- 89 7.3L Exhaust
- Oil pressure gauge actin funky
- hard start when hot
- 6.9 wont crank!!!
- fuel tank selector valve ot working?
- power question???
- leaking fuel filter
- Broken GP tip
- grab handles
- F%^&ing ignition tumbler broke, new one isn't going in right..... HELP!
- 92 Headlights flashing
- What weight oil for my 88 7.3 IDI w/ Banks turbo?
- turbo trouble.
- 89 f450 exhaust
- now that I have the fuel lines...now the tank control valve???
- boost
- Run your IDI outta fuel and it won't start?
- another blue smoke question
- MPG?
- gear ratio
- A-Pillar
- anyone have the bronze gear for the ignition switch
- fuel mileage
- Truck Appearence
- Need Some Advice on my 94 Ford 7.3 IDI Turbo
- is there a full fuel line kit for the 1983 f250 with the IHI 6.9?
- Speedometer & Tach Problems
- Trouble Starting
- DUMBFOUNDED
- Turbos
- Need Help
- Glow Plug Site
- 94 f350 fuel tank question
- 94 idi turbo injectors
- just bought a 94 idi have a few questions
- 1985 Ford 6.9
- Cold Start
- Tranny swap Info?
- 86 F350 6.9 Fuel Pressure
- 92 F350 Loosing headlights randomly
- Glow plug removal
- 1987 F-250 6.9
- Fuse ???
- It's officially a sickness when....
- Parking brake/dash problems
- fuse block
- parking brake
- need info
- ford 6.9 diesel fuel delivery problems
- 94 idi turbo f-250
- 91 7.3l
- 1988 F-250 2WD would get stuck in a parking lot!
- 7.3 in a 74
- fuel lines
- 1990 soon to be powerstroke...
- valve lash
- sensors
- RASB Valve
- Questions about 6.9 and 7.3
- Oil pressure psi.
- blow off valve/ wastegate
- 89 f250 brake problem 7.3 idi
- Glow plug issues
- 6.9 woes wont stay running
- funky dash where to start
- Show off your IDI!
- glow plug controller problem
- LEAKS
- do I have to have this,1991 7.3
- speedometer might have an issue
- caster angle
- COLD START
- 1988 7.3l idi fuel pump turn up
- Block Heater
- turbo
- E4OD rebuild Tips Suggestions
- speedometer
- 92 F350 7.3-back firing
- NEW GUY
- Blue smoke need help.
- Bottom of Radiator Cold
- selector switch
- 7.3 idi wont start.
- tank selector switch
- ABS?
- RUNNING HOT
- I need a y casting for ATS turbo.
- changing return fuel orings
- vacuum
- Important firewall repair crack info
- 1988 F250 IDI Electrical Problem
- NEED HELP BADLY
- front end
- parts
- block heater
- STARTING PROBLEM
- dont know what motor i got
- 6.9L Diesel glow plugs
- transmission problems!!!!
- new truck
- INSPECTION
- How hard to change gasket/o ring on oil cooler tube?
- 90 7.3 clutch
- 94 idi ford turbo diesel non power joke
- wiring problems
- 1993 F-250 7.3L IDI PULLING ISSUES
- GAS MILEAGE
- 87 f250 question
- Leaking IP or NOT???
- BLOCK HEATER
- MUFFLER
- fuel pressure
- how to change a block heater
- what the heck
- glow plug solenoid problem
- 7.3 injector pump
- oil again
- replacing my cab
- Valley Pan or Control Switch LEAK
- oil burning
- 1989 f-350 7.3 starting problem
- Which years fit a 85' f250 for tailgate?
- 1990 7.3 hard start
- 92 F350 transmission
- truck is surging
- whats it worth
- Aftermarket Tachometer Question
- 1985 f250 6.9 problems
- 93 7.3 turbo- developed miss and other noise
- 7.3 idi dies under a load.
