View Full Version : 12 Valve 2nd Gen Dodge Cummins 94-98
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19
  1. HELP
  2. Transfer case parts
  3. will tires hold,not load rated
  4. fleetguard filter number
  5. 3rd gen mirrors
  6. help on tranny
  7. WHEEL SIZE?
  8. FUEL MILAGE?????
  9. creeking from the front end
  10. how much power
  11. 04 cummins vs 96'
  12. back flushing coolant
  13. tool to remove injecectors?
  14. HELP!!!!!!!!!!!!
  15. fuel tanks strap
  16. tranny temp. or fuel pressure?
  17. short bed frame
  18. Waste Gate Question
  19. throttle
  20. removing fuel plate
  21. dodge ram keyless entry
  22. Why?
  23. turbo spool
  24. 1995 ram 2500 2wd ctd
  25. afc housing star wheel won't turn
  26. Need Suggestions on NV4500
  27. 1st steps to a fast diesel???
  28. want to buy a dodge?
  29. wierd problem starting, NEED ADVICE
  30. Fuel Gauge Not Working
  31. Fuller RT610
  32. Problem starting
  33. AFC housing break off bolt
  34. luk clutch?
  35. Money pit.....BALL JOINTS
  36. engine serial number - where to find
  37. turbo brain fart
  38. HELP! What's wrong with my truck?!
  39. Transfer case question
  40. new truck, need power
  41. boost
  42. turbo wobble
  43. Converting an auto to manual
  44. voltage
  45. help
  46. Questions
  47. 12 valve
  48. clutches??
  49. Max Boost on stock 96 12v turbo
  50. some help.
  51. tire wear
  52. 5" exhaust
  53. differental Q's
  54. Fuel shutoff diagnosis
  55. Cylinder wear???
  56. PACBRAKE VAC CYLINDER REBUILD??
  57. poor mans big honking af?
  58. AFC housing
  59. boost elbow
  60. Oil leaking around injectors
  61. 97 3500 srw
  62. NEW TRUCK
  63. Boost Press location
  64. 95 cummins reg cab for 2500
  65. EGT sensor location
  66. how to get more rpms cheap
  67. Fuel Pressure Question
  68. Antifreeze
  69. oil leaks
  70. AFE Filter Part #'s
  71. Beat by a Duramax
  72. what makes auto tranny shift?
  73. Engine Cleanup
  74. Yikes
  75. Difference between cummins engines?
  76. Power and fuel mileage loss 1996 12v
  77. timing question
  78. STARTED UP RAN FOR sec now wont start during cranking
  79. Heater core hell
  80. rear diff
  81. Death Wobble
  82. headliner
  83. TOO LOUD!!!
  84. are they serious?!?!?!
  85. Got a wierd noise.
  86. Miss through the RPM range
  87. Turning up 8.3 Cummins?
  88. 5sp to 6spd?
  89. killing your rear tires
  90. Rpms?
  91. 1997 12 valve broke the sensor above crank shaft
  92. too much power!!
  93. injector problem
  94. Think it's bad?
  95. T-case Problems.....
  96. DAMPER on way out,where to get new one?
  97. bolt up turbos?
  98. switch from auto to 5 speed
  99. Great Power loss....
  100. bed lined rockers
  101. John Deere Turbo
  102. White smoke/skipping?
  103. Super singles on a dually
  104. smoke
  105. Hello there
  106. idling her up!
  107. its about damn time
  108. Third Gen. Mirrors.
  109. Oil Leak
  110. track bar problem
  111. 4th gear acceleration vid
  112. stock EGTs
  113. Parking BRAKE BROKE cant change crank pulley?
  114. filter relocate
  115. help abs
  116. dodge cummins 1994 12 valve
  117. Advanced timing caused high idle
  118. lift pump rebuild?
  119. STUCK INJECTORS!!!!!
  120. specs
  121. 1410 slip yoke
  122. rookie questions?
  123. low on power?
  124. advice for p pump
  125. just wondering
  126. No power and lots of white/gray smoke
  127. 96 dodge 2500 4x4 wheel bearing noise?
