PDA
View Full Version : Chevy/GMC 6.2L and 6.5L
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13
  1. where is the crankcase breather on a 6.5 turbo diesel
  2. transfer case sensor
  3. blowing oil out of the dip
  4. electrical issues
  5. 6.5 smoke white on start up
  6. Trans cooler line leak
  7. 9 starters 3 flywheels? why!!
  8. Running rough or missing
  9. Info on lifting my suburban
  10. NOT CATCHING ANY CODES
  11. hood
  12. Roll Coal?
  13. 6.5 oil cooler help
  14. 97 6.5 with bad turbo
  15. 81 chevy 3/4 4dr 6.2 what's it worth?
  16. 94 6.5 Running rough
  17. 95 3500hd wit mitsubishi 6d31
  18. 93 6.5 turbo diesel
  19. 1996 silverado 1500 6.5TD starting problems
  20. 6.5l parts
  21. changing a GMC 6.2 to a Cummins or power stroke
  22. 350 Old Diesel 5.7lt gm Detroit
  23. 94 6.5 running rough after reassembly
  24. Need parts site 94 6.5turbo rebuild
  25. 6.5l cuts out
  26. Water methanol injection
  27. just made high idle switch
  28. Gear Reduction Starters
  29. Stuck trying to change IP on 95 6.5 HELP
  30. transmission swap
  31. blue vent shades
  32. DTC CODES 41,42,87
  33. help
  34. 6.5l N/A quirks
  35. fuel line help
  36. 6.5L Rattles
  37. 6.2 diesel sitting issues
  38. replacing pmd
  39. 2004 6.5l duramax low oil pressure
  40. Tech 2
  41. 93/97 6.5 rebuild
  42. replacement starter
  43. 95 6.5 no start sometimes
  44. sticky throttle
  45. '98 k3500 Transmission Stuck in Limp Mode.
  46. 4l80E overdrive problems
  47. Vacuum pump??
  48. wastegate
  49. 6.5 td throttle stuck on street shut off then no start smoke coming from pmd
  50. Truck wont crank!!!
  51. What entails in a transmission swap?
  52. weight
  53. ICM? Won't fire up, if it does, not for long.
  54. elec. over hydro plow drawing too much power
  55. complete loss of electrical power?
  56. 94 6.5 \97 6.5 whats the difference ?
  57. Head gaskets n such
  58. rebuilding a 6.2
  59. leaking fuel truck not starting stalling when running
  60. glow plug relay,light,and eng-i fuse question?
  61. Chip for 99 chevy duramax
  62. flex plate probloms
  63. 1996 6.5 turbo
  64. please help
  65. 6.5 not starting
  66. good price?
  67. 1022770 km 6.5 van
  68. 6.5 turbo not working
  69. Pmd options any suggestions
  70. 1996 6.5L K3500 limp mode
  71. Bizarre! Truck not running right.
  72. programmers?
  73. Lack of power....
  74. 1996 6.5 chevy turbo diesel 200K any good?
  75. change ignition tumbler
  76. 6.2 won't start
  77. 6.2 injection pump timing
  78. need help!! rattling noise! thinking its a flexplate or torque convertor?!?
  79. water in fuel light while starting
  80. need some tires
  81. turning up idle speed?
  82. 6.5 wont start
  83. whisteling from my 6.2
  84. 1993 6.5 Turbo solid Flywheel
  85. Shuts down
  86. hard to start
  87. truck stalls
  88. codes
  89. 1.94 timing?
  90. 6.5 turbo smoke and sputter at start
  91. Fuel Advance
  92. My new 6.5
  93. broken glow plug update
  94. Broken Glow Plug!
  95. 6.2 hard starting and running very bad
  96. Trouble shooting help needed for a tranny
  97. Smoking at low rpm
  98. Checking the Glow Plugs
  99. transmmission problems
  100. need some quick help
  101. 6.2 turbo:jump:
  102. new plan
  103. crappy mpg, suggestions?
  104. No Throttle GMC 6.5
  105. Need pistons
  106. Hard starting 6.5
  107. INJECTORS
  108. OIL LEAKAGE
  109. 6.5 turbo shutting off while driving down the road?????
  110. ABS Light??
  111. Performance
  112. She won't start!!!
  113. crossover pipe help!?!
  114. broken screws in injection pump cover
  115. Won't start Man!!!
  116. Real head scratcher.
  117. yank mufflers or turn up ip screw more?
  118. mileage numbers
  119. rear main leaking?
  120. cdr can
  121. stacks
  122. colder weather
  123. ee
  124. 1994 6.5TD DTC 36 Question
  125. Fuel leak from injector pump?
  126. Wiring Harness
  127. Suburban rear doors
  128. fuel shutoff solenoid removal ?
