- Gears
- Turbonetics turbo ??
- Review: Gryphon FICM tuner.
- SCT Tuner & Fuel Pump
- Any trouble swapping 04 6.0 in Excursion with 06 6.0 from f-250
- Need advise on 6.0 powerstroke
- Turbo Timer???
- stc fitting ?
- Which tuner to get?
- Which intake with a Powermax turbo?
- Brightest Factory Replacement Headlight Bulbs
- Nitrous?
- New to the Forum ?'s about SCT
- tire size
- questions on new injectors
- Banjo fittings
- In need of a shop in South Louisiana
- Exhaust
- Intake
- Question about having white smoke
- Edge Insight CTS
- Is The iTSX The Way To Go?
- 10.5/10.25 carrier
- turbo??
- boost fooler?
- what mount pattern????
- spartan or sct
- trick to bump up fuel pressure
- Turbo Blanket????
- questions quad pod install
- Upgrading Turbo and Sticks - need some advice
- new afe intake
- updated PCM and TCM codes?
- SCT X3 issues
- Gauges, Tuner or Both?
- tuner for 6.0
- Safety of my powerstroke
- need some Bully Dog help
- Spinn but no Start
- Still in business
- intercooler
- egr delete?
- garrett powermax turbo
- 4inch downpipe
- Snow or Cooling Mist Water Meth Injec.
- 03 3/4 ton air bags
- Keep stacks, or go with cool duals?
- A true bomb
- Transmission
- Oversize turbo??
- SCT Livewire Question
- Intake Manifold
- Fuel spring mod?
- 6.0 turbo options
- Sinister Coolant Filtration System
- SCT Tuner Issue
- Do I need Oil and Coolant Temp Gauges?
- head bolts 05 6.0 powerstroke
- Regulated Return Kit
- SCT QUESTION
- Edge platinum juice w/attitude for 6.0...
- gear shifter
- What to do first?
- Just starting out
- Superchips Cortex
- Gauge install HELP!!
- silencing ring on turbo and smoke switches.
- coolant kits..
- GOGO's egr delete worth the money?
- Best Air Intake for 6.0??
- headstuds?
- Repaired FICM
- Fire Rings?
- 4:30s or 4:56 with 37's
- programer for my 04 f-250
- Yellow Jacket build thread.
- Do I need head studs with a mild sct tune?
- Best Bang for $
- 6r110
- have a problem
- having a problem
- Keepin SCT off ECUs
- 2.3 CS/CTS
- help
- opinions on water-methanol
- RCD tunes???
- SCT tunes by DFuser
- is 6.0l a good way to go?
- worth it?
- Gauge Pods
- 2.5in leveling kit wat size tires???
- SCT won't connect to computer?
- chips and tranny life
- air dog kit 2005
- Sinister coolant filter kit ... some questions?
- Egr delete ?
- sct x3 tuner?
- Compound turbo or Supercharger
- Which EGR delete?
- blown turbo replacement
- Need help head removal
- Scoop
- 3rd Gauge
- Buying a programmer
- Injector Questions
- custom tuned FICM?
- where to install my oil temp sensor
- new to diesel and have questions
- fuel sump
- wes18 ???
- oil hoses assembly
- Garrett GT3788VA Upgraded turbo
- what tires are you using
- Straight pipe kit?
- Best gauges for 6.0?
- SCT + Edge Juice w Attitude = ?????
- gauges for my psd 6.0
- Egr Delete/CEL Question
- sct
- whos turbos better
- fluttery boost guage
- air dog installation
- Cold air intakes
- air intake help
- SCT WITH INNOVATIVE TUNES
- ARP studs and head gaskets
- no throttle sometimes?
- New Guy to powerstrokes!! help
- whats next?
- Injectors???
- River City Diesel EGR Delete???
- Wats next? 2004 6.0 f-350
- best programmer without headstuds ?
- Cold air intake
- lack of power
- Pyro intall
- MPG??? what should i be getting??? how can i improve it???
- injectors
- which exhaust?
- Sct livewire tune revision problem
- exhaust questions
- Straight Pipe
- Monster 4" Exhaust
- Coolant Bypass and Oil Bypass
- improved exhaust
- ppe programmer
- gauges
- sct??
- autometer
- FICM code, won't start
- Power Hungry Performance tunes
- Turning of EGR valve or Unplugging it???
- REV X
- ARP STUDS and GOOD GASKETS
- tech 2005
- AIRDOG FOR 6.0L
- QUADZILLA ADRENALINE?? FOR 6.0
- Diablosport Predator Custom Tunes??
- Water/Meth Inj for 6.0
- what next
- NY-NJ Area Performance Diesel Shops??
- Gillette Diesel Fuel Pressure Spring Review
- E-350 chip
- Steering wheel
- White smoke pouring out???
- Modified direct clutch solenoid help
- A/C underdrive pulley
- this is a newbe question???
- 05 6.0L
- billet input shaft 5r110
- 6.0 fix it kit?
- Silverline Dual Exhaust
- Mishimoto Radiator & Intercooler Install! 05 F250!!
- Custom Tunes For MPG
- TransGo for a TorqShift
- Cat Converter
- 03-07 PStroke Qzilla with Monitor
- 450-500 HP truck
- need a smoke tuner
- 6.0 complete hopefully
- sct hp gains
- stacks...
- straight exhaust
- Oil cooler
- GoGo Diesel EGR Delete Intake Manifold
- banks IQ w/ six gun
- Body lift for 2006 f-250
- ruff ride...
- blown up.
- PROGRAMMERS
- EGR Delete Work
- Anyone know?
- Were to buy ARP HEAD STUDS
- Best EGR Delete Thread
- 04 f-350 6.0 dually advice
- egr cooler leak
- Thinking about getting SCT LIVEWIRE
- Black smoke
- EGR Delete Kit
- Ford 6L egr valve disconnect
- Friend's tranny
- Upgraded EGR Cooler - question from a rookie
- exhaust differences
- Front end conversions...
- ford 6.0 powerstroke problem???
- Throttle body spacer
- RCD Tunes
- diesel shops?
- Lift for an '07...?
- Edge or Bullydog
- Changing Shift Points SCT
- Christmas Lists
- need advise and input
- 1300+ EGTs
- EGT probe question
- need a list for 6.0
- How to make turbo spool faster?
- Building a 6.0
- dfuser tunes?
- Block off the EGr and Cooler or to remove it altogether?
- Intake Manifold
- Tranny swap
- SCT custom tunes
- negative boost?
- Aftermarket injectors for the 2006
- Edge Juice With Attitude for the 6.0
- EGR delete kit. Is it good or not good
- Innovative FICM??
- 2005 6.0
- Oil Cooler Replace
- SCT 9600 LIVEWIRE Problem
- I got a good one for ya
- Sct Tuner problem
- Which Programmer ???
- OUO Lift Block Traction Bars installed by ORI Yorktown, VA
- What next?
- Record!!!!
- 5R110W tranny pan updates
- Need Assistance
- 2005 6.0 PS turbo/warranty issue
- Another SCT thread
- MBRP exhaust 5" Turbo Back
- 4'' down pipe
- SCT Tunes
- brothers truck
- 6.0l aftermarket exhaust manifolds
- Bullydog pmt???
- Change to ARP without gasket change?
- turbo ideas
- Intake manifold (elbow)