- 86 F350 6.9 questions
- oil leakage 1 gallon a day
- Is it safe to bore a 7.3 1990 .030 over?
- e4od transmission problem
- Glow plugs not getting hot
- need 80-86 truck body parts
- Ford Deuce Roadster
- 85 rear tank not working
- help with ip on 7.3 idi turbo
- 6.9 running great (fuel cutoff in top of pump)
- Heater core bad?
- toy
- need help with injectors
- Front Hub Problems please help!!!
- pro-charger ?
- Fan went into the radiator
- 6.9 f250 85 pickup DIEISEL with MEASELS
- 85 f 250 6.9 no fuel at injectors
- Water pump leaking
- Burning Up Glowplugs
- 6.9 egts
- Knock when first started
- engine will not heat up
- Weird pickup while driving
- Front axle
- Glow plug relay wiring 93 F250 non turbo
- Fuel Filter Changes for dummies?
- '92 7.3 IDI missing/surging gray/blue smoke
- Exhaust
- truck won't start.
- pics of ats turbo hooked up right
- Best battery for the 6.9L?
- Return line
- 91 non turbo 7.3 engine swap ?s
- turbo a 7.3 idi help
- F250 Intrernational 7.3
- exaust size
- 6.9 turbo adjust
- 7.3 in custom explorer any comments?
- funky fuel guage
- 86 f250 6.9 starting but does not stay running
- replacing my cab
- 1992 f250 7.3 wont start
- 7.3 na advise
- 7.3 turbo idi, help please
- HELP PLEASE
- Non Turbo 7.3 advise please!
- owners manual and repair manual
- more power
- Leaky IP
- 1990 IDI what to do with it?
- slow take off
- TEMP. QUESTION
- nothin fancy
- ready to start
- poor throttle response and low power
- custom turbo
- tranny for 88 ford
- timing advance??
- clutch
- ip pump
- 4x4 conversion
- mpg?
- 93 f250
- wieghts and dimensions
- 1992 7.3 diesel bone stock.
- Clutch Adjustment
- Wiring Harness Swap
- E4OD controller
- Shifting Problem? Cab Floors?
- **1985 F250 6.9L EBay listing $2000 start bid
- 1985 CLEAN F250 6.9l for sale $4000 obo
- Won't fire when cranking
- Air conditioning
- My 1992 F350 7.3 powerstroke won't start
- Worth it?
- Rear end info
- Straight Pipe?
- High idle problem
- Racor?
- What can I get for under $5K
- head bolt torque specs
- Borg warner?
- 87 f250 tranny trouble
- 89 7.3l
- Transmission question from a new guy
- 7.3 idi w/banks sidewinder kit
- 87 6.9 questions
- looking for injectors/exhaust
- 85 6.9 sloooooow starting
- Looked at a GPR...WTF!!
- tires
- 85 3/4 6.9 L glow plugs not working??
- need help!!!!IP
- Clicking noise?
- How much oil, additives?
- Exhaust diameter question.
- IDI turbo.
- Fuel Problems with my 6.9!
- How much HP and TQ do you make Turbo-N/A?
- Looking at a 1993 w/turbo.
- 84 f-350 6.9 and 4spd
- ZF 5S-42 Parking Brake Woes
- Turning Up The 7.3 IDI
- My tach 'aint tachin
- 6.9 f350 won`t shut off !!
- Which IDI?
- 7.3 / 6.9 Max driveble hp & tq min $ Tell me what you think.
- f250 to f350
- 7.3 injectors
- EGT gauge on 6.9/7.3?
- Oil Cooler
- Turbo Rebuild Kit???
- what is the differance between the E40D and the 4R100 transmission
- Will Super duty lift fit my 92 f350?
- Where is my coolant sensor?
- help with hood stack on 91 f250 7.3idi
- What do you think? Do I need an intercooler?
- 1990 f-250 7.3 diesel won't start