  129. cheap injectors
  130. wastegate?
  131. WTS light not coming on
  132. replacing my injection pump
  133. 6.2 turbo
  134. DIY Injector Pump
  135. IP question
  136. IP swap
  137. 84 6.2 chevy IDI
  138. 3'' body lift?
  139. I want to change gears on a 96 2500 silverado
  140. how to make a 1996 chevy silverado get more mileage?
  141. dead cylinder?
  142. just bought a 93 6.5 have some questions
  143. 1993 6.5 with no power
  144. New Injectors and Gauges...Now more Exhaust?
  145. 1996 6.5 Diesel turns over but fails to start
  146. Cant be fixed?
  147. 1996 chevy silverado stalls
  148. OPS Location Fishy
  149. 6.5 Keeps dying on start
  150. 1996 chevy 6.5 turbo diesel loses power
  151. new here
  152. wont start, electrical problem
  153. 25 to 34 gallon tank
  154. two plugs to block heater??
  155. electrical issues
  156. 6.5 just dies
  157. vacuum wastegate question??
  158. chevy to cummins
  159. Piston to wall clearance
  160. performance chip
  161. 6.2 pump/injectors questions
  162. 95 6.5 wont go into overdrive???
  163. 1983 Chevy K20 Upgrade/Restoration project.
  164. power windows trouble
  165. hard starting and jumping while driving?
  166. 94 6.5 suburban BAD FUEL SUPPLY AND RETURN LINES
  167. another pmd question...
  168. OPS rewiring
  169. Mechanical Wastgate and Black Smoke Problems Please Help
  170. CODES
  171. ill effects of running NO thermostat?
  172. Large Capacity Fuel Tank?
  173. PLEASE HELP 1997 K1500 6.5 Turbo Diesel PLEASE HELP
  174. Diesel wont start Electrical Problem??
  175. 6.2 sensor/sender question
  176. 4L60 or 4L80?
  177. parts
  178. Blow by question...
  179. questions on MPG'S
  180. 1993 6.5 4x4 trouble starting after warm
  181. losing prime somehow
  182. black smoke
  183. Moving the PMD
  184. 1983 chevy with 6.2l questions
  185. 1995 Chevy 3500 6.5L turbo Diesel
  186. Is a '94 6.5 not able to be chipped?
  187. AC Problem
  188. Battery connection problems
  189. charging problem
  190. P 0236......help
  191. 6.5 no start after warm
  192. Injector Pump or fuel shut off?
  193. keeps losing prime?!?
  194. 4x4 conversion questions
  195. A team turbo
  196. APPS stupidity
  197. Cracked Manifold
  198. 6.5 run rough then died
  199. 93 6.5 turbo ops
  200. 1993 6.5 turbo power loss up hill?????????
  201. 6.2l lift
  202. engine swap
  203. Gauges
  204. What vehicle will my 6.2 fit.
  205. GM oil pressure??
  206. 88 diesel disaster
  207. 98 6.5 losing water no leak please help
  208. heading down the road chugged shut off now wont start
  209. 97 6.5TD Issues
  210. Pmd meltdown
  211. 6.5 Diesel Stacks
  212. Kojo, Heath, SSD or Kennedy tuning?
  213. torque converter
  214. 6.2 non turbo need info
  215. 6.5 chevy loses all power in gear but can rev rpm in neutral?
  216. 6.5 oil in the coolant
  217. throttle surge
  218. Throttle Surge
  219. strange noise from airbox
  220. Trans conversion
  221. 6.5 stalling when full throttle?
  222. Changing front brakes on 8 lug 6.5
  223. 98 Chevy box van with 6.5L
  224. Won't shift
  225. 6.5 fuel/water separator
  226. 95 6.5TD misses
  227. '99 Stalling
  228. Crankshaft failer
  229. trans problem
  230. 6.5 HAS THE FLU
  231. 6.5 vac hose question
  232. 6.5 Stumbling
  233. 6.2 Not Starting Sometimes
  234. GM says looking into PMD problems, sign my petition, lets get this fixed
  235. OPS location ????? anyone tell where???
  236. 95 HD2500 what's worth?
  237. Where is my turbo whistle?
  238. 6.5 turbo on 6.2
  239. 6.5L Puffing Black smoke when accelerating
  240. 6.2 UpGrades
  241. obdi dtc 99
  242. need power steering pump help '99 6.5 3500
  243. 1997 6.5 will start but wont idle
  244. 6.5L TD stalling and other problems.
  245. boost
  246. PMD Failure...First Things Noticed??
  247. 6.5 mech pump swap to manual pump questions
  248. 6.5 TD wont start sometimes and misfires when I mash down on it
  249. What Torque Converter Do I Need?
  250. RPM Gage fluctuating should I be concerned?
