PDA
View Full Version : 1st Generation Dodge Cummins 89-93
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18
  1. rearend problems
  2. Turbo help needed asap!!!
  3. Second gen bed, first gen truck
  4. 46rh that is jumping in and out of OD.. but will stay in OD at 65mph or more.
  5. Getting that Cold A/C
  6. questions about tires
  7. Need wheels!
  8. I WILL put a forward facing rear seat in a club cab. Help me out!
  9. Odd question
  10. New seats and interior mods
  11. Fuel screw..
  12. M3 fuel pin
  13. Adjusting throttle pedal
  14. 518 to 47rh swap questions
  15. New HG....now won't start?
  16. Need some cummins parts...
  17. How can I tell if I have a 47RH?
  18. too much smoke!!!!
  19. 90 motor in my 93 truck?
  20. Help!!
  21. wheel well cut outs
  22. A518 tech questions and fuel pin advice
  23. Exhaust questions
  24. HOW MUCH DO YOU KNOW CUMMINS QUIZ
  25. desperate for professional help!
  26. swapping slushbox for a getrag question
  27. Help with fuel problem out of state
  28. 1993 nv4500 swap
  29. Cat Filter System
  30. A518 price
  31. Warped oil cooler?
  32. oppinions please.
  33. Can't get my idle down
  34. wheels
  35. Injector prob. Need help
  36. Cracked block?
  37. Excessive fuel Consumption
  38. 727 trans question?
  39. Rotary pump
  40. 1990 p pump conversion upgrade questions
  41. need help front end vibration when i hit a bump
  42. 1992 dodge w250 cab bushings
  43. a518 2nd to 3rd shift problem
  44. first gen cooling issues
  45. Let's see yall's Flatbed's!!!!!!
  46. egt too high?
  47. 92 5speed turbo housing?
  48. blown headgasket
  49. what does it take to rebuild a tranfer case
  50. tranny coolant line
  51. hx35 oil return line gasket
  52. Any Ideas: Truck problems
  53. A Newbie Looking To Modify
  54. solve the transmission mystery
  55. 91 4x4 auto can't seem to fix overdrive!
  56. gauge cluster????
  57. Won't warm up?
  58. can I run a open thermostat
  59. i need a cummins mechanic. oh & sum 1 to go racing with
  60. Brake problem after lift/kingpins/steering/37's
  61. will these fit my truck
  62. AFC Spring missing
  63. Removin a powersteering pump
  64. Baldwin filter part numbers?
  65. smoke ??
  66. truck running hotter and oil pressure suddenly higher
  67. High Idle switch for 92 12 valve help please
  68. Diff in intercooled&non intercooled vepumps
  69. voltmeter surging
  70. Hx 40 hybrid or 7 blade wheel
  71. 1st gen frame
  72. options for new brakes...
  73. TPS Delete Problems!!!
  74. Reality versus Fantasy
  75. hx35 crossover pipe???
  76. vepump info needed
  77. tranny temp?
  78. New to site
  79. engine wiring
  80. New Injection Pump
  81. hx35 swap
  82. Need to find a good vepump to build
  83. after market wheels
  84. Fuel Screw
  85. 2nd gen inter cooler swap?
  86. Found a sorce for aftermarket fuel tank sending units. Cheap aswell.
  87. Fuel Getting In AFC
  88. piston lift pump?
  89. adding a intercooler to my 90' cummins
  90. need crossover tube dimentions please
  91. is 40lbs boost to much for stock headgasket and studs?
  92. Diesel filter?
  93. how can i tell if my truck is lifted?
  94. ATF's
  95. full fuel screw bottomed
  96. What got done on your truck today?
  97. A-518 transmission questions and concerns
  98. Getting mod ideas
  99. Pulling the cab
  100. What does is this wire supposed to be connected to?
  101. Draw straw cherry
  102. Always wanted a cummins. Now I've got one.
  103. boosting issues
  104. Nv4500 swap and driveshafts
  105. corporate 14 bolt
  106. Twin turbos on a 1993 cummins
  107. 6 speed swap
  108. No Cruise
  109. AFC Banjo Bolt
  110. What would I need to swap?
  111. 1991.5 First Gen Cummins
  112. ID this part please!
  113. truck meet (cummins mainly)
  114. 1st gen died and won't start back
  115. Get Rag still grinds!!! ahhhh!! help!
  116. performance upgrades
  117. Turbo Sizing Question
  118. Keeps Jumping in and out of overdrive
  119. broke speedo???
