- HX35 rebuild questions (maybe a 35/40 hybrid)
- my 96 cummins
- # 5 fuel plate
- 4k gvsk and 60lb springs but hiccup
- new turbo/ question
- my 12 valve
- p7100 pump maxing out question
- trackbar
- air dog II
- water/meth injection systems????
- Trans build for governor spring upgrade?
- Exhaust
- question
- Sport lights in non sport pickup??
- bd super b
- After market head lights..best one?
- Feed back on bd super b
- AIRDOG FILTERS
- .020 or .040 over????
- New with questions
- need some good advice
- how to get 400 hp
- Headstud difference
- Guages..
- gearing, fuel mileage, bigger tires.
- super b vs hx-40
- aurora 4000 questions
- Fuel Plate
- valair dual disc 1250$
- Manual to auto swap ???'s
- wtf!!!!!
- Fuel Gauge with airdog
- 650 hp build. 94 12v auto
- Runaway loping idle?????
- TC LOCKUP SWITCH SCHEMATIC (REPOST)
- Not Blowing Smoke
- Raptor Fuel Pump
- I need a new turbo any help
- Injectors???
- piping
- Compound turbos, low rpm boost, high rpm flow
- 40lbs of boost
- what turbo is best
- 75 or 90 horse injectors?
- 47rh build
- 12v Fuel Plate
- intake and intake manifold?
- What lift would be better?
- Odd tranny question
- HX50 turbo
- 1/4 challenge
- 5" or 6"
- s300g
- check this out
- sdx injector washers
- Whats a good low pressure combo turbo for the ats 3000
- Turbo????
- Egt's
- heat sheild
- dv's
- Need a little trany help.
- 94 dodge Diesel HP upgrades
- new turbo
- HX55 Turbo
- conversion??
- how do i turn up my fuel flow on my 98 12v...do i just move the plate??
- turbo
- Cylinder head work????
- Hoslet Turbo Upgrades
- Hoslet turbo upgrades
- Cylinder head crack
- boost pressures
- what upgrades for 1000-1500
- prices for gauges
- which cold air intake ????
- gauges ??????
- "Hot line" replacement
- got a cool ideer
- fuel plate
- banks power!
- afc mod i cant find anthing about.
- thinkin bout a he351vgt
- pre turbo/ post turbo pyrometer
- full build
- Anyone seen or used an engine mounted air compressor?
- 4000GSK
- spedo recalibration
- porting a 12v
- timing ?
- Some mods to my truck!
- new fuel plate and now no power??
- trans help please
- trans help
- banks quick spool turbo
- turbo??
- turbo silencer ?
- a1 technologies studs vs arp studs
- Smoke screw?
- Building a 2.6 truck
- 4k Springs??
- turbo help
- Fuel plate?
- turbo help
- TURBO??
- plastic part
- any way to prime the oil pump on my old 91 ?
- Run away with 4k gsk
- injectors and manual conversion
- overflow valve
- DV's
- Homemade FASS system.....
- ? cheap fuel plate
- anyone running these injectors
- Bigger turbo
- transission question??
- good combo?
- 1996 Cummins 5 speed
- smoke rings???
- transmission upgrades
- SDX injectors
- truck running ruff
- new diesel, info?
- tranny upgrade
- torque converter
- tc lockup switch
- Running nitrous safely
- HEAD PORTING
- so confused
- 7x10 injectors
- HE351VGT turbo on 5.9.. anyone done it?
- 98 12 valve how to know if i have 370 injectors
- question for the 1/4 mile guys
- 4gsk, 60lbs springs
- Three Turbos i would like to know more about :P
- WONT FREE REV, POPS AND WHITE SMOKE
- anybody have experience with this turbo?
- Pump timing
- Heavy, heavy towing mods help needed
- boost elbow
- tranny issue
- how much power
- twins
- 4k gsk
- 60lb valve spring questions
- 12v mods
- ht3b,col and hot pipe
- whats a set of used 12mm headstuds worth?
- What is the disadvantage of putting stiffer springs in?
- Billet vs. regular 1 3/8 input shaft
- HX35 HY35 Exhaust Housing Same?
- schwitzer mack truck turbo
- he351cw
- Modifying a Wh1c
- A good Transmission?
- he351vgt
- getting black smoke
- injector question
- twins
- 94 12v Ranch truck upgrades
- T3 and t4 sizes
- airdog 150
- Competition Engine Build
- T18A40 Turbo
- Old dual disc clutch
- Garrett turbo ?
- stock181/fullcut181
- need help with a build
- Delivery valves
- Mileage concious injectors
- Delivery Valve Question
- Custom exhaust?
- Govenor Spring mod
- Washer mod
- Governor spring HELP!!!
- 95 CTD track bar
- MORE POWER
- turbo ?
- need horses
- wastegate hose
- what it take to make a 800hp play toy!
- anybody running scheids adjustable fuel plate?
- banks twin ram
- intake manifolds
- i dont understand???
- clutch
- help to find a shop in tucson
- Quick Question
- MPG
- build for the future
- afc housing and pump
- Advance Timing
- twin stocker kit
- Turbo Identification Help!
- How high can one rev a 6BT with 60lbs valvesprings ???
- trans temp install
- turbo question
- Build Advice
- hx40 question
- road runner TC???
- housing swap question
- help on turbo decision!
- hx35/ht4b twins
- anyone heard of this...DTT tuner
- DDP injectors
- whats the easiest and cheapest way to make power with a 12v
- S300 turbo
- 12 valve monitor computer
- Valair Ceramic clutch
- gauges?
- Building a Tranny
- Dual Disk options
- Changing mods
- Confusion...
- Pac brake install valve spring?
- will this set up work
- Isspro gauges question
- oil pump
- Turbo Swap Questions
- look out
- what turbo
- BIG LINES??
- What's it worth?
- what turbo
- injectors?
- Idle adjustment help!
- best exhaust housing for ht3b
- GSK questions
- 5" turbo back exh. kit fit stock turbo?
- cummins marine crank?
- guage pod
- 62/65/12
- Injectors
- glowshift gauges??
- What clutch to get?
- valve body
- compound turbos
- 60mm w/g mounting options
- Airdog2 question- looking to buy but need some answers
- what mods do i need?
- turbo blade?
- Nv 4500 or 5600
- New Gov
- AFC Moded question
- making a manifold and putting on a bigger turbo
- P pump gov housing
- dual feed injector nozzles
- 16" wheels
- need some advice.. injectors what kind do i need?
