- 96 6.5 injection type
- Unknown Part!!!!
- Slow cranking
- 94 6.5 turbo 2500 fuel issue
- Buying a 98 6.5 with high milage
- 1999 6.5 turbo diesel upgrades!
- code p0236?
- CUCV update
- straight piping a 6.5
- 94 lift pump question
- haveing new problems on 95 6.5turbo
- '02 chevy van wont start
- New to the site, and in need of help
- Howdy everybody!
- I Love this truck
- 1993 6.5 cooling problem
- My rides
- S-L-O-W
- exhaust manifolds 6.5 /6.2 the same?
- 1995 Chevy 2500 wont even turn over!!!!
- oil filter
- injector compare
- Truck Failed Lift Pump Test...Now how to I replace it?
- 1995 6.5TD
- Need Help
- 1988 Chevy P30 6.2L problems
- Part Description
- Oh no another NOOB
- THROTTLE ISSUE
- 6.5 turbo diesel exhaust
- Speedometer help!!!
- No Start
- ect no signal 95 6.5
- m1008 military truck
- 6.2 military truck
- feeling lost need help
- What would u pay?
- Adding fuel = power?
- Is it possible to get a 6.2L into an El Camino?
- 6.5 throttle issues
- 6.2L Turbo Kits
- 86 6.2 smokes a lot and sputters under acceleration and at idle
- 6.5 started black smoke
- FUEL GAGE SITTING WAY PAST FULL
- Transmission Question
- 1994 6.5 NON-Turbo stalling after start then great again for the day once restarted
- 6.2 c code and j code engine differences
- Charging issues
- Trans downshifts / Odometer light goes off
- Running Again
- Power loss
- 6.5 starter issues
- staying in 2nd gear after warmed up???
- Honest opinions on these engines
- Wont start?
- 83 6.2l starts then dies
- Problem(s)...not sure what they are
- at a loss
- 6.2l Diesel Won't Start
- Pictures of my truck - New Lights!!!!
- chance to buy 6.5
- Got my truck runnung.... sort of.....
- Changed location of pmd, lmk what you think.
- 6.5 in 94 Chevy 3500 Stalling
- What are the dangers of replacing my dead turbo.
- Bad news!! Blown head gasket!
- Replacing motor
- another fuel economy post, with a variation
- 6.2L injector pump priming procedure
- blowing black smoke and power loss
- crank pulley rattle
- 1993 6.5 wont stay running
- Replacement for air pump
- What fits ?
- Injector pump timing
- In an attempt to increase my fuel mileage......
- 87 6.2 glow light wont ever shut off
- 95 C3500HD Limp mode?
- question???
- Lift pump test and now it won't start.
- Need a new front bumper for our 1998 Suburban
- instrument cluster question
- Help! 6.5L low oil reading.
- 1997 express van i shut it off next day wont start
- Fuel Filter Housing?
- 6.5 td lift kit
- code help!!!!
- can it be done?
- replaced head gasket
- Turbo Questions
- Oil cooler lines blocked off
- Serpentine belt
- Code 12 on a 1994 6.5??????????????
- Rim and tire size help
- throwing codes?
- Exhaust
- 6.2 trans shifting issues... Long story no fun
- Good Crank.... No start
- 6.2l CDR
- Block off plate
- fuel line
- 6.5 td chip?
- Frustrated!!
- 6.5 td cheap upgrades
- need help: 6.5 problems
- APPS SENSOR or ?
- 18:1 Pistons
- 95 Chevy Tahoe- parts and pieces?
- 6.5 tb- Turbo not spooling
- Engine troubles.
- Sticking starter
- 6.5 van vs truck whats diff
- 1997 6.5 runs rough when cold
- 6.5 lift kit
- 1999 chevy 3500 6.5 stalls intermintently
- 6.2 Questions
- 6.2 liter non turbo
- Head bolts and gaskets?
- If I wanted to replace a 6.5 with a rebuilt engine, what would be a good choice?
- Starter brace
- High idle solenoid on 6.2
- Need More traction
- Installing mechanical injection pump
- HELP rear end pinion bearings?
- 6.2 Rad on a 6.5 TD
- Injectors??
- i need help 6.5 turbo shut off and wont start i have replaced everything
- Glow Plugs
- 6.5 diesel fuel milleage
- Need advice on lift kit for 94 chevy 3500 4x4 6.5 dually
- Harmonic Balancer Fluid Dampr...?
