- injectors
- would like more power
- chevy wheels
- biggy b will a turbo off of an 04 will fit 95
- Fuel Plate Question
- EBay parts
- intake horn
- hey guys i just got my first diesel
- Odd Application for a 12v
- 500 hp
- how can i make a downpipe
- fuel plate
- how much power can i expect to make
- injectors.
- Converting to a p7100
- intercooler pipes/boots
- Pulling Truck Fuel System.....
- #100 plate? will it hurt my drivability or mpg?
- boost elbow installation on a 1997 12v
- Umm more fuel.
- heres a new one
- 4k kit install
- Tranny won't shift right
- BHAF
- Valve Spring Replacement
- can anyone recomend a reputable diesel shop?
- what does lazer cut delivery valves do?
- help with gauges
- truck mods
- idea for filter skin?
- Cold Air Intake?
- best combo for 450 rwhp 850 ftlbs?
- wat fitting on the pyro
- fueling question
- ht3b switzer with 26cm undivided housing
- lowend power
- thanks
- Fuel plate description?
- turbo change
- 12V vacuum location?
- DTT
- any one know about 4 k gov kit?
- Which lift pump to buy?
- 3000 or 4000
- GSK spring kit question
- any one make intake heat shields?
- Fuel Plate
- twin turbo thought
- injector and DV valve questions
- Gov Spring Questions
- 12V programmer ??
- injectors
- propane or water/meth
- 4000 gov springkit
- Banks Powerpak Kit
- water methanol
- Boost Elbow - where is the link?
- Injector and Fuel Plate ?
- home made 3000 gsk
- balanced
- Where do I hook in the trans gauge ???
- turbo ?
- pressurizing coolant system
- 5 inch exhaust
- down pipe adapter
- Need some help please
- Going to the dyno
- turbo upgrade?
- 4000 gsk install ? with picture it is all apart
- 3000 to 4000 gsk ?
- New exhaust
- Head work?
- Gauge Kits
- blockin the waste gate.
- Down Pipe
- fuel plate
- Star wheel
- pyrometer question
- 370 marines vs 370 new eras
- is this a true 887 pump?
- Will these mods require a turbo?
- How much HP?
- injectors
- About the mack plug/rack plug?
- 550-600 Hp Goal
- 3000gsk vs.4000gsk
- what is this air filter
- 12v hp mods help
- 12 valve ez pulling mods
- Will These Housing Actually Help ?
- looking at the next upgrade...
- Fuel Plate
- School Me on Fuel Plates
- ATS 3 piece mainfold
- P7100 pump question
- not enough rpm's
- Drive pressure gauge
- tach?
- #11 fuel plate
- delivery valves
- gov kit & valvespring prob
- Anyone have a D-Tech Turbo?
- injectors
- dv desicions
- Detune?
- Springs and what not
- #6 plate
- gettin to the fuel plate
- Paranioa or not
- tst vs ebay
- Sticks? What Injectors do I have?
- ~*TRUCK SHOW*~
- Gov spring kit tips
- Timing for towing???
- ? Biggest Fuel Plate on a Automatic?
- DV'S
- Aftermarket Tachometer
- 400hp?
- anybody pulled with a ductal dual disc?
- AirDog Dodge FP-100-150 1994-1998 Install Manual Rev. 3-3-09
- P7100 1st gen
- DD install problems
- 12v build questions and advice
- de-bomb?
- to much blowby
- plate issues
- twin ram
- water methenal
- Going Half Fenders... No Bed!
- twins can it fit?
- oil bypass filter
- ICEBOX!!!
- Blowin Coal
- GS washer shim?
- blow off valve
- Fire ring/o-ring?
- newbie 100 vs. 0 plate cut
- cam question
- help turning the fuel up
- milling rocker stands for head studs?
- water /meth injection
- dual disc
- Gauge installing
- Delivery Valves
- Down pipe
- Pensacola injectors?
- water meth
- '03 Trac Bar Conversion/ DSS Project...
- timing 12v
- fuel pressure guage
- Home brewed twins
- best auto trans
- Turbos
- AM I TRYING TO GET INFO FROM THE WRONG SITE?
- Are ATS Turbos good?
- are they compatable?
- I need advice im losing sleep!
- anyone know turbos?
- bumpin fuel in my 98 12v ?s any help?
- 4k govener spring kit
- pulling timing cover what all should i do?
- what turbo sould i get?
- what hp you think im making?
- how to make power,,,cheap
- 13 second 1/4s ??
- Anatomy of Twins
- More rack travel
- AFC arm
- 4" exaust
- Ground my plate to a #100
- 370 marine nozzels
- twins
- Whats it like under your hood?
- Whats a good 3rd Gen TB Bushing???
- help asap please
- Governor Spring Kit Question
- Gutting AFC
- Boost Gauge wiring...
- Getting my 12 valve some more power
- 12valve Turbo Whistle 'r installed...
- afc kit
- ATS Aurora 2000 turbo
- Swapping Parts
- 3000 to 4000 gsk where to get the extra parts?
- #100
- black smoke!!!!!!!!!!!!!!
- Bomb order.
- Plate profiles....
- 4X4 problems.
- changing the plate or plate number from a #6
- High Idle
- delivery valves
- TST power kit has anyone tried
- Question about lope.
- Looking to buy injectors, but which one's?
- what injectors should i get?
- Propane ?'s
- Anyone go from a 3k to a 4k?
- Fuel Plate Grinding...
- Anyone replaced your ball joints?
- starwheel adjustment
- 1Hole... 2Springs... ???
- 3k GSK install
- Death Wobble baby steps...
- Injector flow
- Tuning the AFC?
- sigma p pumps
- Injectors
- 370s
- cummins fuel plate
- Lift + Tires
- cummins pyrometer
- which plate has most power??
- Bumping Timing up on a 1996 12v...
- Steering upgrade
- 12 volt block heater????
- 12 Valve on a budget
- Air vs Fuel
- Opinions On A Muffler
- Fuel Plates
- Fass/Airdog Questions
- BHAF
- Twins setup oil return question
- Monster Pump In A 12V
- Injector Questions Again
- Help Tuning A 12 Valve!!
- Which Trans To Pick...
- 12V Boost Gauge Install
- How Much HP Should This Make.....
- 97 Fuel Filter Relocate Kit ?
- Grid Heater Delete
- New Turbo...
- Lets Make Some Power....
- Unsyncronizing A NV4500
- Stocker Over HT3B
- Best Mileage And Perfomance Help
- Turning up a p7100 fuel pump
- Injectors???
- 12v FASS ?'s
- AFC Starwheel Spring Curves
- Banks Kits
- Upgrades
- P-7100 Tuning The Black Art...
- ATS Exhaust Manifold...!!!!!
- Phat Shaft VS High Tech
- I Can't Decide
- 12 Build
- 94cummins12v Custom Light Bar