  128. really starting to make me mad now
  129. future upgrades
  130. Dyno Results
  131. Overfull on Transmission Fluid.
  132. 12v questions
  133. painting the trim factory color
  134. 10 plate to a 0 plate?
  135. High beam issues
  136. HT3B turbo
  137. killer dowel pin
  138. Wheel Hub Bluessss???
  139. fuel leak
  140. breakin?
  141. 90 horse injectors
  142. Heater cord plug replacement
  143. steering wheel play
  144. Rebuilding the 12v ......What would you do?
  145. power steering
  146. It's been asked b4 but I got another ?
  147. Heater Problems
  148. chewed up serpentine
  149. high idle
  150. rebuild
  151. 4wd Gear
  152. knock
  153. Steering
  154. Timing
  155. 4wd problems
  156. need advice on a 95 3500
  157. twins
  158. cant adjust gov. arm!!
  159. Window seals
  160. Injection pump install
  161. 48RE in 12v?
  162. Smoke
  163. Gov. Spring Question
  164. cold air intake
  165. oil filter
  166. Modifications
  167. towing question.
  168. Front U-Joint Help
  169. P7100 injector pump timing help
  170. 1995 5.9 engine keep running after ingnition stop
  171. Glow Shift Gauges
  172. Rear brake question.
  173. trans
  174. Hey guys I need help modifying my 12v pusher motorhome
  175. 12 valve fuel plate question
  176. Do P-Pumps Knock When Going Out
  177. Starting issues in the cold.
  178. Speedo Gear
  179. difrence in 12 and 24 valve trannys
  180. Where to buy an oil dipstick
  181. p pump power ratings question
  182. Fuel guage trouble
  183. lost power and cant hear turbo
  184. Loud intake or filter
  185. Truck geling up
  186. Boost pressure
  187. Engine lopes after load
  188. Whats the Dimensions of a 12V Engine ??
  189. Hard start after #100
  190. 12 valve intermittent power & throttle response loss
  191. Turbo time
  192. mpg
  193. Fuel Problem
  194. head.
  195. oil pressure Q's
  196. cant someone explain how to use the auto tranny lock mod?
  197. Need pics
  198. Warming up Probs.
  199. PART NUMBER CHECK IT OUT!!! IT HELP ME OUT. MAYBE IT WILL YOU TOO
  200. Holset hx40 wheel and housing p/n's , if you care
  201. Bad Injector?????
  202. Gov. Spring Adjustment????????????????
  203. no plate and gutted afc to plate and tuned afc?
  204. P7100 injector pump shut off question
  205. Track Bar Question
  206. Headliner Woes
  207. KDP?
  208. Fuel gauge
  209. 47re tv cable concern.
  210. volt meter
  211. afc plastic hose boost line?
  212. Intake Horns vs Flow
  213. 1995 trans lines and cheap paper clip fittings
  214. dual exhaust
  215. Transmission computer maybe?
  216. tranny swap
  217. 47re Won't shift at wot
  218. strange noises (engine)
  219. What do I do?
  220. Tranny Problems Maybe ???
  221. Trim
  222. NV4500 questions
  223. 12 valve
  224. '94 F350 knuckles & hubs on '97 2500?
  225. I'm assuming starter?
  226. Tires
  227. Oil in water?
  228. Fuel Plate effect on Auto trans life
  229. Gutting your AFC?
  230. $150 solenoid or $1500 P pump?
  231. Best place for freeze plugs
  232. Blowby oil screen?
  233. trans problems
  234. Tranny swap ??
  235. lift kit/stacks advice
  236. Thermostat Problems
  237. Good deal?
  238. Replacing motor mounts sucks
  239. help Hard starting 96
  240. Good Deal?...or keep lookin kid...?
  241. Wiring Harness
  242. Super B
  243. Vaccum diagram
  244. Missing at 2200rpm?
  245. Gauge Question
  246. coolant on the ground.
  247. Starter Hits my New SBC DD Clutch Flywheel
  248. Sway Bar Links=Death Wobble?S
  249. AfterMarket 47rh
  250. Front Driveshaft
