View Full Version : 94-98 7.3L Performance
  1. New power
  2. southbend clutch sticks
  3. Injector question
  4. what do you guys think injector wise?
  5. need opionions
  6. turbo timers
  7. Fuel Bowl.
  8. Installed T-500 HPOP .. Leak?
  9. T-500 HPOP
  10. Help
  11. lots of motor questions!
  12. Which intake is best?
  13. Finally got some upgrades!!
  14. bulletproof tansmission. which one?
  15. project MORE POWER
  16. Trans swap
  17. Dual hpops
  18. turbo size for injector
  19. Reverse Sincro Replacement ????
  20. diesel power
  21. did they change the ts chip?
  22. need a little more power
  23. 7.3 MPG?
  24. FASS on a 96 powerstroke???
  25. white smoke
  26. which injector?
  27. F350 crew cab 8" lift kit
  28. exhaust kit
  29. 37", 35", or stick with 33" tires?
  30. Saw a 500hp Common Rail get smashed by a relatively stockish 7.3 today
  31. Intercooler
  32. ts chip
  33. Rosewood stage 2s
  34. Edge Cs and CTS speedometer
  35. Is there any way to spin more rpm's on our 7.3's (and is it worth it?)
  36. VGT
  37. how can i get some power out of my 7.3?
  38. need cheap, good 6" lift springs
  39. rosewood injectors
  40. Time for new mud tires... input
  41. terminator 17*modded pump
  42. Ts performance, not exactly what I imagined..
  43. 97powerstroke chip
  44. 10k mod?
  45. smoke switch
  46. Upgrades
  47. Chip Question
  48. front flip shackle kit
  49. New mechanical fuel pump not workin
  50. f250 axle swaps
  51. Exhaust hangers
  52. High performance 140v IDM? Worthwhile?
  53. Is the $250 Terminator Engineering hpop upgrade worth it?
  54. Whats the point of tow/heavy tow tunes on TW tuning??
  55. HPO/HPX upgrade??
  56. New exhaust
  57. Replacing my 6" lifted Superlift shocks...
  58. Front tires are angled inwards; buying new BJ's and u-j's
  59. Truck dies after idling for extended periods then putting into Drive
  60. DIY injectors
  61. In the market for a new 4-5" exhaust and downpipe...
  62. intellistick
  63. Safe to ride the governor on these?
  64. My truck supposedly has ABS... but it NEVER kicks in...
  65. What does a trans lockup switch do, and will it benefit me?
  66. Why does my OBS start better in 27* weather than my NBS did in 50* weather??
  67. Why are my front tires wavy?
  68. stock '97 auto vs stock '99.5 6spd??
  69. Aftermarket downpipe worth it?
  70. Bought my OBS powerstroke!! Lovin it!!
  71. biggest mods
  72. Getting new injectors.. thinking about budget-built stage I Rosewoods
  73. looking for tony wildman
  74. Chip Ideas!
  75. loudest train horn
  76. Chip
  77. Powerstroke newb
  78. Fuel plugs?
  79. Superduty Conversion?
  80. Trans temp gauge
  81. Help
  82. EBV jake brake?
  83. 10k mod worth doing?
  84. DP Tuner?
  85. wastegate
  86. Orange Intake Replacement boot for OBS Turbo
  87. injectors
  88. 1996 PSD downpipe upgrade help
  89. performance help
  90. Tranny Change
  91. Edge 15000
  92. Whats my best option
  93. Exhasut help
  94. Longest lasting 7.3L??
  95. f250 solid front
  96. more smoke without spendin any $$
  97. upgrading 1995 powerstroke injectors to 1999 injectors
  98. Bull dog programmer
  99. Any Ideas
  100. New Mods too OBS (high performance)
  101. Intake Y-pipe
  102. 1995 powerstroke intercooler upgrade question
  103. Question For The Ford Guy's
  104. injector mix and match
  105. Want more horses.
  106. engine swap
  107. 5"-7"tip
  108. tranny cooler for a 95
  109. 96 ford psd
  110. Edge evolution ????
  111. intake
  112. bullydog chip
  113. Tranny gone!
  114. Injector size as related to horsepower...
  115. Looking for some answers
  116. problems
  117. good mods for a 97 7.3l
  118. Cat Converter
  119. 17* HPOP
  120. how much T can she handle
  121. BIG INJECTORS
  122. Crazy Idea
  123. performance for 94 f250 idi turbo
  124. TURBO SELECTION
  125. Have a few questions
  126. 1997 powerstroke horsepower and torque numbers stock?
  127. ts or tony wildman???
  128. smoke switch for 97 powerstroke???
  129. benefits and outcome of FPR shimmed???
  130. Best Programmer/chip for black smoke(97 powerstroke)
  131. 1997 F350 Powerstroke
  132. 96 powerstroke mods
  133. 96 powerstroke mods
  134. fuel regulator shims
  135. Aftermarket intercoolers
  136. Turbo
  137. 1997 Ford F350 Chip Test - 7.3L Power Stroke Chip Comparison
  138. Has anyone replaced there auto hubs with lock outs?
  139. powerstroke straightpiped?
  140. Lift
  141. 7.3 idle problem
  142. injectors 7.3 idi turbo
  143. What's first?
  144. Sniper Chip?
  145. downpipe ?
  146. stage 2's
  147. 97 need help
  148. New Injectors on my F350?
  149. help with pulling need more power on take off
  150. Have An Electic Fuel Pump???
  151. Shimming A FPR? How?
  152. Upgrade Questions..
  153. HPOP?
  154. Injectors and Stock Tranny
  155. Front tow hook ideas?
  156. Fuel system questions???
  157. diy ic tubes
  158. map sensor
  159. get her to smoke
  160. Aftermarket Turbo Housing
  161. backyard performance
  162. MBRP Exhaust 97 F350
  163. group buy for zf5 short throw shift kits!!!
  164. 97 powerstroke. chip/programmer help ?
  165. 1997 Ford F350 Powerstroke help
  166. watchdog
  167. suspension question
  168. 6.0 turbo on a 7.3??
  169. Dual Front Shocks
  170. 97 7.3 Needs downpipe
  171. trans upgrades?
  172. want morepower for my 1996 7.3 any tips
  173. Which is the best all around chip for a 97 power stroke is ts a good chip for it
  174. 400 HP on a 95 powerstroke
  175. tw chip check engine
  176. chips/programmers.
  177. exhaust brands
  178. 94 turbo down pipe
  179. hesitation
  180. HARD TO START COLD,LOTS &LOTSOF WHITE SMOKE
  181. downloader, ?
  182. good mods
  183. Front Cover 7.3 powerstroke
  184. 1997 Ford F350 Power Stroke Buildup - Easy Upgrades
  185. Gauges (Boost Gauge Installation?)
  186. bully dog problems
  187. straight axle f-250
  188. Nitrous On A 7.3?
  189. 7.3 turbos
  190. Master Engine Rebuild Kits
  191. My Boss
  192. OBS Strokers?
  193. Newb question: Funny tach. reading.
  194. 7.3-Non turbo Reliability Performance ETC??
  195. Mods
