PDA
View Full Version : 12 Valve 2nd Gen Dodge Cummins 94-98
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28
  1. How long is to long
  2. what to get on my tranny rebuild/ disk break conversion question
  3. No 1st or 2nd gear in 47re when hot??
  4. popping noise
  5. getting rid of a junky v10
  6. Negative Camber on 4x4???
  7. which turbo for compounds
  8. Shifting problem
  9. New 12 valve owner need advice
  10. nv4500 swap
  11. tuning
  12. Transmission Question
  13. is a larger turbo needed?
  14. Turbo Play
  15. good buy ?
  16. top end power?
  17. lift pump
  18. 47re wont downshift
  19. #6 injector leaking coolant
  20. rebuilt trans wont move
  21. what tranny do i have?
  22. Help me new to 12 valve!!
  23. bllack diesel ?????????????
  24. problems after p pump swap
  25. tranny issues
  26. 2nd gen pcm interchangability?
  27. Blowing oil out the dipstick tube
  28. Blowing oil out the sipstick tube
  29. New to Diesels
  30. Truck refuses to stay running at idle
  31. swaping a auto out for a nv5600 on a 98 12v?
  32. how much lift on stock Radius Arms??
  33. When is it time to upgrade my Transmission
  34. old boost gauges-wierd calibrations..
  35. Anyone have this problem? Clutch issues
  36. NEED HELP!
  37. Front UJ Service
  38. is my turbo going out?
  39. 2nd Gen Air Ratio Spring adjustment?
  40. fuel problems
  41. Looking for a sleeper
  42. Hello
  43. Automatic trans having overdrive issues
  44. uhhh ohhhh 12 valve
  45. Timing issue
  46. wierd noises
  47. electrical problems HELP PLEASE
  48. 96 cummins 2500 slt indash gauges
  49. fast rig
  50. Auto Tranny No speedo, no overdrive, 47RE may have solution for u.
  51. Lower EGT's
  52. GENERATOR LIGHT CAME ON
  53. 96 dodge ram 3500?
  54. I need Help!! 24v to 12v swap
  55. 12v in a 1970 ford sport custom
  56. 97 ram 2500 tranny troubles
  57. got 1st, 2nd gear an thats all?? need help
  58. how to hook up a pot
  59. 98 12V maint questions.
  60. convert auto into standard
  61. GOV SPRINGS AN TIMING
  62. antenna mount
  63. 4gsk
  64. Hooking up gauges?
  65. What Timing to Run
  66. 68RFE in a 12 Valve???
  67. Cummins Vs. 6.5
  68. CA. diesel HELP!!
  69. valve top dead center
  70. 47RE
  71. trans cooler
  72. help 12v conversion
  73. can only column shift to get 1 and 2...help
  74. Miss at idle
  75. installing new injector pump???
  76. Oil pressure gauge high. Kilopascal
  77. PATC Transmissions???
  78. Transmisson
  79. Transmisson
  80. buying a 94 to 98 trucks
  81. headgasket ?'s
  82. got a injector size question
  83. Turbo spool trick... Fuel cut?
  84. NO SMOKE?????
  85. Bed Bolts
  86. Ring gear on flexplate/flywheel
  87. 3rd gen parts, 2nd gen truck??
  88. Fuel Gauge issue
  89. DODGE 12V
  90. Would you burn fuel from the early 80's?
  91. abs/brake lights on
  92. Banks high ram intake on a 12v?
  93. per4mance innovations transmissions
  94. water meth injection
  95. Trying to make more power
  96. Project Cummins Kodiak
  97. 96 fueling problem as in none!
  98. idle help
  99. Fuelling trouble
  100. Trans trouble
  101. killer pin
  102. Fuel heater
  103. help please!??
  104. 96 Slipping Tranny
  105. 97 cummins loosing power
  106. 1996 cummins swap into a 1992 dodge gasser
  107. Lucas
  108. new rubber?
  109. axles?
  110. 97 problems
  111. rebuilt 47rh slipping when not in lockup
  112. new dash
  113. gauge cluster lights not working
  114. walks all over the road help
  115. 97 fuel problem ?????
  116. i need some creative ideas
  117. 4.10 to 3.54 questions
  118. looking for a pic
  119. Driving Habits
  120. Fuel Module
  121. fp issues
  122. Stalling issue, and fuel plate question.
  123. keeps blowing starter fuses
  124. trying to understand this lock up switch???
  125. nv4500 swap wiring questions?
