PDA
View Full Version : Wanted To Buy (WTB) - Used
Pages : 1 2 3 4 5 [6] 7 8 9 10
  1. Raptor 100 or 150
  2. wtb 94-96 cummins intake horn
  3. 1st gen cummins intake
  4. 1994-1998 2500 parts truck
  5. wtb used lift pump from 2nd gen
  6. Wtb, cummins 6speed or duramax $20,000 or less
  7. dual 4 inch
  8. 17 inch used rockstar dually wheels
  9. stock 94-2008 coil springs
  10. GN to 5th adapter
  11. 12 valve parts
  12. WTB: DRW Hub and Backing Plates
  13. hx35 or hx40 or s300
  14. Smarty WTT
  15. sidewalk smoker for stack
  16. 89-93 bed
  17. Injectors for a 12 Valve
  18. trade tranny?
  19. Diesel Motor
  20. WTB 95 6.5 td fan upgrade
  21. Need a push buton np263xhd tranfercase
  22. WTB: Holset HX30
  23. vp44
  24. WTB/WTT 95 triple gauge pod
  25. WTB - HX40 and Smarty
  26. wtb quad or edge for 350 cash
  27. 12v injector return line
  28. 2000 cummins injection pump
  29. to trade injectors
  30. 3rd gen cummins
  31. WTB LMM Duramax Stock Exhaust
  32. cummins intercooler
  33. WTB exhaust brake for '93 D250 2wd
  34. Leaf springs
  35. Transfer case and Drive shaft.
  36. Turbo
  37. Late HX35W or HX40
  38. cummins to chev adapter
  39. 03-09 Stock Track Bar
  40. Want a DIESEL!!
  41. sound system
  42. Anyone Parting out?
  43. Chip needed. (code: DAC3) help
  44. 3rd gen aluminum finish center caps
  45. WTB NV5600. I need help!
  46. 2nd Gen Dodge Flip Out Tow Mirrors
  47. In need of a SO vp44
  48. GM-8 turbo needed
  49. 12v twins parts Needed!!!!
  50. 12v parts
  51. mirror
  52. WTB: Drivers side LB7 complete head
  53. WTB: LBZ or LMM Rods
  54. hx-35 parts
  55. needed: turbo to intercooler elbow. anyone?
  56. injectors needed, 06
  57. Stacks t-pipe
  58. NV4500
  59. hubcaps
  60. WANTED GETRAG G360
  61. RIMZ
  62. hx 40 down pipe
  63. steering pump
  64. intercooler off of a ford or dodge upgrade one
  65. 5"-7"tip or 5"-8"
  66. s300 turbo
  67. 04 -07.5
  68. looking for 1996 to 98 cummin parts
  69. 181 dv holders
  70. boots
  71. WTB Tires
  72. 16 inch dually custom wheels
  73. injection pump
  74. Look for used HX35 turbo
  75. 12 valve delivery valves
  76. FORD TCASE 4X4 LINKAGE
  77. fuel tank
  78. exhaust tip
  79. WANTED!!
  80. cummins flexplate
  81. Radio Antenna Mount
  82. Leaf springs
  83. he341
  84. WTB: NV5600
  85. WTB HX40 Compresser housing 60mm or bigger
  86. WTB Long Bed for 1993 F-250
  87. wtb hx35 12cm exh. housing
  88. Looking for pick up fuel pump setups
  89. used or bad triple disk wanted
  90. torque converter
  91. 04.5 commonrail ecm
  92. O-ringed 24 valve head
  93. P7100
  94. 265s or 285s
  95. dana 80 410 ring and pinion
  96. Turbo
  97. 6.7 blackmax
  98. WTB 12v dodge
  99. 02 PCM
  100. transfer tank
  101. dana 80/60 4:10 gears
  102. dodge auto parts
  103. WTB 1991.5-1993 W350 5spd ex. cab
  104. looking for NV5600
  105. WTB-4" down tube
  106. turbo
  107. turbo
  108. wtb: p pump p7100 injection pump only the pump
  109. 03 dodge after market intercooler
  110. P Pump lines for a 24valve
  111. WTB Computer / PCM for 1996 Auto Dodge Ram
  112. 5 to 6inch tip
  113. wtb: factory intake and turbo for 2006 Dodge CR
  114. WTB Stock Upper Fan Shroud
  115. injectors for a first gen
  116. NEED LT1,LS1, etc.
  117. need a 4bt
  118. ho vp44
  119. Dodge Tow Mirrors
  120. 94-97 cummins dash
  121. vaccum pump 12 valve dodge
  122. Dually whells
  123. WTB used hx35 or hx40 for 300$ or so
  124. WTB- Holset intercooler hotside outlet elbow
  125. WTT Edge Comp
  126. wtb 3rd gen drivers side grab handle pillar
  127. need gears for dana 70
  128. 60mm compressor wheel
  129. wiring harness!!
