PDA
View Full Version : 1st Generation Dodge Cummins 89-93
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18
  1. Where to get Throttle Cable
  2. Wheel offset
  3. how to lower my idle
  4. Brakes and ABS question
  5. lift pump leaking
  6. Getrag 360 top cover
  7. fuel filter
  8. Introducing the 1990 SUPERGOAT!!!
  9. Tailgate Rod Connector
  10. farm truck worth the money?????
  11. Nylon Washer...
  12. Rhino Lining
  13. BIGREDGOAT
  14. Whats wrong?
  15. thinking i have an electrical draw some where
  16. Trannsmission idea
  17. Hitler 6 wheel mercedes with cummins engines
  18. Wipers
  19. removal of badges on side and hood of truck
  20. Lift pump upgrade
  21. Speedo works but Odometer doesn't
  22. smoke screw
  23. steel rims
  24. Can Someone tell me what these wires go to??
  25. Hood Ornament
  26. possibly a dumb question
  27. help i have a ? about a tranny swap.
  28. 1992 Steering wheel
  29. 89 Intercooler
  30. Will this fit a non i/c?
  31. Transmission removal
  32. ''53'' block?
  33. Power steering, oil pressure gauge problems
  34. engine swap
  35. Tire size
  36. throttle
  37. low fuel light
  38. Overdrive Problem on my 93 dually
  39. Are you guys adding
  40. any one have cltuch pedal assembly??
  41. Help with speedo
  42. Electronic fuel pump question
  43. 89 stump
  44. ABS and emergency brake stuck on
  45. killer dowel pin
  46. NV4500 plus all other running gear from a V10?
  47. Alternator Surges
  48. 91 turbo problem
  49. Gauges and Fuel Line
  50. oil leak
  51. Gasket kits for 1993
  52. Need Suspension Help!!!
  53. EGT---what is too high??
  54. clutch
  55. Lowering a 4x4
  56. Skinny tires
  57. 1992 12v lights pulse at idle
  58. Trans noise
  59. locking hub is broke?
  60. Pretty sure Tranny's shot
  61. boost guage
  62. what is a good intake(cheap budget)
  63. findind tdc
  64. Y do some 1st Gens have cab marker lights...
  65. Shifter Knob
  66. valve adjustment help
  67. pin striping
  68. Gearing with 37s.
  69. Tranny Advice Please
  70. afc spring missing
  71. 5.1 apply lever
  72. how hard is it to put in a 47rh in a 92 w350 reg cab
  73. aftermarket lights
  74. 93 turbo upgrade???
  75. Alignment
  76. Sleeve Puller
  77. leaking water
  78. 1993 W250 for trade
  79. Need help. Top Dead Center Pin wont engage
  80. ECM problems
  81. Blowing fusible links
  82. wire diagram
  83. P pump swap question
  84. installed new boost gauge and... is this normal?
  85. rims and tires
  86. New Injectors
  87. Best muffler for my 1st gen
  88. Alternator Guage?
  89. Truck quit White smoke
  90. which kit would you choose?
  91. speedo stopped working, 4x4 light stuck on quick question
  92. tranny question
  93. 93 1st gen 5spd
  94. Wiring wastegate shut
  95. UPS just left some goodies
  96. Quick question??
  97. injector pump question
  98. Turbo for my 1st gen.
  99. Fender trim
  100. Biggest injectors
  101. first gen parts
  102. single wheel to dually conversion
  103. any truck meets around l.i area??
  104. how can I get better mileage
  105. Need to clock my turbo - frozen up?
  106. are my grid heaters going bad?
