PDA
View Full Version : 1st Generation Dodge Cummins 89-93
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18
  1. Fuel Gauge
  2. good pump rebuilder????
  3. 1993 dodge w350..alternator will not charge
  4. ve pump question
  5. OD on A518.
  6. 3200 Spring video
  7. Tail light interchange
  8. Time to rebuild
  9. fuel leak
  10. 92 cummins runnin like crap
  11. Brand New ip
  12. New Paint
  13. What about swapping cabs
  14. Injection pump question??
  15. Firstgen wiring diagrams
  16. how to prime a first gen
  17. help
  18. Turbo Question
  19. low power
  20. IP shaft endpaly
  21. help
  22. Pillar Pod
  23. water methanol vs intercool
  24. 4200rpms!!!
  25. VE conversion
  26. Toasted Axle
  27. Extended linkage travel question?
  28. Headgasket Going?
  29. pricing info for 1st gen captains chairs
  30. New first gen,bad brakes..
  31. Crew Conversion Started
  32. 12 valve missing with white smoke
  33. front ball joints
  34. 1st gen and p pump parts together
  35. Southbend Clutch
  36. Will this turbo fit?
  37. Give me a hand with this.........
  38. By passing fuel heater?
  39. moog 7226s springs
  40. lens
  41. what harmonic dampner are you using at 4000rpm?
  42. Swapping a nv4500 into my 1st gen help
  43. 2nd Gen DP on a 1st gen?
  44. Conversion question
  45. need pump help
  46. bummed
  47. Hola, new diesel user aboard!
  48. Downsides to Changing Timing
  49. Manifold Heater
  50. Off road Diesel
  51. Big Coolant Problem
  52. 93 cummins build
  53. 91 w-250
  54. Think I Killed My IP Pump
  55. What does it take to install "tophat" valve seals?
  56. Performance injectors
  57. turbo swap
  58. 5.9L specs 83-93
  59. why does the '94 -'98.5 have a larger harmonic balancer?
  60. Getrag problems, parts needed.
  61. Dual VE's
  62. Speedometer reading incorrect speed
  63. no speedo or od
  64. 91' 250 spedo/overdrive clstrfk
  65. Need help no ac or power windows
  66. Fuel pin install thread
  67. blew the tranny
  68. Parts interchange
  69. put 2nd gen seats in today...
  70. tranny bucks
  71. Tachometer Output
  72. Steering shaft
  73. Bench seat covers
  74. pulled home by a 6.2l
  75. Govenor spring istalation instructions please
  76. injector cores
  77. 93 CTD severe injector pump leak
  78. Larger Injectors
  79. more power
  80. Which dana 70 is it?
  81. M&H timing spacer
  82. Starter Issues
  83. Turbo housing shenanigans
  84. rearend gears ??????????????
  85. Thank you DB and Denny T!!!
  86. Is removing the afc worth it?
  87. 1st Gen seat questions
  88. I want a sleeper!!!
  89. New project with pics
  90. First Diesel build advice.
  91. Trans Case Differences
  92. Tranny install, need flywheel bolts AZ
  93. Power Window Problem
  94. exhaust manifold needed
  95. Can someone tell me whats wrong with this thing
  96. 6bt dakota build log with pics
  97. i would like to trade my 78 dodge
  98. please help confused
  99. internal pump pressure
  100. VE high pressure fuel distributor leak repair
  101. 4x4 tilt steering column
  102. worth it?
  103. radio wiring
  104. Tuning Question
  105. 93 Wheel Hubs?
  106. whats nessicary to install guages?
  107. New 12v
  108. Won't start without tapping on the inj pump
  109. Clutch?
  110. Grilles?
  111. Help With My Brake Problem
  112. Injector Pump Rebuild
  113. synthetic oil
  114. engine numbers
  115. Truck Shaking Real Bad
  116. Speed sensor/Cable driver
  117. 1993 dodge ram steering coulumn
  118. please help guys i need a turbo used from you
  119. Dana 60 question
  120. what is the best turbo
  121. Exhaust what sounds the best in your opp?
  122. Injector size question.
  123. what size aree the door speakers in a 93
  124. Help
  125. what is a good price for a valve adjustmen at a shop
  126. Pillar Pods for 1st gen
  127. fuel pressure regulator for piston pump
  128. intake system
  129. Hard-to-Start/No Start '90 CTD
  130. a few questions i have about stacks???
