View Full Version : 1st Generation Dodge Cummins 89-93
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12
  1. Fixing Your KDP On The Cheap
  2. 1st gen auto
  3. Turbo rebuild
  4. gauges
  5. Turns on the pump
  6. injector lines
  7. getrag
  8. 1st gen chassis splice
  9. Trim Holes? how to fill?
  10. tach
  11. over drive
  12. What to look for?
  13. 1st gen motor
  14. hx40 questions
  15. tv81 turbo
  16. 1st gen speed sensor
  17. 1st gen. pulsing voltage problem
  18. Prices of VE pumps?????
  19. Timing bump?
  20. turn key and no start
  21. Auto problems... First loud whirring, then no movement.
  22. Switch on ve pump
  23. front end hops
  24. 2wd getrag VS 4wd getrag
  25. do i qualify?
  26. whats the best clutch
  27. G360 to NV4500?
  28. Harmonic balancer installation Q?????
  29. for all you guys with s300's and hx40's needing a 4" downpipe for a 1st gen truck
  30. dodge w350 will not go over 35
  31. Pump swap
  32. Help little bro put 87 oct in my diesel what to do?
  33. Hx35 and 12cm
  34. BD Valve Body
  35. Best Source for Compressor Wheel...?
  36. top speed?
  37. wastegate question
  38. Ranch style bumpers
  39. TRUCK WONT TURN OVER!!!
  40. POD's
  41. Tranny Problem
  42. Ok. Tomorrow the motor is going to be on the ground.
  43. lift pump robbing power?
  44. good idea or just plain stupid?
  45. spacer for piston pump?
  46. bronze shavings in the tank
  47. Replace Your Camshaft, Lifters 'n Stuff . . . .
  48. 1st gen questions???
  49. heat grid
  50. Timing Advance
  51. mega problems
  52. denny t
  53. getrag shift tower all jacked up
  54. Getrag woes...
  55. fuel lines
  56. rear brakes
  57. 1st gen 1ton wheel cyl
  58. needing some new shine
  59. Cummins B5.9 repair & troubleshooting manual pdf download
  60. classifieds not much there!
  61. hx35 housing the same as hx40?
  62. front brake backing plates
  63. air dog II
  64. Cab Lights
  65. What turbo is this?
  66. Use cruise servo as idle control/hand throttle?
  67. grille guard
  68. vacuum 4x4 motor
  69. hc1 on one ton?
  70. Arm Rest 93 Dodge
  71. block heater
  72. No Lights please Help
  73. body work
  74. Happy New Year
  75. Pump swap
  76. Twins Finally Installed!
  77. Injectors yey!
  78. clutch problem
  79. South Bend clutch install
  80. Retorqueing head bolts?
  81. solvent, oil?
  82. Wait To Start?
  83. Turbo for 5x.014s
  84. Installed new shutoff solenoid, now have power problems...
  85. How tall of tires for 2wd?
  86. Stripped Bolt HELP ASAP
  87. 24v power steering pump on a 12 valve?
  88. Help,broken cooling fan!
  89. Shift kit suggestions
  90. Getrag Grinding
  91. Sticky Articles and Casino Cash
  92. harmonic balancer problem
  93. 5-sp shifting issues
  94. Check Engine Light Trouble Codes For 92-93 1st Gens
  95. Anybody got a 1st gen sittin around? I need a part bad
  96. Need some opinions!
  97. Motor Maintaince
  98. Howdy Guys!!!
  99. Locker for Dana 61
  100. Bouncing speedo
  101. turbo Question
  102. 3rd gen intercooler in a 1st gen.
  103. Brakes don't seem to be power
  104. Best Exhaust Housing for Damon... :)
  105. Cool Down?
  106. power steering????
  107. Speed sensor pics
  108. Vehicle speed sensor
  109. gauge
  110. pod injectors
  111. fenders? Rust?
  112. turbo questions
  113. w350 mpg's
  114. AFE Air filter
  115. Fixing the ride of my 1st gen (or at least making it better)
  116. Aftermarket Speedometer
  117. looking for a diagnosis ??