  120. Turbo Upgrade question
  121. Stock tach problem
  122. drive pressure
  123. Dash lights
  124. weird issue....
  125. any dana 71 locker options?
  126. denny t?
  127. Tips on buying a used 93' 5.9L engine
  128. Fuel shut off solenoid shorted to ground..
  129. A Different Idea
  130. 518 problem has me baffled
  131. My ball joint is bad now what?
  132. common problems
  133. hello
  134. 06 turbo on 93?
  135. Body Swap
  136. Throttle rod end.
  137. 89 ve pump help
  138. first mod advice
  139. Dyno March 25th
  140. Need VE Pump Top/Parts
  141. Denny T AFC Delete Top
  142. Some questions, Fuel lift pump/vacuum/timing
  143. Procharger build
  144. 89 Bosch VE Service Manual
  145. 2nd gen power steering pump on a 1st gen?
  146. New here and looking for some advice
  147. What kinda power? What to look for?
  148. parking brake cable collar
  149. non intercooled vacumm pump seal kit
  150. How big of gains can I see with a different I/C?
  151. dash cluster rebuild
  152. 91 cummins 12v info
  153. Installing injectors
  154. HC1 Upgrades???
  155. Will it hold up?
  156. Powerstroke intercooler
  157. New Truck, New Problems.
  158. 1993 W250
  159. Paint
  160. dyno problems
  161. How do I get rid of the smoke?
  162. needing info
  163. Body lift!!
  164. TPS specs
  165. EGTS too low
  166. 1991 cummins 2wd dually auto.
  167. charging problem
  168. 91 2 wheel drive long wheelbase for sale
  169. Broken turbo, H1C
  170. Show Me Your Exhaust!!!
  171. heatercore removal problems
  172. Confusion with rear driveshaft center bearing
  173. Pic of where the injection lines go?
  174. ve pump banjo fix?
  175. 1st gen tps
  176. POT in place of TPS
  177. 500 ft-lbs from pump tuning?
  178. 91 Intercooled wont charge!
  179. Low Voltage
  180. tach instal kits
  181. need a performance lift pump
  182. Timing Spacer
  183. positive battery cable and end needed.
  184. Hello
  185. custom decals
  186. Starting issues
  187. thinking i need a heater core....
  188. Factory lift pump
  189. Injection Pump Issues Again...
  190. steering shaft
  191. steering issues.
  192. steering box
  193. steering box
  194. Heater fan doesn't work, on heat but it does on others.
  195. Auto to NV4500 Conversion
  196. Looking for performance mods advice
  197. Replacing headgasket
  198. Help Identify Injectors
  199. Emissions Failure 2
  200. Help with anyone looking for banjo bolts
  201. 89 VE pump Rebuild Help
  202. had a wreck need parts
  203. Factory Grill
  204. putting exhaust brake on
  205. 93 terrible brake pedal
  206. Cross Oversteering?
  207. Full power screw won't turn in
  208. Truck may be up for adoption
  209. overdrive
  210. 4K Gov spring?
  211. Egt's
  212. Should I buy this truck??
  213. Part Priority Help!!
  214. KBB Says
  215. pyro install
  216. New injectors
  217. Timing spacer
  218. O.D. whining
  219. 1st gen. 12v to chevy swap
  220. anoyone know if this visor will fit?
  221. will these lugs work?
  222. transmission parts
  223. full power screw?
  224. will reg cab doors fit onto a ext cab body.
  225. 1991 CUMMINS W250 LIFT????
  226. 4wd conversion
  227. 93 First Gen mods??
  228. What do you guys think about this?
  229. Fuel Gauge
  230. Denny T Pin
  231. Fuel Pin problems
  232. Eaton Fuller 10 Speed?
  233. New to this 1st gen's, need some help.
  234. drum brakes to disc brakes?
  235. Roll Pans
  236. not your usual OD question
  237. controling over drive and lockup
  238. 1st gen with 303k should i buy it?
  239. H1c compressor outlet
  240. 1992 d350 powerhouse!
  241. LAST DAY
  242. Cracked window
  243. Falls on it's face in 2nd gear?
  244. Silencer Ring
  245. PUSH ROD COVER GASKET
  246. DIY Upgrades?
  247. Governor Spring swap problems
  248. What you got for shifters guys?
  249. volt gauge and lights
  250. Leveling kit