  107. LIft Kits?
  108. Injector hold down nut torque spec
  109. chevy nv4500 to 1991 cummins
  110. power steering gear box from 1988 ramcharger for sale
  111. ATS Diesel 618 Stage II Transmission?????
  112. Steering shaft issues please help!!!
  113. New to forums and New to diesels
  114. Where to buy stock wheels & tires?
  115. New Truck?
  116. fuel leak 1993 ram 2500
  117. ISSPRO Tach Part Number
  118. no power
  119. more horsepower
  120. Got a New Truck!
  121. HY35 oil line threads different than H1c???
  122. I can hear my turbo!!!!
  123. Not Sure?
  124. LOOKING FOR SPONSORS
  125. What trans is this?
  126. TURBO QUESTION
  127. EGT & BOOST ?
  128. Brake issue
  129. New to the Dodge world!!
  130. spec vs gauges
  131. Pickup bed hoist. Got one?
  132. 90 w250 with 93 motor
  133. bumper
  134. Two questions
  135. A quick question!!!
  136. Is getting rid of VE pump worth it?
  137. PAINT
  138. Quick fuel filter question
  139. Front drive shaft
  140. Custom Headliner
  141. wring issues
  142. interior
  143. 92 tranny problem
  144. oil type?
  145. fuel
  146. HEADLIGHT ADJUSTMENT
  147. Should i put seal kit in with 3200 spring?
  148. Need New battery
  149. 1992 d250 Front end sagging
  150. 46RH problems
  151. Bottom oil drain gasket on turbo
  152. clutch doesnt disengage
  153. steering box removal
  154. oil pan gasket
  155. Cablights
  156. Bellhousing cracked
  157. need help fast trans problem
  158. HELP WITH DIMENSIONS
  159. HELP!!!! electrical problems
  160. trans broke
  161. Throttle screw
  162. Getrag Fill Plug
  163. intercooler swap
  164. flickeering lights
  165. non-intcooled turbo on a intercooled truck?
  166. weird turbo noise
  167. I want cruise control again
  168. Paint Ideas
  169. A518 questions
  170. Electrical deamons- only when its near freezing or warmer?
  171. which one?
  172. denny t stage 1 or 2???
  173. want a 1st gen
  174. ve no power after 3200 gov spring install
  175. newie ques
  176. HELP
  177. How can I tell?
  178. Whats a better t-case setup?
  179. fuel screw help
  180. More speedo problems
  181. HX35 help
  182. Grid heater
  183. Do you really need it
  184. thinking about buying one
  185. Master cylinder
  186. I think ignition problem
  187. 3rd gen downpipe?
  188. straps and bolts for u joint
  189. blinkers
  190. U-joints
  191. No Tag what gears do i have? 3.07 or 3.54
  192. block heater???
  193. Read before messing with full fuel screw
  194. need some info
  195. A/C compressor locked up
  196. Bad Injector Pump?
  197. Odometer not working
  198. TPS delete
  199. 92 idles very rough, smokes, and has no power.
  200. One sweet 1st gen!
  201. front end rattle
  202. help hooking up valet switch
  203. 90' 12V 5.9L Cummins Power & MPG
  204. How many cablights?
  205. Warn Winch Bumper
  206. turbo help
  207. fuel pin
  208. What's next?
  209. powerstroke ic help
  210. TV cable
  211. GRID HEATER QUESTION
  212. P PUMP SWAP DISCUSSION
  213. having trouble with some parts
  214. white smoke wear it shouldnt be!
  215. cummins in a chevy
  216. Performance parts for first gens
  217. TPS delete
  218. non-intercooled injectors
  219. new front leaf springs
  220. 93 not as quick as i think it should be!!!
  221. intake box
  222. Injector #5 Leak
  223. 92 hot soak start problem
  224. DragSTRIP Video
  225. Cylinder # 6 not working please help
  226. I think I have a fueling problem?
  227. shifter handle od switch
  228. '93 pcm Voltage Regulator Overide Help!
  229. tach
  230. Gauges help please
  231. tranny pan - warning light
  232. Ksb needed or not
  233. 1993 2500
  234. New Guy Questions
  235. P-Pump Swap
  236. Timing
  237. KSB ?
  238. Who knows where i can get a potometer
  239. Getag shifter
  240. Boost? Hissing
  241. Found truck have questions
  242. turn signal problems
  243. Check Engine light came on and the alternator gauge is low
  244. Slave cylinder question
  245. Getrag fluid
  246. Looking 4 Parts? - Check in Here
  247. Aftermarket bumpers
  248. Injector upgrade
  249. blow-by?
  250. 2wd to 4wd