  118. lost power
  119. Cruise Blues
  120. In Need of Bed for 1st gen
  121. tranny problems
  122. Need some advice.
  123. 370's and 435's
  124. hx40 exhuast housing question
  125. Stock boost?
  126. ...progress...
  127. NHC 250 needs a turbo ?
  128. Troubleshooting
  129. suspension
  130. FUEL ECONOMY
  131. Smoke from flange on turbo????
  132. wont stay in 5th gear
  133. Anyone towing??
  134. smoke
  135. THROTTLE POSITION SWITCH PROBLEMS
  136. bigtime problem
  137. 6bt exhaust flange
  138. governor problem???
  139. manual locks and windows to electric?
  140. Getrag Shift Kit?
  141. power steering fluid foaming and expanding
  142. napa clutch or southbend clutch?
  143. Problem Fixed
  144. 81 Dodge Crew Cab Cummins project
  145. voltage regulator woes
  146. Lowering?
  147. Shift kits?
  148. spare 12v cummins
  149. hx35w v-band flange????
  150. nv4500 rattle (forks or throwout)
  151. getrag
  152. No Charge From The Alternator.
  153. 4 gear ?
  154. what turbo should i upgrade to?
  155. I am curious
  156. Lights problem
  157. boost screw on pump
  158. Hx35w
  159. Overfill?
  160. CD player
  161. Gears
  162. driveshaft length
  163. Turbo upgrade Sugestions
  164. Insulation?
  165. First gen cummins No spedeometer or wait to start light
  166. how to beef up a getrag
  167. No spedometer or wait to start light in 91 cummins
  168. Transmission cooler with fan under box
  169. rebuilding injectors
  170. Which Fuel Pin
  171. plastic trim parts for a First Gen
  172. Plastic trim for wheel wells
  173. Front Drive Shaft
  174. Hey Smokem
  175. cab mount bolts
  176. New Member with a new truck and a question
  177. 93 dodge trans cooler/under bed??
  178. Intercooling my 91.0
  179. How much is it worth?
  180. shut off solenoid
  181. shaving stock fuel pin
  182. My 93 on the rollers
  183. 14cm Turbo housing and 60mm housing
  184. Hood stack
  185. Seats
  186. switch from auto trans to getrag
  187. Intake manifold
  188. need some input
  189. 14cm turbo housing
  190. new here with a turbo question. need help asap
  191. Finally got one
  192. Primer
  193. tachometer
  194. turbo
  195. Fuel pin pics
  196. cummins 855 turbo
  197. exhaust
  198. Well Im pretty sure my torque converter took a $#!@ today...
  199. Virgin pump?
  200. TPS
  201. the inside of the getrag
  202. Auto OD question
  203. Gauge pods
  204. Transmission Swap
  205. Fuel Pin Videos
  206. 4" exhaust system for cheap?
  207. Crazy Fuel Pump
  208. Billet Adapter Plate?
  209. Stock truck with bottomed out star wheel?????
  210. gov spring 3200?
  211. GDS 60mm upgrade vs hx35
  212. replaced inj. pump
  213. Fuel pins
  214. Truck Value
  215. Adding Boost?
  216. How far did you guys go before losing MPG?
  217. looking at buying a 1990 Dodge
  218. Clutch assembly
  219. help with pump timming
  220. Wiring wierdness Or How Many regulators does it take to ......
  221. Hood Stack on a '92 truck to play around (opinions needed)
  222. Tranny
  223. 1989 Dodge Cummins Commercial
  224. K&N air filters
  225. non-ic injectors ID
  226. Installed HX35w 12cm. Where is the shove in seat?
  227. converting from ve to p7100
  228. Fuel pressure guages.
  229. VE full load screw
  230. Put pot in my 91 and still no OD
  231. Oil Leak
  232. HX35 vrs stock head gasket?
  233. vehicle speed sensor question
  234. fuel inlet
  235. injector pump timming
  236. Little help for a fellow bomber
  237. 91 cummins for sale
  238. 4x4
  239. fuel system
  240. cold = dead battery?
  241. transmission
  242. getrag
  243. Christmas came early!!!
  244. Its video time again
  245. 91 D-350 has no od
  246. airdog II question
  247. killer pin
  248. starter
  249. non IC hp over IC injectors?
  250. Fuel Pin Question
