- wher to buy a valair clutch right now!!!!! ASAP
- #11 plate
- Quest for power
- valve springs
- ht3b housing questions
- 60lb exhaust springs
- lets settle this... hx40
- first 2nd gen...kinda
- How much hp/mpg will I gain by getting a dual elec. fan setup?
- Governor Springs
- Custom Fuel Lines
- I Think My Airdog Is Going Bad
- TC switch
- now what
- Rebuilding motor with badass parts vs. putting in used motor from junkyard?
- oringing the head
- BD TC Lock up switch
- 65lb/min DBB P-trim 63a/r single or twin?
- running out of fuel?
- Need a cheap hx35!!
- Parts and functions of the afc
- 60mm pin wheel
- head stud????
- Want to go faster!
- Whats a worst-case scenario that can occur with slipped timing?
- pinning the compressor housing
- What pressure will I see if I plug the wastegate line?
- thought i would share.
- anybody try this yet.
- What turbo is this? pics.....
- Who out there is running Water/meth injection?
- How to tell if exhaust turbine seized?
- Is cold-start sputtering normal?
- AFC Tuning
- Delivery Valves
- 24 valve head on a 12 valve block.
- cheap?
- Twin Turbos - 12 Valve in a F450
- Just noticed my bottom 2 afc screws came out!!
- Resetting the TPS for better mileage?
- What to do what to do???? next step?
- How to tune afc for mileage AND power?
- Afc spring kit?
- bhaf for $34.00 at napa!
- Bigger exhaust better?
- Another 94 12V
- bhaf v.s. k&n filter
- Big Airfilter
- how much timeing
- 5" Stacks and Straight piped
- Are upgraded valve locks and retainers worth the money?
- CAN I MAKE THE HP WITH THESES MODS
- SDX Injectors
- 100 plate grind
- CAT Stack? Post pics too!
- Which Turbo
- delivery valves
- injector?
- HELP
- What is needed to get an hx40 bolt up?
- Will driving with a seized turbine cause any damage?
- HELP! Is my turbo fried???
- 38R on Cummins 12 valve
- WHAT DO YOU GUYS THINK
- Looking for 75 hp injectors
- turbo testing video..what do you think? Input please...
- 3kgsk
- injectors
- need a good set of gauges
- turbo specs for the htt 64 71 13ss?????
- twins enough?
- timing wont stay
- Looking better
- overdrive adjustment?
- Different size tires on each side of my dually?
- headgasket and arp head studs
- budget twins?
- 370 Injectors or drill out stock ones??
- Camper Shells
- Oil Pressure Pre-startup.
- head ?
- wh1c hybrid?
- Ready to start
- Lots of spontaneous smoke w/ fuel plate?
- 4K GSK and stock Auto tranny.
- I'm so freaking EXCITED
- Turbo question? hx 40 pro ...super 60
- aurora turbos
- Blow off valve????
- 98 12 valve fule plate in or out
- Do I need a billet input shaft?
- Will this turbo work?
- afc tuning for no plate
- governor springs
- Blown Head Gasket
- Valve Springs
- 100 plate sdx 90's ???
- Cat stack
- injecters 90's or 140's
- 97 Fuel plate removal.
- Coolant temp goes from like 150* to 190-200*, then goes all the way back down...
- Gas Guzzler to Diesel Pumper
- cams
- drill bit and tap for pyro in manifold
- Glow Shift Gauges?
- guages
- Holset H2E
- hx40 question
- good clutch???
- Bigger housing on stock hx35?
- Delivery Valve Holder
- Upgraded 40hp nozzles? any good?
- How are pensecola diesel stage II sticks?
- Compound with a stock HX35?
- opinions on mods
- tranni filter
- less fuel
- 12v Injectors
- Delivery Valves
- while its apart??
- turbine housing
- 215 Injectors
- turbo housing for hx35
- Anybody ever rebuilt their starter?
- automatic vs manual P-pump
- 12 valve fuel pressure?
- delievery valves
- hx40 a good turbo upgrade?
- Upgrading turbo but keeping bd exhaust brake. Turbo options?
- twin turbo install
- 3 bolts on AFC
- Timing Trouble
- Anything as far as aftermarket air horns?
- BHAF questions.
- afc air line...?
- FS/ WTT....my custom dv's by weston for your 181's
- AUTOMATICS....Tell me about them
- rack plug
- tans cooler
- clutch ?
- Head bolts and valve adjustment
- Intake Plate
- input shaft
- 4k GSK KIT INSTALLATION?
- engine missing out
- Auto to Manual Swap
- piping
- Where to get a pod/egt/boost gauge combo for cheap?
- Which filter do you guys use for your bhaf?
- Does advancing the timing help out a lot?
- what pressure plate
- need serious cool down
- tc lock up switch
- Jacobs brake
- 300-350hp
- Project 700hp
- Wix napa filter
- NEED ANSWERS QUICK!!! TWINS 12v
- Suncoast valve body question
- 215 injectors
- new truck
- Waste Gate
- What About the cam
- What to do next
- Making room
- egt guage messing up
- what you guys think
- Compund turbo mounting
- Wastegate mod?
- 3k or 4k gsk kit w/ only basic mods?
- Can I ditch the steel mirrors and get 24v mirrors?
- What size fuel plate fits me? I'm thinking a 0 or 10?
- New to Cummins, former F250 owner.. have questions!!
- Trans
- hx40 compressor wheel
- what convertor
- smoke screw
- Gov. arm height adjustment
- more power?
- stock injectors
- Transmission Which One
- 47RH
- 01 nv5600
- bhaf vs. afe
- Gauges
- Injectors
- settle this once and for all for me
- ht3b exhaust housing idea for my twins
- Ever heard of a new aftermarket 12v head?
- any suggestions
- What to run for twins??
- boost question
- body work tips?
- scan guage II and 98 12 valve.
- Governer Springs
- are these 370 injectors???
- thinkin of more power
- weight problem
- 4' down pipe
- pyro install question
- Need Boost!?!?
- Injectors, fuel plate question
- Finally bought a pyro
- what should i put on my 12v engine
- Cleaning aftermarket air filter
- 94 47rh to nv4500 swap help!!!!!!!
- any reason i can't have a 6spd?
- Homemade fuel system
- would the gear box go on 94?
- still cant decide what injectors to get
- Injector Size?
- fans
- O-ringing?
- where to get tc lock up switch>?
- red tops dead
- injectors?
- Killer Dowl Pin
- how much power
- twin turbo piping
- what top turbo to get
- what clutch set up to get
- 4k governer springs
- 4wd swap using donor v10 to CTD 12v
- Steering Gear Upgade
- Roof Rack
- Quick ? running AFC cover w/2 screws
- Injector breakdown
- coolent lines to turbo
- Turbo Bark
- Upgrade Questions
- Rough HP/ torque estimate
- New 5inch
- Torque converter break in?
- scoop on tc lock up switch
- ATS Billet Flexplate can Fail
- micro pump?
- New seats
- Road Ranger - 10 speed
- tuning
- T hande Hurst shifter?
- Dual Fuel Feed
- somekem or sdx
- Tranny temp gauge help
- turbo help
- P Pump Timing Adjustment
- Water Meth?
- head gasket
- 96 12v q's
- changing injectors
- exhaust manifold
