View Full Version : 12 Valve 2nd Gen Dodge Cummins 94-98
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19
  1. how many miles on your truck? ever any compresion problems?
  2. best injector cleaner
  3. Hello, y'all
  4. steering/brake issues
  5. NEW TPS
  6. 5th gear nut
  7. Changing mods
  8. truck keeps losing prime! where to start?
  9. nv4500 bellhousing
  10. gears I.D.
  11. Truck dies when in gear
  12. replacement fuel filter with out a drain
  13. Truck wont start after swapping to 5speed.
  14. engine pix request.
  15. 12 valve fuel mileage
  16. Need socket sizes!
  17. pump diagram
  18. Clutch break in period??
  19. 12 valve wont start!!
  20. Electrical short?
  21. heating problems
  22. No Power
  23. head lights on 94
  24. here is one for ya
  25. truck died wont start back up replaced lift pump
  26. what is it? timing?
  27. No overdrive
  28. torque converter lockup switch??
  29. 96 12 valve wont idle, gray smoke
  30. turbo question
  31. just got a cummins, have some questions
  32. gauges wont work & gearing issues my first cummins in need of some help.?
  33. Bad 4th gear syncro's, whats the prefered method of changing them?
  34. Installed new cummins thermostat...
  35. kdp problem
  36. injectors
  37. oil leak
  38. 1998 dodge 12 V start problems
  39. 94 12 v dies
  40. nv4500 tail housing
  41. new to diesel bombers but on my second cummins need a little help
  42. 1998 12 valve 2X4 2500 fuel milage
  43. 12 valve high egts
  44. tps????
  45. 96 12valve auto vs 96 12valve 5 speed
  46. rough idle
  47. keep your 12 valve save money
  48. headlight problem
  49. Gearing for 37's???
  50. my truck has a miss
  51. dies while driving down the road
  52. Oil Pressure/Supply Questions
  53. new to diesels need help
  54. fueling at wot and afc tuning
  55. blow by tube
  56. Check oil in transfercase?
  57. Shopping spree today...
  58. radiator wanted
  59. Starting issue
  60. 5 speed question
  61. tranny temps??
  62. having trouble settting timing
  63. Tranny fluid and transfer case fluid question?
  64. stock tranny
  65. painted 94-02 wheels
  66. need help about overdrive ground switch
  67. head gasket
  68. trans acting up
  69. Auto Trans
  70. Injectors
  71. any 47rh experts out there?
  72. 94 12v bad tps...replace with new still bad
  73. Oil leak 95 12 valve
  74. slightly bent aftercooler
  75. Auto Trans mod for 12v
  76. L.E.D. Taillights
  77. hard starting
  78. what the sound mean?
  79. 47re output bearing failure
  80. p7100 pump ofv?
  81. Shifting problem =/
  82. won't start this morning
  83. worn bell crank
  84. alternator charging problem
  85. no overdrive any suggestions ??
  86. injector miss
  87. HELP
  88. truck won't start, there's smoke but no fire
  89. NEW PARTS
  90. Weird Feeling when turning
  91. throttle linkage?
  92. p-pump problem
  93. help fuel leaks
  94. correct fuel pressure readings
  95. oem number on 97 p7100 pump
  96. 12 v cracked block
  97. Intermitant stalling - fuel shutoff?
  98. Hold Down For Battery
  99. Alternator Isn't Charging Bad ECU need help plz!!
  100. Tappet cover
  101. Running kerosene, timing issues...
  102. head shaved 20 thou. 10 thou. gasket, will the valves hit?
  103. need some help on my 12 valve!!
  104. hehehe, did some drifting :')
  105. Hard Starting and white smoke.
  106. NV4500 Swap
  107. Blown Head Gasket?
  108. Brakes
  109. woodnpig
  110. 60lb valve springs install
  111. 12 VALVE FUEL PLATE
  112. reasonable amount of labor to pay?
  113. i need a bigger hammer
  114. fuel leak
  115. nv4500 -- 4th gear
  116. 5.9L specs 94-98
  117. has anyone made a "how to set p7100 timming" video?