  130. IN SERIOUS NEED OF A PUMP DRIVE GEAR
  131. stacks
  132. turbo for dodge
  133. Anyone Have Some 235/80/16 Tires?
  134. A 24v Cummins Motor NOT a 53, From 98.5-02
  135. Front Grill for 91' dodge w250
  136. bullydog GT
  137. lookin for a 100 plate or grindable one.
  138. I Need a New whole Fender
  139. turbo housings
  140. manual transmission pedals
  141. I need 24V injector cores ASAP
  142. Turbo
  143. FLAT BED
  144. I need a cam gear for a 01/02 24 valve
  145. turbo for dodge
  146. USED STACK
  147. Looking for cheap 5" black flat top stack!
  148. WTB Black Plastic Storage Tray For Standard Cab Trucks
  149. Holset HE341Ve Turbo
  150. transmission parts
  151. Black 17 or 18 inch Wheels for Dmax
  152. Stock Injectors for LB7
  153. 2nd or 3rd gen 1 ton
  154. truck bed
  155. Dually wheels
  156. Power Mirror switch for 02 Dodge 2500
  157. 03-07 control arms and springs
  158. I need a Bumper
  159. Stock 98.5-02 Cummins Injectors
  160. overhead console - 2000 Ram
  161. i need 1 stock ford alcoa rim and a set of 285/75r16 tires
  162. 17" wheels
  163. Wanted overhead console
  164. NP241 extension housing
  165. Edge juice with attitude for '04 Dodge
  166. Need a 12valve motor
  167. NV4500 bell
  168. Standard 5speed
  169. Dodge downpipe
  170. I need some DV's
  171. Duramax Tow Mirrors
  172. Differential gears
  173. 67-69 C10 shortbed stepside
  174. <SPAN style="color:green;">Wanted: </SPAN>Wanted: Hub Cap for 2nd gen 3500
  175. power puck
  176. Wanted to buy some gauges
  177. Wanted 2007 Dodge 3500 dually spare wheel
  178. 12 Injectors
  179. wanted 22 or 26cm ht3b exhaust housing
  180. wanted 12cm super phat shaft exhaust housing
  181. Wanted 6bt/4bt Sae #3 flywheel manual trans
  182. hx40 14cm housing
  183. WTB or trade for 4:10 gears for dana 60's
  184. flywheel cover
  185. 2008-2010 Superduty Wheels
  186. Stock 16"x8" 2nd Gen Dodge 2500 Aluminum Wheels
  187. crank case breather used or new
  188. WTB: HE341Ve compressor backplate
  189. WTB VP44 core pump!
  190. Wanted Cummins flywheel housing
  191. one ton
  192. in need of a 5pd manual
  193. Stock Wheels
  194. 5.9 cummins
  195. 5" or 6" stack...
  196. WTT 24v 100hp Injectors for 50s
  197. twins/compound turbo setup
  198. 2000-2003 4x4 powerstroke truck or engine and trans
  199. turbo!
  200. NV4500
  201. 2001 dodge dually front center caps
  202. Need Truck hauled from devine,TX to florida to suncoast..
  203. need turbo bad
  204. 3rd gen aluminums
  205. HX 35 turbo
  206. NV5600 6spd trans and parts
  207. need fuel plates for cummins
  208. Parking brake cable(and a few other things)
  209. 241DHD transfer case
  210. 24v Throttle cable
  211. ht3b housing
  212. i need a good used vp44
  213. stock forged rods from a 12v or 24v cummins
  214. Inside Drivers Side door handle 1st Gen
  215. looking for
  216. Smarty with beta 4.2!
  217. Cummins T4 manifold and Misc.
  218. H1C turbo
  219. steering box
  220. Dodge Cummins transmission
  221. WTB D80 Rear end
  222. WTB AirDog Lift Pump
  223. WTB Aftermarket parts for 01 24v
  224. WHEELS
  225. 2wd 5speed for 6bt
  226. need an oil pan pick up tube fast!!
  227. 1998.5 Or Newer NV4500 Shifter Handle
  228. need ht3b 26cm housing
  229. Cummins 5.9 SAE#3 flywheel housing
  230. gearvendors
  231. 2004.5 3500 dodge owners manual!!!!
  232. overflow valve
  233. 1993 VW Eurovan MV Gas to Diesel conversion
  234. 1998-2001 TDI Golf or Jetta/Passat Wagon
  235. dodge 12valve cummins 4x4
  236. edge drag comp.
  237. Help I need a Motor Mount
  238. Rear Driveline for 02 Dodge quad SWB 4x4 6spd CTD
  239. WTB Good 4:10 gears sets for dana 60
  240. parts to finish 5 speed swap.
  241. need front end parts
  242. In need of some things! Please look!
  243. 12v Dodge
  244. WTB 1st Gen Auto w/OD good trans or rebuildable core NORCAL
  245. water outlet
  246. Stacks
  247. Pre 98 factory ford Alcoas
  248. truck stacks
  249. Dodge diesel 727 trans.
  250. New motor centralized closing