  126. tranny went boooom
  127. knocking issues
  128. clutch choices
  129. 12 valve popping..?
  130. diagram's for a 96 cummins?
  131. What is a 190hp ppump worth?
  132. 96 nv5600 swap/no start
  133. bad injector pump???????????
  134. looking to buy a dodge diesel with NV4500 tranny preferably cheap.
  135. rims
  136. Where do i start on a stock 96?
  137. 4wd drive problem
  138. advancing timing
  139. Want to trade 5x0.14 DDP's
  140. fuel system
  141. oil dipstick
  142. trani cooler tube?
  143. somebody help
  144. difference between 97 and 94 motors
  145. tire fitment on a 97 dually
  146. Cold Idle issues
  147. nv4500 swap questions
  148. Does your truck leak oil?
  149. down pipe
  150. turbo ex elbow ??
  151. How do you remove the push pins in the fender liners?
  152. Lookin to buy a nv4500 or trade my mint 47re for a nv4500 kit.
  153. Anyone done a Half-Ton swap ???
  154. killer dowl pin
  155. 97 dodge neon 2.0 5 speed cv axel problems
  156. Oil pressure sensor location
  157. NV4500 issue
  158. silver 64
  159. Oil pressure
  160. completely SHATTERED my driveshaft center bearing (not sure what you call them)
  161. #4 plate
  162. Looking for NV4500 conversion kit!
  163. possible charging issue
  164. 5'' exaust
  165. exhausted!
  166. 3000 gsk / 4000 gsk pricing ?
  167. Dodge 2500 12v cummins tranny swap
  168. dowel pin problem
  169. gear case
  170. transmission shifting weird
  171. custom lift pump
  172. break off screw on p pump
  173. Waste gate, shoulda thought about that
  174. damper proff screw on p7100 pump
  175. modifying stock TC
  176. wastegate and star wheel
  177. Neutral safety switch
  178. 4k gsk plate or no plate
  179. 450 hp
  180. hx35 turbo rebuild kit
  181. NV4500 problem???
  182. Silencer Ring Removal - Affecting CFM ?
  183. Head lights went out, then came back?
  184. NV4500 is this normal?
  185. auto to standard swap!
  186. Need some help diagnosing my no-start scenario on 12v conversion
  187. need some input
  188. 4x4
  189. wastegate question??
  190. loping at idle
  191. NV4500 conversion
  192. lowering my EGTs???
  193. dash
  194. Turbo Upgrade?
  195. trans upgrade???
  196. Brake calipers
  197. Turbo
  198. 1999 trans in a 1997?
  199. trans trouble (again)
  200. Really Stiff Steering!
  201. my 97 stuuders than stalls while driving???
  202. another timing ?
  203. Studders between 1000 an 1400rpm
  204. axle seals and gear oil everywhere!
  205. 66/71/14???
  206. Do I really need studs?
  207. Need to figure out mileage drop
  208. 4K GSK?
  209. problems bleeding lines after pump swap
  210. engine starts ticking then shuts down
  211. tranny troubles....yay
  212. 94 6 speed swap
  213. cylinder head numbers
  214. $800 94 5 speed truck missing on front two cylinders
  215. 1995 Dodge 5.9 Why does it smoke when cold
  216. Too big Injetors?
  217. what should my gauges read
  218. Ugh... Help? White smoke issues
  219. How would this work as a single?
  220. 96 12 v for $1250
  221. what gear ratios should i get?
  222. any suggestions on upgrades that won't hurt my tranny
  223. problem with high rpms at 65 or 70 mph
  224. Ceramic clutch. Your 2 cents.
  225. Input shaft nv4500
  226. Bad injectors?
  227. 1998 cummins egr delete ?
  228. 12 valve with blue smoke
  229. Broken Bolts!!!
  230. Interior lights fuse Blowing.
  231. whats everyone getting for fuel ecconomy
  232. HX52 over HX35 :) 750hp doable ? streetable ?
  233. Smoke
  234. extended cab rear molds and headliner questions
  235. exhaust manifold need some help
  236. Rebuilt transmission slipping need help fast! 47rh
  237. Chrome Rocker Panels?
  238. finding stacks
  239. websites
  240. hub assembly/ ball joints
  241. Anyone here removed their door moldings ?
  242. DV replacement
  243. 12 Valve to 24 Valve Swap
  244. electrical wire on lite switch
  245. 38MPH electrical gremlin
  246. broken "throttle" spring
  247. Little help
  248. turbo question
  249. clutch recommendations
  250. question about boost