  131. first truck!!!!!!!! (new to the site)
  132. Fuel Pin Wanted
  133. weird clunking feeling
  134. Okay guys just tell me what to do GETRAG 360 is trashed
  135. P-Pump conversion........
  136. posi
  137. Getrag Breaking Point?
  138. front bumper
  139. No overdrive and engine temp question
  140. oil pressure
  141. Power steering pump replacement
  142. oil pressure
  143. Idle question!
  144. how to make your non I/C Truck an I/C Truck
  145. OEM Ball Joints
  146. throttle linkage
  147. water coming into cab...Where?
  148. need help and fast....
  149. Help with 89 D250 hard start
  150. Power Steering Leak (HELP!)
  151. Bed corner repair?
  152. Wa state emissions test required.
  153. Manual switch for O/D?
  154. 2nd gen duals on a 1st gen
  155. question on buying a 4 inch exhaust
  156. Bipolar Engine Temps
  157. 1992 Dodge MPG Drop
  158. drop down pitman arm
  159. HELP!!!!!!!!!!!!!
  160. Rewiring Cruise control
  161. 93 cummins
  162. 1st gen intercooler vs 2nd gen intercooler
  163. 1993 fuel tank size please
  164. at my wits end with this front end
  165. new pods
  166. 1989 6bt Marine application
  167. Hey Guys... Heads up....
  168. Fuel Pressure gauge
  169. Poly brushings for a 89 dodge
  170. 89 dodge reg cab long bed
  171. A/C question
  172. Info on this truck?
  173. Question about turbo.
  174. Need help> 91.5 w30 has no power
  175. radiator
  176. Thoughts and opinions wanted on twins.
  177. Performance Upgrades??
  178. Which fuel pump?
  179. new injectors
  180. Replacing Your Fusable Links With Fuses
  181. vaccum pump question
  182. need some help on a trans swap
  183. Maximizing Fuel Economy on the Cummins 6BT
  184. injector research. what ya got?
  185. Starting problem
  186. 93 is done,, finally.
  187. Twin Turbo using only Cummins sourced Holsets... Possible?
  188. Electric pump?
  189. OK so my truck is freakin out man
  190. Oil pan ?
  191. Transfer Case oil
  192. Coolant Temperature Sending Unit?
  193. First gen dodge speedo trouble
  194. Colum pod
  195. intercooler options
  196. hx35w on non IC
  197. Leaking Inj. Pump
  198. Fuel shutoff solenoid
  199. This May Not Count....
  200. Quick intercooler Question
  201. Time for new turbo, Recomendations?
  202. Door Panel Clips for 1st Gens
  203. Built 727?
  204. Intercooler
  205. Brake lines replacement
  206. Injection pump dying?
  207. Cummins T-stat
  208. My Vents dont switch
  209. Deer vs. First gen
  210. 1st Gen. Tachometer???
  211. bell housing
  212. Exhaust temps
  213. need help truck smokes bad
  214. Fuel Line Size?
  215. Injector Swap
  216. 12V for son ....help!
  217. how much
  218. Exhaust Valve Photos... how do they look to you
  219. Plug in by the hood release handle
  220. dash lights
  221. How to put the power to the ground?
  222. beef up my auto trans
  223. HX35?
  224. wait to start light blinks and grid heater acting weird
  225. Will not shift into OD with the 'WAIT TO START" light on
  226. need some info on a tranny swap(auto to 5 speed)
  227. Not shifting to Overdrive
  228. HELP!!! Steering problems!
  229. install a 1st generation in a 89 wagoneer
  230. tell me the difference
  231. Badass 1st gen
  232. HELP!!! What Trans??
  233. You first gen lovers dream work truck!
  234. Mirrors
  235. QUestions about temp and pressure
  236. Not the kinda rattle I expected
  237. What sensor is it?
  238. RPMs at Idle
  239. A dumb turbo question.
  240. baffle in my turbo is this true?
  241. Allison 751 is it worth a crap
  242. new toolbox and stack what do you think
  243. 3 speed no overdrive
  244. what is this part?
  245. New Paint *pictures*
  246. Radiator removal
  247. Hard Starting 90 D250
  248. over heating
  249. Vacuum pump
  250. Lifting The Front End
