing injectors on a LB7
- Replacing Duramax LB7 Injectors 01-04 tips and hints
- Busted CV Shaft
- water/meth injection
- 03 transmission - Help
- weird noise
- Lost on this.
- Am I "limping out"
- 2001 Duramax
- service engine soon
- Reset or quick learn the allison transmission
- Dmax Leaking ATF
- tranny options?
- lookin at truck
- Danny's no help, need transmission suggestions
- high idle
- Headlights
- pulling a bumper
- No power steering or brakes
- Knocking and black smoke...
- Annoying sound
- Funny surging idle...
- new truck hopefully
- Fuel leak in oil crankcase?
- Tire Size
- something loose in the front end
- need opinion
- bad injectors ?
- truck wont smoke
- remote start?
- gear/axle ratio question
- Blue Smoke
- the truck
- burnout...
- Did a little logging today
- Lb7 injectors in a lly?
- Injector replacement
- what's up with this?
- limpin' down the road
- tires?
- Looking at an 01 Duramax, 2WD, ext cab long bed.
- Intake air temp.
- NEW TRUCK!!
- GEAR OIL
- Weird Acting Duramax
- Anyone Ever Had This Problem???
- My "New" Hauling Rig...
- Chug??
- Transfer Case?
- DTC Question
- Water Pump Leaking
- Injector Options?
- Any Suggestions?
- Starter?
- Blue Smoke At Idle
- Takeoff
- New Truck
- Looking For Some Answers About The Best Programmer For An LB7
- Cabin Air filter
- Need Some Help
- Help My Truck Won't Start
- ZF S6-650 vs Allison
- Juncion Block Body - No Power
- Bad FPR
- 04 Dmax 4X4 6spd
- p0089
- 2004 Chevy Silverado Duramax - Worked Truck
- Is This Right
- Duramax LB7
- How Hard To Change A Fuel Filter?
- U1800 DTC Code
- Looking For A New Truck
- Sliding Rear Window?
- Power Steering Leak
- The AMSOIL Dealer Said.....
- Synthetic Oil...?
- New Duramax owner w/ question, please.
- Yup....I Did It.
- Disableing MAP
- 03 Dmax Stock Guage Cluster Not Working Right?
- My Truck's First Load (Since I Got It)
- What Tranny Does The 03 Have
- Does Anyone Know If...
- Tires?????
- lb7 mpg
- "Death Mode" On A 2001 Duramax
- Coolant in Oil
- fuel pump
- OK ......Which one of you Chevy guys???
- 4x4 Gremlins
