- Puttin in new tranny thursday!
- Need Advice
- lift pump bypass ?
- brain fart
- gsk question
- dual fuel lines?
- p-pump build
- turbo time
- Exhaust Manifold Porting
- A few turbo questions
- sleeves or no sleeves??????????????
- Emusa HX40
- Head bolts / studs
- Plate vs No Plate
- b1 turbo ?
- Mechanical Lift Pump
- O Ring and Head Studs
- methanol injection setups
- 3000 worth of upgrades
- Horsepower on a budget
- Which fuel system
- first twin build
- rack plug
- pump timing?????????????
- dyno day
- twins
- Wastegate mod question
- TC lockup switch question
- more fuel n air
- #4 puking oil
- 12v build...kind of
- truck pops above 2500
- is over 700HP worth 15k?
- Just moded my AFC and plateless
- gauges
- tranny?
- Making her spin fast......
- top turbo for twin setup
- injectors
- gsk (governor spring kit) installation
- best intake.. reccomendations?
- transmission cooling
- Good Realiable Towing Setup
- how much torque??
- Auto Trans
- What Brand of converter?
- pensecola injectors
- he351 on a 12 valve?
- still confused
- delivery valves
- in need of some help
- i need twins!! 12 VALVE
- what fuel plate
- 64/14 Turbo too big?
- HX35 or HX40?
- track bar
- Fuel Gauge Install
- Turning Up The Pump And Removing The Fuel Plate
- Safe Boost #'s
- airdog question
- Turbo Help??
- Lower egts
- transmission
- washer shim trick in governor
- Brake Controler
- head studs ?
- looking for bosch numbers off big delivery valves
- Reliable 350 HP
- Where to start?
- nitrous
- Turbo Performance Exhaust Manifold Blanket
- DV O-ring help!!!
- Got the plate and now have ???????SSSS
- installing head studs...NEED HELP!
- Which Exhaust 4 or 5 inch?
- 12v into 24v
- injectors
- Fuel Plate??
- Tranny Problem
- injector/twin turbo?
- injectors
- help!!!!!!!! turbos!!!!!!
- who has the best pump upgrades
- 370s
- Intake manifold ?
- D-Tech
- possible new truck
- Bumping timing
- timing Questions
- Injector Help
- Manual trans guys...
- Planning future bombs looking for advice
- too much boost?
- 40+ too much?
- Sliding The Fuel Plate?
- faster?
- MORE POWER!!!!!!
- 191 Delivery valves
- Fixing KDP what else should i do
- twins
- Taking out my plate.
- 12v upgrades
- torque convertor
- Over heating
- Turbo
- twins or single
- air dog or not
- got a new toy to tinker with!
- Buddys new 12V
- I wanta do this to my cummins any ideas?
- injectors
- What next ?
- dual fuel lines
- grinded to a #100
- Unexpected results from 370's
- power estimates & advice for a newbie?
- no wastegate on a HX35
- input on cheap upgrades
- power making advice
- 4gsk and fuel shutoff selinoid troubleshooting help
- where to plumb in fuel pressure guage?
- hx55?
- How to get more HP? lookin 4 some pointers
- Air intake filter on turbo?
- aftermarket camshafts
- 95 5.9 in a Freightliner FL 70
- injectors
- Gauges!?!?
- fuel plate mods?
- after trans then what's possible??
- electric fuel pump on 12v
- Mod help
- No plate?
- HX40 turbo?
- Turning up a 12 valve questions
- trans question
- electric lift pump
- ht3b piping
- turbo wheel?
- 12 valve auto
- injectors?
- 370 marine injectors
- fuel lines
- 12v Rebuild Upgrades
- Ceramic clutch
- smoking problems's
- choosing the right turbo
- up grades
- 98 12v
- transmisson
- t.v. cable adjustment
- Dual Feed P-Pump
- 4k gsk, 60lb springs and possiable timing. HELP!
- p pumpd 24v
- Turbo Piping
- 12 valve build up
- high egt's water/meth?
- oversize fuel lines
- govenor arm adj? pumping tweeking
- fuel plate vs tranny
- borg-warner turbo
- 4k gov springs = SUPER touchy throttle
- 95 p7100
- Tranny Temp.---Another question
- 24 valve head on a 95 block
- any suguestions
- marine 370's
- Timing advice...
- Help.. which southbend is this??
- afc spring kit?
- whats fair?
- Boost?
- Air Filter Collapsed, Looking For Replacement
- motor rebuild, hg ?s
- Whats the advantages/disadvantages of no plate over a plate?
- which injectors???
- 175 pump??
- Pump failure
- pump timing
- Should I buy back my old 12v?
- Twins
- laser cut vs stock 181 dv
- 3k kit and timing
- Valve Spring Install
- #100 plate
- how much boost????
- How much boost on stock intercooler?
- Gotta 91.5 first gen 12V sittin out back
- Replace afc washers?
- Automatic Tranny shift kit?
- Need to go to school 12v performance
- Need advice on setting up a 96' for Towing
- 3k spring install with no factory shims
- HELP!!
- in need of new intercooler boots what kind?
- hey guy in Az i need your help
- Transmission AN fitting
- 4k and timing ????s
- PUMP TIMING?
- turbo
- 370's
- What is the Barrel Mod?
- Thoughts on High Flow delivery Valve Holders.
- INJECTOR HELP!! NEED NEW ONES
- HELP
- possible gain?
- need a new turbo
- delivery valves
- Wanted: Torque converter
- mighty diesel head bolts?
- torque converter
- opinons please fellas.
- 12v rookie
- looking for cheap mods for power and mpg's
- o/d unit rebuild
- O-Ring vs. Fire Ring
- Afc
- 3k govenor springs
- injectors
- twin turbo combo?
- The Next Step
- transfer pump
- Price to put in gsk and valve springs
- pump guy?
- Double vs. triple
- Searching for timing vs. rpm powerband post?
- what mods for a 215 to make 500hp?
- Turbo ID help
- what turbo
- Spot for more gauges
- Twin with hx35
- glowshift
- b&m mega shifter install
- power???
- afc question
- where to run mechanical oil gauge to
- nitrous questions.
- tc lock up switch
- A/C Compressor
- air filter box inserts
- Where did you get your mudflaps
- got the motor back together today
- Average cost to rebuild cummins?
- boost question
- diesel power source exhaust manifold?
- Symptoms of bad injectors?
- Looking for 3K GSK and 370 marine Injectors
- Mahle 12v piston numbers
- injectors
- fuel pressure guage