- 95 6.5l stalling out an shuts off about 30 min
- Turbo silencer
- first steps
- Throttle noise?
- 1996 6.5 won't start, have power but only clicks when cranked
- room for tires
- 1999 4 wheel
- what is the normal oil pressure for 6.5
- replacing valves on 6.5 head
- intermittent fuel issues 1996 chevy silverado 2500 turbo diesel
- diesel virgin...6.2 wont turn over
- 1995 6.5 t.d. no upshift
- starter issues
- 99 6.5 Blowin Coal (Want to fix it)
- should I buy it, and will it worky?
- 6.5 turbo diesel
- 6.5 L Assembly - Elite Newbie questions
- Lift Pump Pressure
- 6.5 DB2 Injection Pump Problem
- 6.2 ip modifications
- cucv pics please
- 6.2l dying after 20 mins of running
- Ultragauge
- 6.5 keeps shutting off any help?
- No fuel
- 6.5 no electric to gauges and fuses need help asap
- 1989 GMC 6.2 Service Fuel Filter Light
- betcha can't help
- 6.5L 1999 Sanava Won't start
- 1995 Chevy 2500 6.5L
- HELP need piston help!!!
- Rough idle, barely runs 94 6.5td
- 95 6.5 won't start
- 4l80 no overdrive or reverse
- Silencer Ring
- Favor fuel manager
- 99 k3500 dually question. Had the truck 10 years and no problems til now
- Wont start , no power to starter, hvac blower no
- Where to begin, and what are my options
- 1994 6.5 Wont start
- 94 6.5L turbo 1/2 ton chevy
- any ideas?
- rebuilding lowerend end of 6.5 is there anything perf i could do
- 6.5TD black smoke and slow acceleration... help...
- Another start then stall... hard restart, I searched but no answer..
- Leveling kit
- 95 chevy 6.5 ops problems
- 93 6.5 upgrade help please
- Is the 6.5l a good engine?
- Dual Alternators
- new 6.5 blocks
- EGT Probe
- Trying not to get ripped off...
- 14 bolt diff removal help
- HELP!!! bad running
- Cold start problems
- Fuel leak
- Need Help ASAP
- fuel problem
- to anyone that has to change a head gasket on 6.5
- 1980s 6.2l blazer military or not
- 95 6.5 turbo question
- I still Need a 14 - 16^2cm turbine housing for a HX40W
- 1999 diesel sub
- pmd wiring...
- 6.2 No Fuel At Injectors
- Cooling Fans
- R.I.P. Crazy (bruce)
- 82 6.2 glow plug light blinking
- low voltage issue fixed.
- Interesting Alternator Issue
- Starting Problem
- I am looking for a HX40 14cm turbine housing
- "Crazy" had a heart attack?
- np 208c output shaft
- changing a injection pump
- which headgasket to use?
- 6.2 turbo
- 86 military 6.2
- Starter Holes Are Oblong 6.5 Turbo Diesel
- head gasket thread?
- 6.5 turbo diesel lift pump problems
- Starting question
- How to achieve best mpg
- 6.5 going down hill, i need help
- Why no fuel? ... sometimes
- #9,#5 pmd resistor
- 95 k2500 glow plug relay wiring
- 6.2 tach
- 93 6.2 4x4 tranny info wanted
- Vac Pump Q
- fuel injectors
- cannot figure this 6.5 out! help!!!
- 6.2 high idle switch
- Fuel pump
- 1999 suburban 6.5
- Oil Pump question....
- crank sensor stuck in block
- 6.2 will rev up and sometimes will die
- Alternator belt on 6.2
- 1997 K2500 runs itself out of fuel
- I need 4 T precups
- 94 suburban 6.5 turbo wont start
- Remote start for 6.5?
- Oil Pan Removal
- Is this blazer worth it?
- Broken fuel guage
- want to buy water neck crossover
- Chevy Tahoe w/ turbo diesel...
- anther dumb ?
- 4x4 not engaging..
- 6.5 turbo kit instructions
- 96 6.5l 4 sale
- Need some Mods
- push rod trouble
- High Idle and cold weather ?
- coolant leaks all over
- 1999 K3500 Tempermental Throttle