  118. 1939 Dodge 1.5 Ton Flatbed Build thread
  119. Gov Spring
  120. woodnpig
  121. Questions
  122. Break away bolt?????
  123. Help with AFC ?????????
  124. Steering play
  125. where can i get this fuel line (pic)
  126. Need some tools for the NV4500
  127. 1994 D valve question 191's
  128. oh the choices
  129. no start
  130. Bunch of question 98 12v
  131. tranny exchange cooler
  132. Making 94 Dodge Diesel the Bomb
  133. intercooler relocation
  134. MBRP straight pipe?
  135. Have you removed your fuel heater?
  136. heater delete
  137. Timing case repair (dowel pin)
  138. diff/axle
  139. Sleeved 98 12v
  140. Trans wont shift
  141. Lift Pump Symptoms
  142. Free Technical Article on the Cummins Lift Pump
  143. Maunal trans guys...
  144. tranny swap
  145. 4x4 issue please help!!!
  146. Oil question
  147. Normal or about to explode?
  148. What is this and what does it do?
  149. Are all 12v heads the same?
  150. 98 12V fuel additive
  151. 95 12valve advice
  152. banjo bolts off 24 valve the same as 12 valve?
  153. are they banjo bolts?
  154. need specs on 1261 CPL
  155. could the cylinder head survive this?
  156. Twins HELP!!!!!
  157. 1996 dodge with factory 24 valve?
  158. afc housing
  159. Leak Down with Head OFF
  160. can you lock the p7100 in position?
  161. where to put timing
  162. Turbo Questions
  163. help!!!
  164. Help
  165. lower egts
  166. front end screetching sound and wobble
  167. Help with injector #'s
  168. 94 automatic trans
  169. nv 4500
  170. woodnpig
  171. NewTPS
  172. timing question
  173. Injection Lines
  174. truck will not start. figured out the problem.
  175. transmission
  176. Drive belt/Serpentine belt tensioner
  177. automatic transmission for sell
  178. trans ??
  179. Gears, etc...
  180. timin on a ppump
  181. Afc mods
  182. 97 12v How to turn up pump?
  183. HELP 97 3500 Cummins 4x4 ext. cab
  184. HELP NO 5TH OR REV.
  185. pump question
  186. ATF all over the bottom of my truck?
  187. How to remove cam (part way)
  188. How to fix the KDP (part way)
  189. need smoke
  190. Hardly any fuel to #1 cylinder
  191. Need 2WD drive shaft help!
  192. New Truck
  193. p pump question
  194. another timing ? help
  195. LOL, i'm stranded !!!!
  196. No Oil According to Dipstick
  197. Synthetic oil question
  198. 24 to 12
  199. TPS
  200. Throttle cutting back
  201. death wobble like a mother on new suspension HELP!!!!!
  202. The Best Timing Setting
  203. Freeze plug install
  204. engine shake
  205. power to manual windows
  206. tranny ?
  207. Rumour ive heard
  208. AFC Question
  209. starting problem
  210. dies at idle
  211. how to turn up a p7100 injection pump
  212. fuel plate for mileage
  213. ring and pinion question
  214. Found a truck but is it a deal?
  215. newcomer help
  216. Fuel oil
  217. P7100 gov arm adjustment help needed
  218. Order List
  219. #6 dv gone ???????????????
  220. bucking and kicking
  221. Vacume lines from transfer cast to engine
  222. new 1995, what should i do?
  223. Added consumption with following mods...
  224. very loud poping out of intake need help
  225. NEW TRUCK!!!
  226. Fuel tank mounting hardware?
  227. i have a new oil leak
  228. rocker panels
  229. can someone measure their springs for me?
  230. no more slushbox
  231. fuel screw help
  232. wiring
  233. Racing a Ford
  234. AFC adjustment
  235. Why does my truck make a popping sound?
  236. need help making a decision
  237. Stalling problems
  238. voltage problems
  239. Oil leak need help!
  240. dana 70 rebuild ?????
  241. pcm
  242. Bump up my timing
  243. tranny temp light
  244. copper spray
  245. dclemens
  246. Fuel system problem
  247. Timing and KDP
  248. Battery Not Charging
  249. Installing Tranny temp sensor advice?
  250. dropping RPM's
